Pretty Sure my HV Battery is about done.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MPGHokage, Jun 30, 2018.
  1. MPGHokage
    MPGHokage Junior Member
    Utah
    Hey guys, I bought a 2008 Toyota Prius, and I'm thinking the HV Battery is just about on its last legs. I budgeted for the expense so it's not a big deal as I was expecting it. However, I want your input before I buy one.
    My average MPG has been sitting around 36-42 with it dropping about 10% within the last 3 months
    When I go on break from work I frequently (though not always) will go from 1 bar in the green to 1 bar purple in about 3600 feet (I measured it on google maps). In which case my acceleration from zero is quite pathetic.
    I bought a Prolong Grid Charger, and I'm confident that it's the reason it has lasted so Long.
    Otherwise I think I should replace the battery now before it fails and potentially leaves me stranded.
    Would I be best to get a battery from NewPriusBatteries.com | Home ? I Have the ability to replace it myself so that's not an issue.
    Or would my best bet be to just go to the dealership and spend the extra 1000$ which I would prefer I didn't do.
    Thanks for the Input! Let me know if I left any information out that could help!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    With a Prolong setup another option might be to look at local salvage yard for a late Gen3 (2013 through 2015) and swap all the modules;).
    You’ve got the right equipment, and I bet the salvage yard pack won’t be too pricey :).
    Another option worth considering (y).
    SFO and jerrymildred like this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,450
    3,358
    Madison, Wisconsin
    Have you gone to the dealer parts department and found out what their best price is on a battery?
    If you have a few dealers, call around.
    jerrymildred and ITBland like this.
  4. MPGHokage
    Utah
    Gen 3s work? Hmmph, I might have to look into it haha
    Raytheeagle likes this.
  5. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Same number of modules ;).
    All you have to do is remove them from the Gen3 case and put them into your existing Gen2 case:).
    So some assembly required ;).
    Good luck with your decision (y).
  6. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    I'd place a preorder for the NewPriusBatteries.com | Home right now.. and then decide later.. they are still at least a month out.. Sell the core batteries that are functional on ebay..
