PriiDash(TM): Enhanced Instrument Panel / Data Logger - Now Open Sourced!
Discussion in 'PriiDash (TM)' started by 2009Prius, Jun 26, 2011.
  1. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    STNterm is a terminal program that you can download (free) onto your computer. You can then alter the speed that your elm327 communicates at. The the speed when supplied is set at 38400, you need it to run at 2m if possible, but the cheap clones only seem to run 500,000 max. I find this is fast enough to run Priidash.
    [email protected] likes this.
  2. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    I cant get this to work. I got cygwin installed, i click on xwin, and it is just a black blank window. nothing happens.
  3. Britprius
    5,194
    1,924
    Have you tried the windows version.
  4. scotman27
    735
    82
    PA
    2001 Prius
    i tried downloading it. i extracted it to my desktop. so i go to desktop/ priidash/priidash2/bin/priidsah2.exe, i click on it a window pops up. a second later the error tone and a window that says.
    " this application has failed to start because cygwin1.dll was not found. reinstalling the application may fix this problem".
  5. scotman27
    735
    82
    PA
    2001 Prius
    there was a post to supposedly take me to the windows version, but its the same version i already put on my computer. i am running win xp sp3
  6. Britprius
    5,194
    1,924
    I'll see if I can dig out what version I am running and let you know. I am running XP with service pack 3.
    John (Britprius)
  7. scotman27
    735
    82
    PA
    2001 Prius
    hopefully its just a broken link. that would be nice to not have to mess with cygwin
  8. Britprius
    5,194
    1,924
    Try this:- Unzip - double click Priidash folder - double click bin folder - double click Priidash VC2010.
    scotman27 likes this.
  9. scotman27
    735
    82
    PA
    2001 Prius
    ok, it comes up now. but when i try to run simulation it comes up with the fatal error/ send report screen. will i be able to use my autoenginuity connector with this?
  10. Britprius
    5,194
    1,924
    Yes you should. Have you designated a drive for the log files.
  11. scotman27
    735
    82
    PA
    2001 Prius
    no i didnt.
  12. scotman27
    735
    82
    PA
    2001 Prius
    In just tried setting it to my C:\ drive and it goes righ back to F:\ drive
  13. Britprius
    5,194
    1,924
    You must set up a partition designated F or use a memory card or external drive designated F
  14. scotman27
    735
    82
    PA
    2001 Prius
    ill grab one i have laying around
  15. scotman27
    735
    82
    PA
    2001 Prius
    will my autoenginuity connector work
  16. Britprius
    5,194
    1,924
    Keep us informed .
  17. Britprius
    5,194
    1,924
    I have not tried one myself but I do not see why not.
  18. scotman27
    735
    82
    PA
    2001 Prius
    ok. now I put my flash drive in and tried to change it to E:/ 01priusobdlog and E:/01priuscsvlog and it does the same thing
  19. Britprius
    5,194
    1,924
    It must be set to F:/
  20. scotman27
    735
    82
    PA
    2001 Prius
    ok ill have to see if i can find a program to do that
