Prime cold starts @ W.O.T.
Discussion in 'Gen 5 Prius Main Forum' started by Preebee, May 15, 2023.
  1. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Unless the Gen5 control logic has changed, you can go out and see for yourself in the driveway. Put the car in HV mode, set emergency brake and place foot firmly on brake pedal, put in D and floor it and keep it floored. You'll see the ICE starts up and runs w/o any drama. It will NOT scream at ultra high RPM's and bounce off the redline limiters like a traditional ICE.
  2. Preebee
    Preebee Senior Member
    871
    774
    Midwest
    2023 Prius
    My assumptions are, the Prime is going to do everything it can to remain in EV mode, much longer than the non-Prime, until the loud pedal is mashed. At that point it's going to perform just like Road & Track says it will. Everything up to and beyond that point is a ? - including any new systems/processes that might be in place to protect the engine from the heat and rapid expansion that would occur during W.O.T. on a "cold" engine.
    I'm just thinking that the pardigm has got to have changed with the massive increase in HP and what appears to be "instant" response from the engine during hard acceleration runs.
    Has anybody with a Prime ever heard their engine "cycle" for a bit when they are on EV mode with plenty of battery and well under the threshold that would trigger their engine starting for acceleration purposes?
  3. Mendel Leisk
    42,208
    That is the premise of this thread. Guess time will tell.
    Preebee likes this.
  4. Trollbait
    12,795
    This isn't a case of taking an engine, and modifying it to produce more power. It is an engine, and paired motors, designed to make more power, with the parts to do so.
    M/G1 does the job of the starter. It is probably 10 times as powerful as a traditional starter, and has no problem spinning the engine up to 1100rpm before even firing the spark plugs. A hybrid cold start is not an ICE cold start.
  5. ChapmanF
    18,909
    My Gen 3 pays a bit of attention to what I do, as I pull out of my driveway and down my street.
    If I am driving normally, it will start the cold engine and run it gently, while supplying mostly electrical traction.
    If I mash the go pedal further enough, the car says "yikes, the human must need to get out of someone's way or something", and it will then temporarily exceed the parameters it had picked for the engine. Until I am back to a normal go pedal input, and it then returns to gentle use of the engine, until it is warmed up.
    I think that's pretty much how I'd want it to work. As Leadfoot suggested in #16, it seems like mostly a strawman concern to fret over what the car will do when driven like that, if you're not intending to drive it like that.
    And for those odd times when you have pulled out gently into the street and then noticed the approaching van you hadn't seen, it's nice that the car will respond that way when pressed.
    Mendel Leisk and Preebee like this.
  6. Preebee
    871
    774
    Midwest
    2023 Prius
    No, it's not a strawman, or any other kind of argument. It's just a question based on an observation of high-performance runs happening without a traditional engine warmup. Even Ferrari's have hybrids so I'm guessing some accommodations are being made. If nobody pops up with an answer in here, I'll try and remember to ask a Toyota mechanic next time I'm in - what is going on when a Prime is just being EV'd around town and then somebody decides to go wild on short notice.
    I'm just remembering a conversation I had with a field tech about a problem I was trying to get solved on my 2019: he was explaining to me how my non-Prime might be cycling the motor on long EV runs to "lubricate the engine". So if this cycling (sounds like the motor is running for a few seconds, but there's no pedal response), is not happening on Prime's, there must be another system in place.
    P.S. I don't own a Prime and likely never will. I'm going EV after 3 more years or so of driving my new 2023 LE. I'm just fascinated by the "instant demand" behavior of a cold, metal engine, under full load, with what is becoming a fairly high-performance power train.
  7. Leadfoot J. McCoalroller
    8,249
    7,753
    Pennsylvania
    2018 Prius c
    You do understand that people routinely abuse random consumer products in youtube videos specifically to get more people to watch, right?
    A few have earned enough on the clicks to repair or replace whatever they were abusing, including expensive cars.
    Preebee likes this.
  8. Preebee
    871
    774
    Midwest
    2023 Prius
    Now THAT'S a strawman... ;)
  9. Trollbait
    12,795
    The Prime is a Prius with the same system. It just has a bigger battery that lets it do a lot more in EV mode. Unless it was out of grid charge when stopped, and not plugged it, the Prime will start the engine up with more energy in the battery than the Prius has. So the Prime will be going easier on the engine than the Prius in this hypothetical.
    Preebee likes this.
  10. bisco
    52,725
    unless you live on a highway onramp, there should be plenty of time to warm up the engine before the need to floor it if that makes you more comfortable.
    that has always been my practice. idk if it's necessary, but i sleep better, and it's no bother
    Preebee likes this.
  11. Leadfoot J. McCoalroller
    8,249
    7,753
    Pennsylvania
    2018 Prius c
    I apologize if my tone came off too harsh, I was really just trying to suggest that if you wanted to be fascinated rather than educated (not judging!) you might get more of what you're looking for out of a video site.
    Preebee likes this.
  12. Mr.Vanvandenburg
    1,359
    632
    2020 Prius Prime
    Tooling in ev and going wild will still be going wild in ev in the Prime until the battery is used to the lowest point. If I am heading to a freeway in the Prime, I do always put it in hybrid mode ahead of time to warm up the engine, to avoid a high rpm event when the engine is cold. I do this often as there is a traffic light at the bottom of an uphill on ramp to a freeway I often use. Others are not interested in me being in their way going slow to warm my ice to protect it going up the on ramp.
    I was going to buy a used Niro ev for less than the Prime, had heat pump option and 11 k miles. I chose the used Prime for more money. It’s whatever works best in the personal situation. My case I feel I need the gas option, and the very large majority of use will be on ev mode.
    Preebee likes this.
  13. Preebee
    871
    774
    Midwest
    2023 Prius
    I'm reading that in 2023, 84mph or a smashed pedal, will awaken the I.C.E. regardless of charge or EV/HEV mode selection. And I believe that Sport vs. Normal vs. Eco will also influence how fast the I.C.E. joins the party.
  14. ChapmanF
    18,909
    The car generally treats a floored pedal as a demand to give you all the power it knows how.
    When driven more moderately, it makes more moderate decisions.
    Hard for me to say that's not the right call.
    Preebee likes this.
  15. Mr.Vanvandenburg
    1,359
    632
    2020 Prius Prime
    Mashed pedal at 84 maybe ice starts, but only a 2023 Prime owner can verify mashed pedal if it stays in ev. I think it would. Ev mode is ev mode only in the gen 4, in my experience having one. There’s ev auto mode which is just as it sounds, which isn’t ev mode. I never have driven 85 in a very long time, so can’t verify a first hand experience. I tend to guess it tops out at 85 in ev mode on mine, and that’s it. The battery isn’t lasting long at that point . I don’t have any intention of trying it so why am I talking about it anyway.
  16. Mr.Vanvandenburg
    1,359
    632
    2020 Prius Prime
    I read in the owners manual one condition for engine to start is exceeding 84 mph in EV mode, but under that speed it stays on electric only. It’s a really good system.
    Also Toyota responds to “do I need to warm up the engine”, with no you do not need to. I disagree but that’s how they see it.
    Preebee likes this.
  17. Trollbait
    12,795
    The 'warm up the engine' recommendation for modern cars, that is ones made in the 1980's or earlier, came from the mistaken belief people were starting the car and immediately driving off. When actually surveyed, people weren't doing that. The usual act of getting 'settled' in the car took place after starting it. Which is enough time for oil pressure to come up. The Prius can get to operating temp in that time.
