Prime electric bill cost to operate
Discussion in 'Prime Plug-in Charging' started by PriusPrimeOwner, Jan 17, 2017.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
  2. Andyprius1
    2,327
    859
    Cool CA
    First assumption was wrong. Level 2 charging at $.17/ KWHRs. Charge time: less than 2.5 hours from empty.
    Daily cost = 2.5 X .17 = .34 + .08 = .42 cents a day, per charge / full charge.
  3. Andyprius1
    2,327
    859
    Cool CA
    I partitioned the kitchen and family room off with two doors installed at thresholds and since I had a natural gas log starter in my fireplace I connected a gas fired space heater and we are nice and toasty in the Winter. Our gas bills are less than 1/3 of the old, highly inefficient forced air system.
    Upstairs we have a Electric blanket on for about 10 min. A night.
    MikeDee likes this.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    That's some pretty bad math there, Andy.
    2.5 hours * $0.17 / kWh * (240V * 16A / 1000W/kW) = $1.63 per charge.
    You forgot to include the power draw. Essentially you assumed the power draw was 1kW. It isn't, even on 120.
    Others have reported the actual energy consumed during a full charge is 6.3kWh by direct measurements.
    6.3kWh * $0.17/kWh = $1.07 per charge.
    #64 Lee Jay, Jan 21, 2017
    Andyprius1 likes this.
  5. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    The only way to determine the actual cost is to install a meter or strip recorder. The cost of electricity includes the charge moved into the Prime's battery, plus all losses, which are considerable (about 15 percent or more).
    A reasonable meter (from Amazon)
    is about $150, which is the cost of a good dinner for two or one day at Disneyland if you eat your lunch in your car.
    If I had a Prime (next time I buy I will), I would consider the cost of a meter to be part of the purchase price. I don't know why such a meter is not part of the charging cable since the data it provides is so valuable.
  6. Andyprius1
    2,327
    859
    Cool CA
    My provider is SMUD, SACRAMENTO UTILITY DISTRICT, I can go on line and read the KWHRs used between 1200 and 0600, another option is cost for the KWHRs used that day. They always agree, i.e. 2 KWHRs usage = 2 X $.075 = ~ $.15 Total Im only looking at EV charge between 1200 and 0600. Starts at 1200 (midnight) and completed charge. Around 0200 to 0230 where am I going wrong? Was the other post perhaps Level 1 ?
  7. Lee Jay
    5,850
    4,036
    You equated 2 kilowatt-hours with 2 hours. Not the same units. 2 hours on charge at 1 kW is 2kWh. 2 hours on charge at 3kW is 6kWh.
  8. Andyprius1
    2,327
    859
    Cool CA
    For some reason, on your original reply to me you took the KWHRs and again multiplied it X 240 volts times 16 amps, I don't know how you measured 16 amperes.
    1. A Kw = 1000 watts
    2. A KWhr 1000 watts consumed in 1 hour
    3. A watt is the product of E X I, Voltage times current.
    The Kilowatthour already comprises the Voltage, the current and the the total consumption KILO
    ANYWAY I'll pass on to SMUD THAT THEY ARE DOING IT WRONG.
  9. Andyprius1
    2,327
    859
    Cool CA
    Where did you get 3 Kilowatts from?
  10. Andyprius1
    2,327
    859
    Cool CA
    Lee are you a EE ?
  11. Lee Jay
    5,850
    4,036
    Yes - specialty in power.
  12. Lee Jay
    5,850
    4,036
    Just an example.
  13. Andyprius1
    2,327
    859
    Cool CA
    But you incorporated that 3 Kw along with 16 amps that was completely irrelevant to the OPs comments and then put it forth as factual...?
  14. Lee Jay
    5,850
    4,036
    No, I was just trying to teach you how to do this calculation.
    You multiplied 2.5 hours of charge time (not 2.5 kWh of energy usage) by $0.17 per kWh. That's wrong. You need to multiply the charge time by the power draw during that time to get energy (this assumes constant draw, which isn't quite right, but close enough to illustrate the point).
    What I did was to multiply the voltage and the current that a Prius Prime draws on L2 - 240V and 16A - to get its power draw. Then I multiplied it by the charge time to get energy and multiplied that by the cost of energy to get the cost.
  15. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    Sounds right.
    PV ?
  16. Andyprius1
    2,327
    859
    Cool CA
    Many mistakes:
    1. Both Voltage and current as given by any company are theoretical and will vary.
    2 The utility company already calculates PIE, Power = I X E, in their meter at your house.
    3. It then measures time and the watts used in one hour
    4. It also calculates all the variations which occur within any 24 hour period
    So when my Power company tells me on their bar graph that I used 2 KWHRs to charge my car, then I believe them and my cost is about $.15 for that period. TY Lee
  17. White 17
    White 17 Junior Member
    59
    17
    Nor Cal
    I am just getting into owning a plug in so not sure how it will work out . I will guess 20 to 25 days a month. I do have other vehicles that get used also. This will be my most used I think.
  18. Lee Jay
    5,850
    4,036
    Quit being stubborn. This is what you said:
    "2.5 hours from empty" X "$.17/KWHRs" = ... ".42 cents a day per charge / full charge."
    That's a flat wrong calculation. You used 2.5 hours - the charge time - as an energy value. It's not. It's a time period.
    In that 2.5 hours, a Prime will actually consume about 6.3kWh of electricity by the measurements of others. One way to demonstrate that is to point out at it draws either 240V * 16A for about 2 hours (~7.7kWh) or 120V * 12A for about 5 hours (~7.2kWh). Since the charge tapers toward the end, the 6.3kWh actually measured is quite plausible.
    At your rate of $0.17/kWh, a full charge will actually cost 6.3kWh * $0.17/kWh = $1.07 per charge. You got ".42 cents" a charge. Even ignoring the misplaced decimal point, you're still wrong since $0.42 is not the same as $1.07. And it's wrong for a simple reason - you used the charge time of 2.5 hours as a unit of energy when it's not.
  19. EV-ish
    602
    278
    SW US
    Looks to be missing power, as in :
    time * power * cost/kWh = total_cost
  20. Lee Jay
    5,850
    4,036
