Pressing horn activates AC and vice versa
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nicotin3, Jun 13, 2015.
  1. Nicotin3
    Nicotin3 Junior Member
    22
    Romania
    Good day,
    After a cleaning of AC. The next day, when I tried to honk, it didn't stop. I took out the fuse cause I couldn't find a solution. Now when I press the horn from the wheel it activates AC, it is the same function like the one on the left of the wheel. And if I plug the fuse back, when I start the AC it keeps honking continuously. I guess some of the foam was leaking somewhere on the electrical parts.
    Any ideas on this matter.
    Thank you in advance.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    First thing I'd check is your 12v battery. If it was weak and you left the doors open and the interior lights on they could have run it low. When the 12v is failed/failing on a Prius the car does all sorts of weird things like you suggest.
    It might not be the 12v, but it's always the first thing to look at. They're only about £95 fitted to replace using genuine Toyota parts.
    52,831
    how did you clean the a/c?
  4. Mendel Leisk
    42,331
    This reminds me of the time I had a washer fluid leak, on another vehicle. In the course of troubleshooting I took the front bumper off*, and pulled off two identical electrical connectors, one for right turn signal, one going to the wiper fluid motor.
    Long story short: finally sorted everything out, got everything back together. When plugging the electrical connectors back in, it seemed like there was barely enough reach on one of them, no matter. So later, went for a drive, everything fine, then pulling back into our side street I signalled a right turn, and got rhythmic squirts of washer fluid for my troubles. :ROFLMAO:
    * Later found the leak, and it was nowhere near the front bumper, but hey...
    #4 Mendel Leisk, Jun 13, 2015
  5. bisco
    52,831
    i wonder if there's a short inside the steering wheel, or the clock spring?
  6. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I wonder if they used the wrong a/c lubrication oil and are now getting shorts going on in places where it shouldn't? Doesn't the Prius require a special non conductive a/c lubricant?
  7. Nicotin3
    22
    Romania
    I used a foam cleaner like this one from the video
    I didn't touch any wires, but the liquid which comes with the foam could have.
  8. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I think you've found your problem.
  9. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    I take it that either you or a previous owner smoked in the car...
    Bill the Engineer
  10. bisco
    52,831
    i'm not sure where it would touch anything in the vents, the fan i suppose. maybe turn on a/c and disconnect horn, use fresh air, fan on high.
  11. Nicotin3
    22
    Romania
    I had the ac running all day after a long drive without any result.
    The thing is that when the horn fuse is on and I am starting the AC, it honks continuously. I cannot find in the wiring diagram any connection between the two of them except the one on the wheel.
  12. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Assuming there are no holes in the vent tubing or that the spray didn't get all over the electrics internally, which it's sounding like it has.
  13. ChapmanF
    19,009
    I am going to out myself as a skeptic on the cleaning-foam-causation theory. There really is hardly anything electrical within the ducts and heater enclosure (aside from the PTC electric heat elements), so we'd have to walk further down the probability scale to where a bunch of foam drips out at one of the joints in the ductwork and happens to get somewhere that it can conduct between the horn and steering-wheel-control buttons. I doubt the cleaning foam actually dissolves wire insulation (you could spray some on a spare bit of electric wire and see), so the likeliest thing left for this theory would be the stuff dribbling down the wires and reaching a connector, forming a path between two or more of the pins, which are usually pretty well recessed in the connector shell. I won't say impossible, I'm trying to weigh probabilities.
    bisco's "clock spring" suggestion refers to the wound-up ribbon cable behind the steering wheel that allows the wheel to turn while carring the electrical paths for the wheel-mounted controls, horn, and airbag. Your car is nine years old and those ribbon cables have been known to wear through the insulation in spots, and create weird interactions between different wheel-mounted controls. There are existing PriusChat threads about it. It's possible for such a problem to have come along independently of your AC foaming, but at just the right time to be confusing.
    Typical of a clockspring problem is that how often it happens can depend on which way the wheel is pointed, or you get the classic 'horn honks every time I turn left' kind of thing. Maybe that isn't a feature in your case.
    To check any of that out, you'll at least end up removing the plastic trim around the steering column. You should be able to find the connector attaching to the clockspring itself. Maybe you'll find that connector is right under a ductwork joint and it's gooey. In that case, maybe there's something to the AC goo theory after all. If not, you'd probably just proceed to examining the clockspring itself, which you get to by pulling the steering wheel.
    The service manual has important words for you regarding how to do that while safely handling the airbag. Do note that any bright yellow wiring connectors you see in that area will be airbag-related.
    -Chap
    Nicotin3 likes this.
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The foam startled the mouse, who ran to a different place and from nerves ate a quick wire lunch.
    GrumpyCabbie and Nicotin3 like this.
  15. Nicotin3
    22
    Romania
    Thank you for the suggestion about the clock spring. Indeed, I made the connection with the foam, because it was the last thing I've done, but can be just a coincidence. The foam it's not so dangerous that can damage any of the wires. But after I've done the cleaning, there was some liquid falling on the mats. After I opened the cock pit I figured there is a way to leak through the sponge seal of the AC piping.
    I found about the clock spring but I cannot figure out if there is any way to dismantle or disconnect and still keep the airbag connected.
    I would like to try to disconnect the clock spring and then try to turn the AC on from multi-display.
  16. ChapmanF
    19,009
    No, the clockspring is behind the steering wheel, the steering wheel nut is behind the airbag, and the clockspring is part of the airbag circuit. It's not a difficult job otherwise, just make sure you learn the precautions against accidentally deploying the bag (at close range, not good for you).
    But as I suggested above, you can probably see the connections on the stationary side of the clockspring, anyway, just by removing the plastic trim around the steering column. If it has anything to do with the A/C foam, I'd think the connectors on that side would be the only ones with any chance of being near a ductwork joint.
    -Chap
  17. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I would check the wiring harness coming off the steering wheel under the dash..it sounds to me that fluid leaked out of the ac ductwork and into the connector causing a common ground between the two circuits.(horn and ac controls) does the steering wheel still work the radio?..id use a hair dryer to get the moisture out of the connector before ripping things apart
  18. Nicotin3
    22
    Romania
    Fist of all thank you everybody for your time and suggestions.
    Today somebody commanded to take out all the connectors and clean them with a contact cleaner spray. When I was driving back from the shop an error came on the display " A program cannot be read. Please consult the dealer".
    I got the spray, took out all the cock pit, MDF and the cover of the wheel. Cleaned all the connectors and placed everything back in place. Under the wheel there are the connectors for airbag and three more, I found some lubricant oil on tow of them, I don't know if it is normal or not(see second photo). After I placed everything back and tried if the horn works, at the 1st press of the horn the same problem appeared, it didn't stop honking. I didn't want to stop it and tested all the buttons on the steering wheel. "AC auto" button stopped the horn. Then I played with the "AC auto" button and the problem disappeared. Meantime I took few rides and tested the horn and the AC button, only once it happened when I was switching on the AC from the steering wheel it started also the horn, except of that nothing happened.
    Now I got a different problem. The navigation doesn't work anymore. It gives the error " A program cannot be read. Please consult the dealer".
    Into the service menu I had few errors and NRES on the navigation. (see attached photos). I did a memory clear and error resetting, but the NRES didn't went away.
    Any suggestions on the last matter?
    PS: 1st of all I removed the "-" from the 12V battery. But few days ago I removed by mistake the "+" when the horn was honking continuously in traffic.
    #18 Nicotin3, Jun 14, 2015
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    I was hoping that as things dried out your gremlins would go away, but it does not seem quite that simple.
  20. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    And the health of the 12v is what?
