pressing the brake, but the green light never comes on
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by J2014, Jun 8, 2014.
  1. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    You are assuming that all dealers are ethical and that all their employees are competent.
    That's a pretty WILD assumption I think.
  2. Easy Rider
    982
    210
    N. Central Florida
    Does that mean that you have not actually tried to start it and drive it since you noticed this ??
    If not, you should try that NOW.
    If it does seem to drive OK, the light might just be bad.......or a computer glitch.
  3. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    We'll have to see how this plays out.
    However, I am inclined to believe the OP's problem is due to a faulty brake switch than the vehicle not receiving the recent software update prior to sale.
    Yes, that is MY belief, however WILD it may be. ;)
    SCH-I535
  4. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    Unlikely (for a 2014), but...dead fob battery?
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    I think you would get a no key detected notice.
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    I still think you need to be a little more firm pressing the brake pedal or it is the brake light switch!
    The dealer will figure it out! :)
  7. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    The 15 sec method. Press the power once, the amber light comes on,press the brake and push the power button and hold it for 15 sec, the ready light will come on.
    The ONLY way to start the car is going through the method I mentioned.
    I pressed the brake all the way to the floor and still no green light.
    We will find out what happens after we bring it to the shop.
  8. bisco
    51,907
    where did you learn the 15 second method? i never heard of it.
  9. El Dobro
    El Dobro A Member
    7,088
    3,270
    New one on me.
  10. xliderider
    8,140
    3,276
    Honolulu, HI
    Just to rule out the key fob battery...
    Press and hold the brake pedal. Hold your key fob against the Power button. The green light should light after a couple of seconds, even if there is no battery in the fob.
    SCH-I535
  11. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Lights, LEDs, whatever have been known to go bad. If the car starts is not an immediate problem. The dealer should be able to fix it.
  12. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
  13. retired4999
    2,652
    627
    Eau Claire, Wi.
    Let us know how things turn out. :)
    good luck!
  14. bisco
    51,907
  15. GregP507
    GregP507 Senior Member
    3,002
    481
    According to a reliable source (my dealer) running the Prius battery dead in the showroom was an almost daily occurrence. By the time I got the car, the aux battery was shot; only holding 10-15 mins of charge at best, in acc mode. Apparently they believed (as I did) that keeping the hybrid battery plugged in would keep the aux battery up as well. Not true at all, although such a feature would be much appreciated.
  16. GregP507
    3,002
    481
    I agree, and that's why I spent so much time researching what sort of a dealer I was buying from. In some ways, we buyers get what we deserve when we don't put much thought into buying a car from a dealer with questionable ethics. In a perfect world, everyone would deal only with those dealers who have genuinely earned a high customer satisfaction rating. Until then, I guess some of us will continue to pay the price for our lack of high standards.
  17. J2014
    J2014 Junior Member
    37
    2014 Prius Plug-in
    OK, the car is staying over night at the dealership.
    He said there's an open circuit and the switch for the break is broken. They need to order a new switch. I think someone metioned that on here too.
  18. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep! Glad it is going to be a easy fix!(y)
  19. CharlesH
    2,796
    1,163
    Roseville, CA
    And a free warranty job.
  20. Easy Rider
    982
    210
    N. Central Florida
    And along with that, I think someone asked if the brake lights were working or not.
    Were they ?
    I think some of us assumed that if the brake lights worked, that would rule out the switch.
    Maybe there is more than one switch.......or multiple contacts ??
