PriiDash(TM): Enhanced Instrument Panel / Data Logger - Now Open Sourced!
Discussion in 'PriiDash (TM)' started by 2009Prius, Jun 26, 2011.
  1. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    I cant seem to. the connector is recognized by autoenginuity, but it does not get picked up by my laptops, system
  2. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    Thats a great pity, can you obtain a cheap ELM327 of Ebay I think over there in the US it will be $10-$15.
  3. Britprius
    5,194
    1,924
    Frustrating your so close.
    John (Britprius)
  4. scotman27
    735
    82
    PA
    2001 Prius
    Yeah i agree. Iam thinking of picking up one of those Xhorse/techstream connectors. I heard they do everything techstream does but without the registration/subscription pert of it.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I don't think Techstream or AutoEnginuity connectors could work. You need an ELM compatible OBD-USB device. OBDLink SX is a relatively low cost option if you choose to stay away from the "clones".
  6. scotman27
    735
    82
    PA
    2001 Prius
    I will look into those. will those also work for this new techstream software?
  7. 2009Prius
    2,705
    512
    63
    No. Techstream needs a different kind of connector.
  8. scotman27
    735
    82
    PA
    2001 Prius
    Ok. does the obdlink SX allow me to get into the hybrid system of my car as well as abs and all that?
  9. 2009Prius
    2,705
    512
    63
    If you want to be able to talk to all the ECUs and perform dealer level services then just go with Techstream - that's the tool the dealers use. PriiDash only display and log some drive data, it does not do brake bleeding or zero point calibration for example.
  10. scotman27
    735
    82
    PA
    2001 Prius
    thats probably what im going to do. im going to try one of those chinese xhorse techstream programs as I heard they work exactly like techstream
  11. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    The mini vci devices from the East use a FTDI USB2.0 interface to a NXP Cortex(x) MCU driving a HS CAN and MS CAN Ports on the DLC3. The LIN Port is unpopulated on the one I have.
    The software supplied consists of the FTDI VCP Drivers and an unlocked version of Techstream but not all modules may be unlocked.
    The brake bleed funcion is enabled on the on I bought on the little testing I did on the wekend.
    I did use it to clear the Ucodes that were generated by my experiments on the CAN Bus and the misfire codes that were stored. It showed 3 misfires possibly over the past 123000 mi which I cleared also.
    dave77 likes this.
  12. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi ccdisce,
    The Mini VCI that I bought 2 yrs ago does support K-Line. It seems that there has been a lot of cheap ones flooding the market recently.
    Disassembly of the fake mini VCI cable
    I suspect the K-Line was removed due to cost and also newer cars (starting from 2004) are not using them anymore.Your Gen2 has a mixture of K-Line and CAN so some functions will not work.
    FYI, my firmware ver. is 2.0.1 and the recent one is 1.4.1.
    Vincent
    dave77 likes this.
  13. ccdisce
    259
    187
    Stone Mtn GA USA
    Vincent,
    I did some more poking around on the one I bought and this is what I see:
    a. A ISO 1050 CAN PHY for the CAN Bus which is terminated in 120 Ohms (a no no)
    b. A Siliconix Si9241AEY K-Line Transceiver terminated in 510 Ohms
    c. Pads for a second transceiver for the L-Line
    Do you know if 1. the Gen2 use KWP2000 protocol with a CAN PHY
    2. if so the speed 1M maybe
    3. How is the BEAN Bus driven? via the Gatway ECU maybe?
    Winston.
    dave77 likes this.
  14. vincent1449p
    894
    332
    Singapore
    1. Nope, it uses the K-Line directly.
    2. 9600 baud.
    3. Pls refer to this link on BEAN Bus.
    Vincent
  15. ccdisce
    259
    187
    Stone Mtn GA USA
    Thanks for the link.
    Can the K-Line be used to talk to the devices on the BEAN Bus?
  16. vincent1449p
    894
    332
    Singapore
    Yes, K-Line (SIL on the DLC3) is not only connected to the devices on the BEAN Bus, it is also connected to many other CAN devices (for diagnostic purposes only) except HV ECU, ECM & Bty ECU.
    Vincent
  17. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    Uh wow. I could never do this in my car. I get distracted enough with all the buttons and different displays! I can't imagine having this thing. I'd probably be in a car accident before I backed out of my parking space!
    Great work though. Neat to know there is stuff like this out there.
  18. ccdisce
    259
    187
    Stone Mtn GA USA
    Thanks Vincent.
  19. 2009Prius
    2,705
    512
    63
    2013-05 new release
    This new version adds capability to read generic DTCs. The Gauge Window is changed to wide format. Sorry I haven't done much with the Lite version yet.
    connectorxp likes this.
  20. connectorxp
    connectorxp Avid mountaineer and rock climber
    25
    Bucharest, Romania
    Nice job, I managed to get hold of my netbook and installed Priidash, I downloaded an older version for Windows as the latest one refuses to work, with that Linux type runtime installed on it according to the instructions that came with Priidash.
    Some of the parameters aren't working, I'm still tweaking the connection as it's a Bluetooth chinese ELM clone.
    Love the way you managed that tablet in between the steering column and the dash, I'm thinking a way how to mount the netbook from the ceeling, near the light or get hold on a used 2003-2006 MFD and fiddle with it and a used PC motherboard.
