Preview: 2010 Honda Insight
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Jan 17, 2009.
  1. Per
    Per New Member
    232
    San Antonio
    True, but I can get 60+ MPG if I work at it too. The EPA tests should be a fairly equal testing ground for comparison.
  2. Tideland Prius
    16,680
    Yeah but the Insight starts at a lower official EPA and uses a mild hybrid system. These are regular folks getting 60mpg. I got 60mpg once but I had to work at it.
  3. JSH
    JSH Senior Member
    2,605
    140
    PDX
    The Insight is 2 seconds faster than a Civic Hybrid 0-60. My guess that the Insight has lower gearing. That would explain lower mileage and quicker acceleration even though the Insight has slightly less power than the Civic.
  4. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    1.339, apparently. But Honda UK call it 1.4. :)
  5. drees
    drees Senior Member
    1,782
    247
    Yeah, no kidding. The only time I've seen more than 55mpg on the Prius is when going downhill. Otherwise it's mid-high 40s.
    The Insight is also a couple hundred pounds lighter that the HCH, isn't it?
    I'm also surprised at the EPA ratings of the Insight II given that under "normal" driving the early test drivers were getting mid-40s...
  6. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Almost, 180 lbs.
    --------------------- Insight --------- Civic Hybrid
    0-60 ----------------- 10.9 -------------- 13.5
    Curb Weights ------- 2736 -------------- 2896
    Horsepower ---------- 98 ---------------- 110
    Torque --------------- 123 --------------- 123
    Drive Ratio ------- 4.20 : 1 ------------- 4.94 : 1
    CVT Ratio:
    ---- High --------- 0.53 : 1 -------------- 0.42 : 1
    ---- Low ---------- 3.17: 1 -------------- 2.53 : 1
    (Specs from edmunds.com)
  7. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    They were doing a Honda-selected course, with presumably a warmed-up car rotated among the journalists.
    I seem to recall reading an article about this press day and the creator of CleanMPG was interviewed. He got over 95mpg on the same course in his Prius.
    Article.
  8. Tideland Prius
    16,680
    Ok but they can barely get 50mpg if they tried out of the Prius
    Riight... so compete with other 1.4 litre cars?
  9. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The 60+ mpg reports are from journalists who agreed to drive a specially laid out course for fuel economy. Can we please stop this apple-to-oranges Prius to Insight comparision Jhinton and others ?
    I am not an Insight critic at all, but this spin surrounding Insight mpg is not productive.
  10. JSH
    JSH Senior Member
    2,605
    140
    PDX
    In this thread I have talked about CVT transaxles and compared the Honda Insight to the Honda Civic Hybrid. I suggest you actually read the thread before commenting.
    The Insight will be compared to the Prius whether you like it or not.
    Now for people that are interested: "Comparison Test: 2010 Honda Insight vs 2009 Toyota Prius" Strategies for Smart Car Buyers . Edmunds drove the two vehicles together over a 197 mile test loop.
    2010 Insight = 51.5 mpg
    2009 Prius = 54.4 mpg
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    Jhinton --
    And I suggest you own up to your previous posts, even if they are not in this specific thread.
    I am all for mpg comparisons -- the apple to apple kind. Highway, city, cold weather, and short trips. The edmund's review is a start, but comparing the future Honda Insight of uncertain msrp to the soon to be replaced Toyota Prius is silly on it's face. At least the editors were clear in what they were grading, even if I personally thought the criteria and marks were useless. E.g., "Simply starting the car and understanding the transmission lever takes re-learning." Geez. They make it sound like people are being asked to eat their oatmeal with chopsticks.
  12. JSH
    JSH Senior Member
    2,605
    140
    PDX
    If you have an issue with one of my posts I recommend you respond in the same thread as the post that is so offending.
    I'm concerned with what mileage I will actually get from the vehicle in the real world not a EPA dyno test. Yes, the EPA tests are apples to apples but that doesn't mean that they represent the reality of driving on actual roads.
    My 2003 VW consistently returns better than EPA ratings of (35/39/45)
    My 2005 Prius only returns the EPA rating (48/46/45)
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    Uh huh. Information you intend to glean from the Honda course, or the Edmund's course ? The dyno test is not inherently better or worse than a road test; it just has it's own set of driving conditions and drivers -- just like a road test.
    I suspect that the mpg ratios between two vehicles on the EPA testing and other head to head road tests vary less than how you use each of your vehicles.
  14. Tideland Prius
    16,680
    ok guys... settle down.
  15. edmcohen
    edmcohen Member
    133
    25
    Newark DE
    If you Google "CVT transmissions" you will get various sources, and in particular, a nice Wikipedia article. These transmissions are glorified V-belts, made of exotic materials. Special ATF, available only from the manufacturer, is required for warranty. I have already heard a horror story of exorbitant prices charged for the replacement transmission fluid. We know that the new Insight is distressingly noisy under acceleration. All this increases the attractiveness to me of the absence of a friction clutch or a mechanical gear change in the Prius.
  16. MSantos
    MSantos EcoAccelerometry
    589
    260
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    There is a fair amount of mis-information and fear mongering regarding CVT transmissions. I am not going to pretend to know much about Non-Honda CVT's since I frankly do not look at them much (my emphasis is strictly Toyota and Honda vehicles) .
    The eCVT used by Toyota is relatively bullet proof so we won't dwell on that. The CVT's produced by Honda in the other hand had quite an evolution over the last 10 years and despite the scorn that it often gets in some circles, they can be very reliable especially when the C-ATF fluid is changed regularly.
    Yes, the CVTs manufactured by Honda do use somewhat exotic materials and production processes. In fact Honda produces much of the CVT components in-house since quality control is critical. Yes, the formulation of the C-ATF fluid is also unique and very specific.
    But it being costly? Nope. Sorry, I speak from experience on this one and its not much different from the cost to change the ATF fluid on a regular AT equipped vehicle.
    Contrary to the seriously misinformed reports from the previewing media, the Insight's CVT is not the source of the noise under WOT. Not in the Insight and definitely not on the HCH-2 either. The engine is the source of the noise, especially when they pin it at 6000+ RPM in the senseless and totally wasteful tests they run. :(
    Cheers;
    MSantos
  17. Per
    Per New Member
    232
    San Antonio
    Well, I just had the transmission oil changed along with other service items at my Honda dealer, and the cost for changing the transmission oil including labor, was $100.00. I don't call that exorbitant!
  18. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    What does "being made in exotic materials" have to do with longevity ? Even V-belts last quite a long time in modern automobiles. Please cite your sources, besides Wikipedia.
  19. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Did they redesign it yet? :D
    I think that's what most people are waiting for. In the meantime, for Honda lovers, the Civic Hybrid is looking pretty good.
  20. Tideland Prius
    16,680
    Not in Canada. They've raised the HCH's price quite a bit. It was $25,800 back in 2006 (dropped from $28,500 in 2005) then after a few quick price jumps, it has slowly risen and is now $27,350. An Insight EX (equiv. to your EX-L) is $27,500. The base Prius is $27,500. Hmm... $150 more gets me a Prius.
