Prime 2023 12V battery integrity on EV
Discussion in 'Gen 5 Prius Technical Discussion' started by hb06, Apr 13, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    So, AGM batteries are not immortal after all. ;)
  2. Gokhan
    6,714
    2,672
    Paramount CA
    Reading about it, the main advantage of AGM batteries seems to be lower self-drain, ~ 2% per month vs. ~ 5% per month for a calcium battery.
    AGM batteries seem to have shorter longevity vs. properly maintained flooded-cell batteries.
    Does the self-drain advantage matter given that Gen 4 and Gen 5 Priuses have a high standby drain? Probably not. That would explain why Toyota might have opted for a flooded-cell battery, especially given the higher cost of AGM.
  3. rhodes2020
    rhodes2020 Junior Member
    United States PST Southern California
    Thanks for this. I am newxto Prime, but had a few Prius. What is READY mode? I have EV, HV, ECO, sport, and a hundred menus to go! But I have never ever seen anything called READY. Can you please share how to set and know that a 2023/2024 Prius Prime is in READY mode? I have a 2024, bought in March 2024, with 9,000 miles. Today, March 4, 2025 it is being towed to dealer for a dead battery.
    I do hope I get a battery and not just a charge and hand it back to me. My driving habits are all electric around town to get grocieries and an occasional road trip.
  4. mva
    mva Active Member
    177
    105
    B.C. Canada
    2024 Prius Prime
    SE
    When you press the START button and brake pedal at the same time the car goes into READY mode. It charges the 12 volt battery in this mode and also any time the car is plugged in.
    If you press the start button once the car goes into ACC mode which can quickly deplete the 12 volt battery.
  5. Hammersmith
    Hammersmith Senior Member
    2,487
    2,546
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The car has four power states. It's actually the same as your old Prius. That also had a READY mode that you used every time you drove the car.
    1. OFF - self explanatory
    - press power button once without pressing brake
    2. ACCESSORY - some electronic components are on - radio, etc.
    - press power button again without pressing brake
    3. POWER ON - all electronic components are on
    (back to OFF)
    (from OFF)
    - press power button while pressing brake pedal
    4. READY - car is fully powered up and ready to drive
    Here was your old Prius display. See the READY in the lower left corner?[​IMG]
    And here's your gen 5 display with the READY on the left side in green:
    #85 Hammersmith, Mar 4, 2025
  6. Mendel Leisk
    42,349
    Ready is akin to turning the key on an old car as far as it’ll go, activating the starter motor and the engine’s running. The Prius is similar except once engine’s partially warmed it’ll start shutting down periodically and so on.
  7. Gokhan
    6,714
    2,672
    Paramount CA
    It is less complicated than the explanations above.
    READY
    = hybrid system on
    (as indicated explicitly on the display)
    The car cannot be shifted to gear or driven unless it is in the READY mode (= the hybrid system is on).
  8. flim
    flim Active Member
    265
    191
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    My battery was dead after almost a year last April 30 2024. The dealer tested the battery, deemed it defective and replaced it.
    #88 flim, Mar 5, 2025
