Prevent EGR troubles?
Discussion in 'Gen 3 Prius Technical Discussion' started by Harryjo, Nov 1, 2018.
  1. Mendel Leisk
    42,343
    You mean "newer" rings in general? In third gen, the last year (2015) rings are supposedly the cure for oil consumption, according to the tsb. I'd really like to see a review of the two ring sets, comparison photos.
    2010~14 piston ring set part number: 13011-37110
    2010~13 piston part number: 13101-37120
    2015 piston ring set part number: 13011-37260
    2014~15 piston part number: 13101-37240
    2016/17 piston ring set part number: 13011-37270
    2016/17 piston part number: 13101-37250
    I looked up 4th gen pistons and ring sets too, @Ragingfit mentioned that 4th gen ring set as well would work.
    Simtronic, Grit and padroo like this.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    We'll see. I was referring to most all car engines made in the last 10 years.
    I am skeptical of all newly introduced products and remedies.
  3. Mendel Leisk
    42,343
    Understand. Just get the sense they back pedalled a bit with the 2015, as oil consumption reports started piling up? Again the tsb for repair due to excess oil consumption involves putting in 2015 rings and pistons.
    No trivial task, theoretically 16~ hours labour, though I wonder what the reality would be. The engine removal instruction references myriad Repair Manual sections, which I didn't check, but looking at the parts list, the implication is to pull the engine AND transaxle. This seems like overkill, I'd think it's easier to just separate the engine from transaxle and pull the engine, per @Ragingfit 's videos:
    Swapping in a Gen 4 Prius' 2ZR Engine into the Prius v | PriusChat
    It's a Prius v, but the principles are the same.
    (I'm slowly working myself up into a lather over this. And I've got 78K kms, and zero consumption.:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:)
    Georgina Rudkus likes this.
  4. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    I'd trade in the car before I'd do the ring replacement. In the meantime, I'd lessen the mileage between oil changes and install and monitor the OCC. What you see in the OCC is a good indicator of the condition of the piston rings and cylinder walls.
  5. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Dump in a bottle of Techron 4 times a year.
    Easy.
    Done.
    And 8 or 10 yrs from now, if my Prius Plumbing is plugged, I just buy a new car. :D (Or I will be dead. One or the other.)
  6. Mendel Leisk
    42,343
    4th gen has a better EGR design, and I'll wager better pistons/rings. If it didn't look like a deranged, kicked-in-the-butt Pokemon, with an obscenely gargantuan touch-screen dominating the dash, eating up more and more functions, and expanses of porcelain-white trim, it'd be pretty nice car.
  7. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    I'll pass, too, for the same reasons.
    I'll wait until 2023 and will likely get a full BEV with no ICE.
  8. Jdh2425
    Jdh2425 Junior Member
    Baltimore
    Wow, reading all of this is disheartening. I just got out of a diesel for all these reasons, and went with a Prius to get that Toyota "appliance reliability".
    It looks like I made a mistake.
    I'm beginning to think the only answer is to buy an older car and rip out all the emission components.
  9. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    Hey guys? I think I found the sales pitch for the Corolla Hybrid...
    Raytheeagle and Mendel Leisk like this.
  10. Mendel Leisk
    42,343
    Emission components on older vehicles tend to less problematic? I definitely wouldn't rip out anything, especially if it's not problematic. I took a look at our previous 06 Civic's EGR, it was a simple contraption, about the size of a fist, and the inside was just a little sooty.
    Raytheeagle likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    The Prime doesn’t look that bad:
    AFC8B766-DAB9-4A32-AF89-A5450D273643.jpeg DB4FB6D1-D702-4D1D-A98F-837723E40DFF.jpeg
    Aggressive (y).
    Grit and FnRedPrius like this.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Think that's bad, just wait til you read up on inverter failures.
    Soujiro13 likes this.
  13. ColoPriusV
    ColoPriusV Member
    35
    27
    Boulder. Colorado
    Has anyone considered modifying the EGR cooler by removing or expanding some of the internal baffles?
    Positives would be less internal restriction that allowed the cooler to continue to operate when it would otherwise to get plugged; negatives are that cooling capacity would be reduced.
  14. Mendel Leisk
    42,343
    Nah, don't go there, near impossible, very impractical. That thing HAS to be water-tight, and is counting on the radiator to cool exhaust gases. It'd be like working on a boat in a bottle, after it's in the bottle...
    Just get used to cleaning, say every 50K miles? The first time is the hardest.
    mikey_t and Raytheeagle like this.
  15. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    It’s like riding a bike after that:).
    And if you get good at it, you’ll help others too(y).
  16. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    How clean should these be, can you shine a light in 1 end and see it through the other and is oven cleaner still the best solution to clean with.
  17. Mendel Leisk
    42,343
    Keep an eye on the EGR tube condition, probably redo every 50K miles?
    I'll probably redo every 50K kms, it keeps me busy. That is if I ever get there...
    I like Oxi-Clean for the cooler, easier on the hands. For the pipe and valve: carb or brake cleaner. For sure don't use Oxi on the valve, since it's aluminum: it might not harm it but I think it would really dull the finish.
    I don't have a pressure washer, but I've heard that's a game changer. I'm ok with life in the slow lane though.
  18. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    ..so you like it then I gather? :ROFLMAO:
  19. ChapmanF
    19,019
    EGR on my mom's 1979 Colt would be clogged every time you turned around.
    The EGR valve on my 1984 Bronco II was kind of ok, but the position sensor on it had a way of drifting out of calibration. It was replaceable separately (just sat on the valve with three screws) but not as cheap as you might want for flaking out as often as it did.
  20. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    How about a local DIY car wash? Those are like every few blocks here.
