Prime cable
Discussion in 'Prime Plug-in Charging' started by Ferrarilover, Mar 21, 2017.
  1. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    Hi. How long is cable for the Prime? Assume it's the same length in the uk?
    iPhone ?
    52,662
    the pip cable was 25' i believe, prime is probably the same.
  3. CharlesH
    2,798
    1,166
    Roseville, CA
    My understanding from discussions in the PiP forum was that in the UK, charging stations do not have cables with the J1772 plug; you have to provide your own cable between the car and the charging station. In the US, charging stations, whether personal EVSEs or public charging stations, provide the cable with the J1772 plug.
    52,662
    are you saying the prime in the u/k doesn't come with an evse?
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    It comes with an EVSE and cord, but from what I heard from British owners on the PiP forum years ago, public charging stations do not have a cord. You have to plug your own cord into the charging station, which has a special charging receptacle different from the standard British home power receptacle.
  6. bisco
    52,662
    which means you need an adapter?
  7. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    The cable in this photo looks like a J1772 on booth ends?
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    I really don't know definitively, but I suspect that what you need to use a public charging station has the J1772 on one end, and the special charging plug on the other. I seem to vaguely recall that the owners were complaining that the EVSE came with an attached cable (like the ones in North America), and they had to buy their own charging cable if they wanted to use public charging stations. But this was about five years ago, when the PiP first came out.
    Edit: the picture in the preceding post suggests that the "special charging receptacle" on the charging station is the J1772. Who knows what is on the car end?
    British EV owners, help!
  9. bisco
    52,662
  10. Ferrarilover
    185
    168
    Manchester, UK
    Most that I have seen are tethered but some require a double ended cable.
    iPhone ?
  11. bisco
    52,662
    interesting, thanks.
  12. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
  13. Samprocat
    491
    297
    Lincoln, NE
    priuscatprimeguy and CharlesH like this.
  14. Ferrarilover
    185
    168
    Manchester, UK
    You get two cables in the uk. One for a 3 point socket and one with for plugging to a fast charger.
    iPhone ?
    priuscatprimeguy and Samprocat like this.
