Prime charging
Discussion in 'Prime Plug-in Charging' started by David Beale, Aug 11, 2016.
  1. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Probably not in there currently, but it would be "nice" if, when plugged in, the Prime also could charge/maintain the 12V battery. Without it you aren't going anywhere. ;)
  2. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    I believe that's one of those obscure facts about the PiP. It does charge the 12V when you charge the traction battery. I'd like to think Toyota would not change that. Not sure though about the ramifications of the Solar Roof. I know it provides a charge to the 12V when under way, but not sure until we actually get one how the 12V is affected.
    Unsupervised!
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I know my Energi will do this.
  4. DavidA
    2,349
    1,825
    Chicago western burbs
    If true for the Prime, this would qualify as an item for the Obscure Prime Facts thread.
  5. bisco
    52,889
    i can't see why they would drop that feature from the pip. but keep in mind, gen 4 has a more robust battery.
  6. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    You mean the 12V is more robust. Don't forget the 12V is located in the front of the car now instead of next to the traction battery like on the PiP.
  7. bisco
    52,889
    this is what i'm saying.:)
