Prices on service for fluid changes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius408, Aug 15, 2014.
  1. Prius408
    Prius408 Junior Member
    34
    San Jose, CA
    Hello
    So I found a mechanic that is certified to work on my prius. He quoted me the following for the services below. Does that sound about right? I think the charge for a coolant change is pretty expensive. This is not the dealer.
    1. Coolant change, $100
    2. Interverter coolant change, $100
    3. Transmission fluid change, $150
    4. Belt $100
    5. Spark plugs $140
    6. TB clean, I don't even know what this is $50
    Total $640
  2. Patrick Wong
    18,210
    6,526
    The engine coolant change is not easy if it is done correctly with the coolant heat recovery system drained. Further, the correct coolant should be used which is Toyota Super Long Life Coolant and this will cost ~$22 per US gallon, premixed 50% with distilled water. Three gallons will be needed for the engine and inverter coolant loops.
    The transmission fluid used must be Toyota ATF WS which costs ~$9 per US quart, four quarts are needed.
    The iridium spark plugs must be the correct NGK or Denso plugs, which will cost ~$40 or more if bought locally.
    The throttle body needs to be periodically cleaned to avoid engine no-start issues.
    You might try Luscious Garage in San Francisco.
    WilDavis likes this.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Those prices sound pretty reasonable to me.
    Keep in mind that shop labor rates range from $100-$150/hr and each of the services that you listed, will require 1/2 to 3/4hr.
  4. Prius408
    34
    San Jose, CA
    Ok thanks guys. Just wanted a second opinion since this is my first Prius. Funny thing is I have a Mercedes and to change the coolant is actually cheaper on it.
  5. JC91006
    16,937
    8,647
    I find it strange the transaxle fluid change is $150, while the coolant change is $100. The coolant is more expensive and takes more time.
    Silver Pine Mica likes this.
  6. cnschult
    cnschult Active Member
    772
    97
    Michigan
    That should tell you everything you need to know. That mechanic, while perhaps honest and good-intentioned, just doesn't know enough about the Prius to do it.
    pretty much anything involved with programming keys, A/C service, coolant fluid and brake fluid change needs to be done at a toyota dealership. I hate spending more money as much as the next guy, but its critical you understand what truly has to be done at a dealership or shop like Luscious Garage that specializes in the Prius and services them regularly.
  7. Patrick Wong
    18,210
    6,526
    The mechanic is probably planning to go to Pep Boys or the equivalent and buy the cheapest coolant and Dexron ATF he can find.
  8. The Critic
    3,193
    2,333
    CA
    That's quite the assumption that you're making.
  9. Patrick Wong
    18,210
    6,526
    Well, we'll see whether the OP reports some strange green or yellowish fluid in the coolant reservoirs after service.
  10. The Critic
    3,193
    2,333
    CA
    Or the OP could just bring the car to my garage and I can do the services properly....and I'll even do them for a lot less. ;)
  11. Mike500
    Mike500 Senior Member
    2,593
    767
    Here again is good link on what this service involves from the Art's Automotive web site.
    Prius 30k Service
  12. Prius408
    34
    San Jose, CA
    This mechanic is a Toyota/Lexus/Scion only shop and uses all Toyota parts. I seen his shop and it is very clean and I do see nothing but Toyota parts on the shelves. He said he used to work for Toyota. So hopefully he does know what he's doing. I'm going in tomorrow. Thanks for all the comments. This forum has been great so far.
  13. Former Member 68813
    3,524
    983
    US
    Ask him what fluids he is going to use.
  14. Patrick Wong
    18,210
    6,526
    That profile is a good start. A competent independent who is Toyota-trained and uses Toyota parts (and fluids) is to be encouraged.
  15. exstudent
    exstudent Senior Member
    2,214
    906
    Torrance, CA
    San Jo to Berkeley (Art's Automotive 510-540-7093) and San Fran (Luscious Garage 415-875-9030) is reasonably close. Maybe give those two shops a call for price comparison to see if you are truly over/under charged. If you do call, please post the pricing to give others an idea what the market rates are (for the Bay Area at least).
    $100 for a belt change seems like highway robbery, esp if you get all those other services done. I did the belt on my own Prius, and it took me about 35 minutes, and I'm just a recreational mechanic. I bet this independent person can do it under a maximum of 10 minutes, with his eyes closed.
    #15 exstudent, Aug 18, 2014
  16. The Critic
    3,193
    2,333
    CA
    My labor time guide says 0.5 hour for the belt replacement. The belt stickers for $19, and the shop will probably want a bit more mark-up that just msrp. Labor rates range from $100-$150/hr....so the $100 number isn't too far off.
  17. Fifine
    Fifine Member
    114
    23
    So Cal
    Just had my 2008 serviced and recall-work done at a Toyota dealership (in W. LA). The service rep gave me a deal: $60 to install the serpentine belt I brought in. He said the usual charge was $120 (for 1 hour labor).
    For convenience, since I was already there, I opted for the inverter service = $159.
    An independent shop had quoted me $97 for same.
    Transmission: $189 at dealer; $165 at indie shop
    Belt: $95 at indie shop
    Spark plugs + tune up: $229 at dealer; $160 spark pl. only at indie shop
    Alignment: $70 w/ coupon at dealer; $98 at indie shop
    Dealerships have coupons for 10-15% off service work that may make their prices a bit more competitive. Just ask.
    Since I haven't found a local mechanic whom I can trust to do the more Prius-specific work, I'm willing to pay a bit extra for peace of mind.
    (... though it may be a HUGE leap to presume that dealership techs know their schtuff!)
  18. ETC(SS)
    7,571
    Actually those rates aren't out of line for SO-CAL and if the wrench is honest and fairly competent then I'd recommend going with it.
    You're looking at about 450 bucks in labor but you're also looking at some significant work....especially if the tech really does clean the throttle body instead of just spraying a $9 bottle of Tee-Bee-Cleen into your air intake---ask the tech how they do it.
    He/she has a shop to run, and there's no telling what it takes to stay in compliance with licensing safety and environmental regulations to say nothing of the taxes, fees, bribes, etc.
    An 05 probably needs the work done.
    Good Luck!
  19. Prius408
    34
    San Jose, CA
    Thanks, I didn't even think about the TB clean procedure. I'll ask them for sure...
