Prime "bounces" back after applying parking brakes and letting go of brake pedal?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Darien Day, Dec 23, 2021.
  1. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    So new '22 PP Limited. I park on a driveway with an incline. When I park and press the "P" button then release the brake pedal, the car will kind of roll back a tiny bit then bounce back after reaching the end of that tiny backwards roll.
    None of my previous cars ever exhibited this behavior. Has anyone else experienced this? Is it normal or should I get this looked at?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    #2 JimboPalmer, Dec 23, 2021
    Darien Day likes this.
  3. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    Ok, I get the first sentence, but do not follow what you're saying in the last two sentences.
    Pulse07 and Mendel Leisk like this.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    P drives a pawl into the gears so they can't roll, but it can take some rolling to settle into a low spot in the gears. Ideally I linked a picture in the previous post.
  5. Elektroingenieur
    2,515
    3,258
    Three Touring
    If you set the parking brake first, as Toyota instructs (see “Parking the vehicle,” Owner’s Manual (PDF), page 315), you also won’t notice this behavior, which as @JimboPalmer kindly notes, is normal.
    That’s a good habit to get into, anyway, just in case there’s ever a malfunction in the system that engages the parking pawl. There’s supposed to be a warning message on the multi-information display if that happens, but you might not notice it before releasing the brake pedal, which could allow the car to roll away.
  6. Darien Day
    Darien Day Member
    123
    35
    SW USA
    2022 Prius Prime
    I'm an idiot. It's been at least five years since I've driven a car with a "parking brake" either the hand operated lever type or the foot pedal type. I assumed that pressing the "P" button would automatically engage the parking brake (In my C-HR, just shifting to Park would automatically engage the parking brake).
    I didn't even notice the foot pedal parking brake in this Prius until I read the thread Jimbo linked to.
    Pdog808 and Mendel Leisk like this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Ideally, a simple proof read of your post BEFORE hitting the "Post Reply" button would have been nice too.
  8. Storm88000
    Storm88000 Active Member
    321
    145
    LHValley, PA
    2020 Prius Prime
    Sort of related. Anyone notice when you go into reverse quickly, and then hit the brake and stop short before shifting back into drive to go forward (like making a quick K turn with vehicles in the street waiting) you hear a minor clunk from the rear? Mine has always done this since I've had it
  9. sam spade 2
    7,035
    2,788
    2017 Prius c
    Not under those specific circumstances.
    But my C has developed a mild "clunk, clunk, clunk" almost every time that I come to a stop and the engine shuts off.
    It sounds like an exhaust pipe hitting on the frame or on a shield.
    Gonna have it inspected at the next service......unless it gets louder.
    Storm88000 likes this.
  10. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    One thing I've heard the Car Care Nut (YouTube Toyota Master Tech) mention when parking is to shift into neutral, apply the parking brake, release the normal brake pedal, allow the car to settle, then shift it in park. He mentioned the parking pawl is fairly pricy to replace, and following this method places less stress on it.
  11. ChapmanF
    15,514
    That's nearly the advice you find on page 321 of your owner's manual, except for a slight change in the order. Toyota would like you to keep your foot on the normal brake pedal throughout, and only slowly release that after both the parking brake and the parking pawl have been set. That's the typical recommended order.
    The parking pawl would indeed be pricey to replace, as you have to disassemble the transmission to get to it.
    That said, I have never heard of parking pawl breakage being a common problem, no matter what order of steps people use when parking. It would probably require a force more like being rear-ended while parked for breakage of the pawl to be a concern.
  12. Storm88000
    321
    145
    LHValley, PA
    2020 Prius Prime
    ^ Wow. So Toyota is saying to press the parking brake with your left foot down before actually shifting to Park? Or do the older models have a hand brake. I always prefer the hand brake, I have one in my '20 MX-5 (and Mazda continues to use them even in the coming 2022 model) - but no car is ever perfect so I deal with the dopey left foot e-brake.
  13. ChapmanF
    15,514
    For the math-inclined, what's going is is there is a "partial order" of the steps, but in order to typeset a list of steps in a manual, they have to pick a "total order". There's really no particular significance to whether you apply the parking brake first or shift to P first (or even just power the car off, which shifts to P for you), or even do both of those at the same time, as long as both of those steps precede taking your right foot off the normal brake pedal; that's how you can minimize any rolling or bouncing of the car.
