Prime electric bill cost to operate
Discussion in 'Prime Plug-in Charging' started by PriusPrimeOwner, Jan 17, 2017.
  1. Db17
    Db17 Member
    188
    92
    Visalia, CA
    That's probable/possible. But it still takes 6.3 kWh though you might save a few pennies. But the wait will definitely be shorter.
  2. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    A kWh is NOT an amount of power. It is an amount of energy
  3. EV-ish
    602
    278
    SW US
    L2 has less losses. It is somewhat non-intuitive because L1 usually runs at lower amps than L2 and therefore has less resistive losses, but most of the charging loss is fixed to time for the EVSE electronics, so the faster charging time ends up being the major savings.
    MMBH, MikeDee and bisco like this.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I'm a bit confused about this.
    Switching loss in the battery charger should be proportion to voltage squared (because you're shorting out the MOSFET parasitic capacitance in each switching cycle and the energy in that capacitance is 1/2*C*V^2. Four times as much at 240V versus 120V but only 2.66 times the power (more amps too) - lose.
    Forward conduction loss should be proportional to current squared. 1.77 times as much at 240V but 2.66 times the power - win.
    Battery charging losses should be proportional to battery current squared. 2.66 times the battery current means more than 7 times the battery losses (which are quite low).
    I'm surprised that the forward conduction losses so drastically dominate the other sources that 240V charging would be not only more efficient, but by the reported 15%. Switching losses and conduction losses are usually comparable so I'd expect this to be close to a wash.
    Weird.
  5. EV-ish
    602
    278
    SW US
    You are thinking over my head, but I don't think the difference is an absolute 15%
    L2 is around 12-14% losses
    L1 is around 18% losses
    Or so I have read.
  6. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Technically you are correct. Please excuse my poor semantics ;)
  7. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Is the heat generated by the losses in the charger in the cabin area or on the outside ?
    Is it helping to warm the car ?
  8. Lee Jay
    5,850
    4,036
    The charger is under the rear seat.
  9. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    It must have forced ventilation that leads to somewhere, cain't just let heat build up under a seat.
  10. Db17
    Db17 Member
    188
    92
    Visalia, CA
    So if you charge your Prime once every day, that amounts to what, the somewhat less than the cost of a Happy Meal over a month?
    I just bought a device to track my home energy usage, but by my calculations using one full charge a day instead of buying gas will net me about a $12/ month savings. So the delta between 14% or 18% loss doesn't change my world.
    So I'm pretty new to this forum. So far I haven't found and credible independent measurements of about anything posted. I've never found manufacturer's marketing numbers (or EPA's) to match what most of us in the real world come up with. My point here is that we are mostly speculating. Here's my first night's car charge.
  11. Lee Jay
    5,850
    4,036
    I suspect it can. It can probably tolerate being at over 100C. It has to be able to survive the car sitting in the sun in the summer while charging. It might have a heat sink that's bonded to the car body or something.
    Looks like it might have a small fan that blows air forward into the passenger compartment. upload_2017-1-22_10-2-24.png
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Cancelled.
    #112 giora, Jan 22, 2017
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    This looks like a recording power meter (Wattmeter), can it sum up and show you the total energy consumed? because that what you are after (I think).
  14. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    We are talking here of battery usable capacity (for EV) and the amount of charge consumed from the wall (=~payable charge) to charge it up, these have nothing to do with driving habits etc. So, EPA calculated data of amount of charge from the wall is applicable to everybody in the real world (at least when the battery is new).
    And, as I posted earlier, this ~6.3 kWh consumed from the wall (=~payable energy) was already confirmed here by some owners' measurements. So, what exactly do you mean by "credible independent measurement"?
    #114 giora, Jan 22, 2017
    EV-ish likes this.
  15. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Yes it is. But it is monitoring my entire service and is not dedicated to car charging.
  16. EV-ish
    602
    278
    SW US
    1. Start with EPA 133 MPGe and 25 miles range. The rest follows
  17. EV-ish
    602
    278
    SW US
    In the same way that 2+2 is technically 4.
  18. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Did you have to look that up?;)
  19. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    It is force ventilated.
    The input is directly under the back console.
    I usually keep a small trash buck on the floor nearby, and the fan sucked the plastic liner to the vent, causing the fan to go into really high gear.
    There is another vent to the passenger side on the floor, but it does not seem to be forced. I did the tissue test to see if there was pressure or suction, and I could not detect either.
    I was charging 240 volts, 16 amps, and the foot well on the passenger side was at about 56 degrees F.
    Ambient for the car was 45, for the garage 38.
    Free heat for the winter!
    giora likes this.
  20. bisco
    52,901
    maybe the fan was off.
