Prime "Auto-Blending" Mode could yield > 22 miles EV
Discussion in 'Prime Fuel Economy & EV Range' started by inferno, Jul 22, 2016.
  1. inferno
    inferno Senior Member
    1,072
    405
    Here's why I believe this.
    1. Prius Plugin is 95 mpge while Prime is 120 mpge which is a 20% increase in efficiency.
    2. The battery pack doubled, so in essence we should see 26.4 miles EV ideally.
    3. But I believe the EPA tests have changed and I think the EPA will definitely guarantee the Prime to be 22 Miles of Actual EV even though I'm sure drivers would get 25 and beyond.
    4. If the Prius Plugin took the current EPA test (sans acceleration that caused it to be rated 6 EV miles) - I'm sure the Plugin would rate 9 miles EV or lower.
    5. Auto mode on the Prime will use the battery pack when needed, and I believe hard acceleration will use the gas engine.
    6. People could milk 14-15 miles of EV with the plugin, a 21% increase at worst.
    7. According to all the above, we might be able to see a 21% increase over 26.4 miles EV if drivers drive it to "milk" EV miles, in other words we should be able to see Prime Drivers do 32 miles EV easily!
    Though I won't buy the 4 seater version I'm hoping that there will be enough buyers for Toyota not to cancel this and improve it.
    It will be interesting when Hyundai releases their 5 seater plugin.
    Perhaps in 10 years we'd see a 50 miles EV easily on the road. I'm sure the refreshed Volt can go 55 miles EV and I'm also sure that some Volt enthusiasts can "milk" their EV miles to 55-60 miles EV now.
    But I believe Toyota has built their vehicles to be more on the pessimistic side and therefore allow others to better hyper mile and milk the EV...
    Too much milk for you all?
    briank, Tideland Prius and KrPtNk like this.
    52,750
    yes.:) do you mean total ev miles, in a drive that also uses the engine?
  3. inferno
    1,072
    405
    Yes. But the mode should only engage the engine when it's necessary. My guess is hard acceleration. Like the current ev in a regular prius. My guess is maybe that bar is expanded and therefore can allow u to accelerate a little harder and faster. But if u stay below it... Then it should be all good
    52,750
    then it would all depend on what kind of a drive you do, unless it starts in hv warm up mode.
  5. Tideland Prius
    16,665
    Don't forget the improved efficiency of the electric motor and inverter that came with the Gen 4. I, too, think that Toyota is being conservative by simply saying "oh we doubled the pack therefore the distance has doubled". In Japan's JC08, the distance has slightly more than doubled. I think the PiP was rated at 26.8km and the new PHV will be rated at "more than 60km". I think it'll be closer to 25 miles (or even higher) in the real world.
    Danny, inferno and KrPtNk like this.
  6. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I can net 26-28 miles regular driving in mild weather and hypermile 31 EV miles in my Energi with a smaller 7.6kw battery so I think Prime should be able to get 30-35 miles under the right conditions. (y)
  7. bisco
    52,750
    agreed. under the 'right conditions', i can get 16.
  8. Trollbait
    12,799
    Just to get a couple points from the OP addressed first.
    Hyundai already has a 5 seater Sonata PHEV out with around 27 miles EV range. The planned Ioniq PHEV should have at least that range, possibly just over 30 miles. It will be cheaper than the Sonata PHEV, but will be smaller. Arriving after the BEV and hybrid models, we'll have some wait before we get all the details.
    The EPA test cycles have not changed; they changed and clarified some rules. These rules covered things like the condition of the test car, like how much wear can the tires have, and which results can be used for determining the average number for the window sticker, and which could be thrown out. The one having the most impact in making 2016 results lower than previous years is upping the coast down speed from 50mph to 70mph. The results of the coast down test determine the load resistance for dynanometer during the actual tests.
    For the OPs main subject, if the Prime is driven in EV Auto in such a manner as to not have the ICE engage at all, I agree that it should exceed the official 22 mile range. It will not go farther than driving the car the exact same way while it is in EV mode. EV Auto is the blended mode. The thresholds at which the ICE comes one will be higher than the PiPs; likely close to those of the Energi's. When driven without hypermiling, it will allow the grid charge to cover more miles than the pure EV mode by sparing battery depletion from heavy acceleration and high speeds with ICE use. It doesn't have more grid charge in EV auto mode than in EV mode though. So the car has the same amount of energy for EV miles when driven at speeds and accelerations to keep the ICE off.
    Another way to look at it is that EV Auto will yield more miles covered by the grid charge, but so will manually switching between EV and hybrid modes for high speeds and times of high load.
  9. Tideland Prius
    16,665
    So the question will be, whether EV Auto can replace the manual switching of EV/HV modes in the PiP, especially now that the motors can handle higher ground speed before the engine has to come on to spin. In the Gen 4, the car can already accelerate in EV mode more easily. So switching to HV mode may not gain anything over EV Auto.
  10. Trollbait
    12,799
    Yes. I think the only time HV mode will be of gain is on trips that exceed EV Auto's "EV" range, and you want to save grid charge for lower speed roads near the end of it. It also comes down to when the EV Auto uses the ICE, and we have to wait for those details.
    I'm guessing it will behave around the same as the Energis because of the similar pack sizes, but Toyota might decide to be more conservative, and have the ICE thresholds closer to the PiP. With the reviewers not being allowed to try EV auto recently, I don't think these settings have been fixed yet. Market specific like the PiP is also possible.
  11. bisco
    52,750
    might be better for the 'common man' that toyota is targeting, who just wants to get in and drive.
    KrPtNk likes this.
  12. Tideland Prius
    16,665
    Ahh right. Yeah that would make sense.
    The Energis have a reasonably high threshold from what I remembered (I drove the Fusion Energi if it makes a difference). In that case, EV Auto will pretty much stay in EV mode except when climbing steeper local hills. It might also function differently on the highway too. Even with the higher 135km/h EV mode, I suspect that's for descents or where the road is on a slight decline for European drivers. In the U.S., my guess is that after 60mph, it'll probably function closer to the Gen 4 since it could be more efficient to use the gasoline engine at those speeds (and save the battery for later) than to slowly drain the battery. In that case, the driver has the choice to go into EV Drive Mode to lock out the engine if they intend to charge immediately after getting off the highway.
  13. drash
    drash Senior Member
    2,595
    1,337
    Upstate NY
    XLE AWD-e
    For determining when Prime's ICE will fire up in EV Auto, we know the battery is now capable of producing 68 kW of power but the Prime MG2 was downsized to 53 kW. Based on a trip using blended mode on a 65 mph freeway going home yesterday, the PiP battery showed an average use of 48.4 amps at the average battery voltage of 202 volts. So the PiP was using about 9.8 kW of battery that is rated at 38 kW. Using the same 26% for the Prime battery output of 68 kW we get about 17.5 kW before the ICE kicks on. Probably have to narrow that down a bit by the 12% lower power difference in Prime's MG2 we still get over 15 kW of power being used before the ICE kicks on. But since it takes quite a bit more power at higher speeds even though the Prime has about 5 kW more to use, I'll offer a WAG that the speed cutoff is gonna be in the 70 mph +/- 2 mph range using EV Auto.
  14. bisco
    52,750
    that was too much milk.:unsure:
    inferno likes this.
  15. drash
    drash Senior Member
    2,595
    1,337
    Upstate NY
    XLE AWD-e
    And here I thought I was making it easier by rounding....a lot.
    :D
    inferno and bisco like this.
  16. DavidA
    2,349
    1,825
    Chicago western burbs
    I'd bet you were real good at statistics in college!
  17. DavidA
    2,349
    1,825
    I would really really hope that in less than ten years that Toyota could have a PHEV that does much more than that! If not, then that would be pathetic.
    Actually, I suspect that in 6 months we'll have a thread title of "Who got more than 50 miles pure EV out of their Prime." Proper mode selection for flats, hills, speed, etc. might become the new hypermiler challenge for this model.
    briank, drash and Tideland Prius like this.
  18. Tideland Prius
    16,665
    Another possibility is if the nav has terrain built into it and EV Auto can use it (if you're under Route Guidance) to decide when to drain the battery in order to leave room for recovery on the downhill portions.
    briank and KrPtNk like this.
  19. drash
    drash Senior Member
    2,595
    1,337
    Upstate NY
    XLE AWD-e
    As usual, Toyota will be surprised on how much PriusChatters push the envelope of the Prime. And they will adjust their engineering based on what we on PriusChat have discovered, utilize on a daily basis, and what parts get more heavily used than others. For instance, although they thought they made the current PiP battery tough, Toyota didn't realize we would plug it in so much and (some of us) go incredible distances on EV, so they made the Prime battery tougher. They also made the battery tougher without the expense of liquid cooling.
    This will be quite the challenge. Look at all the variables we get to utilize: with or without using the heat pump, preconditioning, EV Auto vs EV, etc.. Oh yeah I can hardly wait.
    Unsupervised!
  20. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    I suspect the old Prius PHEV's 95 MPGe number is dinged by the gas engine starting up during the EV range testing. If the engine hadn't started the MPGe number would have been much higher -- maybe 105-115. So, the new Prime won't be hugely more EV efficient.
    Since EPA is actually 22 I assume you mean with careful driving in good conditions.
    My guess is around 10 miles. The gas engine is used but only 0.022 gallons of gas were burned.
    The Volt is EPA 53 miles and in good conditions drivers are getting over 60 with careful driving. A few have reported getting over 70 on occasion. Basically, an EV can often be reasonably hyper miled an extra 30% beyond the EPA range. Careful drivers on next year's Honda 40+ mile EPA Clarity PHEV will probably get over 50-55 miles.
    That's not a relevant spec because the Prime has dual motor mode due to its added one-way clutch. It can also use the 23 kW MG1 during EV driving so combining the motors allows it to max-out the peak battery output of 68 kW for a short burst.
