Prime electric bill cost to operate
Discussion in 'Prime Plug-in Charging' started by PriusPrimeOwner, Jan 17, 2017.
  1. PriusPrimeOwner
    PriusPrimeOwner New Member
    29
    US
    First month with 2017 Prius Prime premium model added $69.00 to my current electric bill. It equals to about $2.30 per day. Granted, I did not charge it everyday. In December average MPG is 80.4 and Currently in January MPG is 72. If anyone is curious.
    bill188 and bisco like this.
    52,889
    well done! how much gas saved?
  3. PriusPrimeOwner
    29
    US
    I did not really keep track. A drive to work and back. I can do on almost one charge about two miles beyond what it will do on one change.
  4. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    good info, thanks!
    What do you pay per kwh?
  5. PriusPrimeOwner
    29
    US
    Well month to month it varies. Last electric bill was .11 per kwh
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    My landlord charges me $15.00/mo. Since I'm in a 15 story apartment the electricity is commercial so my landlord pays .9 cents/KW.
    dalcon95 likes this.
  7. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    I want to have your landlord
    dalcon95 and priuscatprimeguy like this.
  8. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    OP, if you are using one full charge once a day, that works out to about 200 kWh a month extra. At 11 cents a kWh the bill should have increased about $22 from the EV.
    #8 EV-ish, Jan 18, 2017
    Insirt, dalcon95 and Neohippy like this.
  9. EV-ish
    602
    278
    SW US
    Actually, you want my landlord. He has agreed to let me install PV. I am going to pay about two cents a kWh over the lifetime of the array.
    If I move he'll keep my labor invested in the installation and the electrician bill will be a sunk cost. I'll take my panels and inverter to the new place, or sell him the array at cost.
    #9 EV-ish, Jan 18, 2017
    MMBH, priuscatprimeguy and Zythryn like this.
  10. bwilson4web
    16,552
    We often see two battery capacities: (1) maximum electrical capacity, and (2) operational capacity with the high and low buffers taken away.
    • $69 / $.11 ~= 627 kWh # bill and kWh rate
    • 627 kWh / 25 kWh / 100 mi ~= 2,500 mi # EPA 25 kWh / 100 mi
    • 627 kWh / 8.8 kWh ~= 71 charge sessions (+2 per day?)
    The number of charge sessions seems a little high ... not impossible. This is the problem of trying to use a variable, monthly bill as a meter for a specific load.
    I'm going to suggest you might consider an electrical power meter (i.e., kill-a-watt or equivalent) for the outlet used to charge the car. This will provide a more accurate view of the electrical costs isolated from normal variations. If you do, get one that 'holds the metrics' versus one like the kill-a-watt that loses it in a power outage.
    I am using an instrumented, Emotorwerks EVSE that records each charge session. They exist but cost hundreds of dollars. Still, I like to know.
    GOOD LUCK!
  11. PriusPrimeOwner
    29
    US
    Well you buy the meter for me then. I am not your science project.
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    The Prime's usable charge is about 6.3 kWh (at the wall) not 8.8, so ~100 charge sessions?
    (EPA: 33.7/133*25=6.33 kWh @ the wall)
    #12 giora, Jan 18, 2017
    priuscatprimeguy and EV-ish like this.
  13. kevin54
    kevin54 Member
    57
    65
    New Hope, PA
    The cost increase seems rather high - you imply that you didn't charge more than once a day, and sometimes not every day? If that's the case I would think your costs for charging the Prime would be about a third of what your increase shows. Does your electric bill kWh USAGE vary widely from month to month for other reasons?
    SAronian likes this.
  14. bwilson4web
    16,552
    No problem as I bought my own Prime and drive it home Friday.
    MMBH, SAronian, ruby and 2 others like this.
  15. Zythryn
    Zythryn Senior Member
    6,412
    4,415
    I'm guessing the OP is attributing the entire increase to the Prime which does not seem to match up.
    I am guessing colder weather, more days in the billing month, or other factors explain most of the increase.
    At 11 cents/kWh the Prime should only increase his bill $15-$20/month.
    kevin54 likes this.
  16. EV-ish
    602
    278
    SW US
    Yep. Or perhaps his entire bill was $69 ? Or he paid a lot more than 11 cents a kWh for the car charging.
    Only thing for certain is that an error or mis-attribution is lurking somewhere.
  17. PriusPrimeOwner
    29
    US
    Well I am not going to bother sharing on this lame forum. Since people want to pick everything apart like a scientist and there obviously just regular people. What a joke. Of course there are other factors to consider since I did not have a meter running off the one outlet it runs off. People need to stop picking everything apart.
    Dman747 likes this.
  18. PriusPrimeOwner
    29
    US
    Oh really. Thanks for the advice. Scientist Giora
  19. PriusPrimeOwner
    29
    US
    Did you know a battery need to have a maintenance charge even just sitting. So it still takes power. That's why they sell trickle chargers. So if a battery is not in use it will loose a charge. So what is the loss of a battery of 8.8 kWh loose per day sitting?
  20. Samprocat
    491
    297
    Lincoln, NE
    Plugged fully charged...will consume from 0.4-0.7 amps......i will not go so deep how and why.....and this is measured by Fluke meter
