Price quotes on transaxle fluid change
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by F8L, Feb 21, 2011.
  1. BigDeal
    BigDeal Junior Member
    95
    Arizona
    2021 Prius
    Think I will call a Toyota dealer and see what kind of answer I get from them.
  2. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    Transmission warranty for life of car? Its 100k right?
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    Trans is covered by 5/60K powertrain warranty, sometimes 10/150K for CARB warranty in CARB states.
  4. BigDeal
    95
    Arizona
    2021 Prius
    You're right, I shouldn't have said "for the life of the car", but for the warranty period duration.
    And not doing the trans fluid change might shorten the life of your car it sounds like?
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yes. But, transmission life on average is probably over 200k miles without a change. OTOH, there have been some tranmission failures reported here at lower mileage and as far as I know none of them were in transmissions that had regular oil changes.
    It's a case of how long you plan to keep the car and how lucky you feel.
    People who have done thir first change and had an oil analysis at 30k miles have usually found oil that has thinned below the viscosity spec. I can't get too excited about that because Toyota probably considered that during transmission design and oil choice.
    A bigger problem is that the GenIII has no filter and contaminants build up in the oil. Things typically look bad at 30k miles, after that initial change 60k miles seems acceptable. That's because the transmission sheds more material while it is getting worn in. I expect to change mine at 10k miles, 30k then 60k intervals if the 30k looks good enough.
