PriiDash & Wifi?
Discussion in 'PriiDash (TM)' started by KhaPhoRa, Feb 23, 2013.
  1. KhaPhoRa
    KhaPhoRa Member
    168
    37
    I have an ELM327 wifi (for ios device usage) on the way and was wondering if it will work with priidash or will I need a separate USB obd2 scanner? My netbook has wifi, so that's not my concern, just whether or not priidash can tap into the scanner via wifi (either natively or perhaps though a wifi USB stick). Thank you for you time.
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Does the ELM327 WiFi present itself as a virtual COM port (like the USB version does)? If so then is the baud rate at least 500K? If the answer is "yes" to both questions then it should be able to work with PriiDash. Thanks for the interest and please keep us updated how it works out for you. Good luck!
