Prime Features Explained
Discussion in 'Prime Main Forum (2017-2022)' started by Tideland Prius, Aug 18, 2017.
  1. benagi
    benagi Active Member
    525
    280
    Utah
    I think it sounds like a good deal for both you and the dealer. Also, if you pay enough taxes for 2018, you willl get full $4502 tax credit.
    KRISTJAN ANTALIC likes this.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    None of the Prime's have Entune 3.0.
  3. Joeteck
    Joeteck Junior Member
    43
    Long Island, NY
    2018 Prius Prime
    isnt the BSM and RCTA the same thing?
  4. Tideland Prius
    16,678
    Nope. They use the same radar but are not the same thing.
    BSM notifies you, via the yellow lit icons on the wing mirrors, about the potential of an object in your blindspot in the adjacent lane (left or right). It will flash rapidly if you indicate and there's a vehicle there.
    RCTA activates in reverse and scans left/right for approaching vehicles that are 90° to your direction of travel (so it may not catch vehicles if there's a curve in the road (left/right or elevation type curve) that may impede the radar's view of an approaching vehicle. It will alert you on the 4.2" MID along with an audible buzzer if it detects a vehicle as you are moving backwards. This version does not auto-brake (That's RCTB on certain Toyota models).
    Prodigyplace and Joeteck like this.
  5. Joeteck
    43
    Long Island, NY
    2018 Prius Prime
    Ahhh, thank you.. Neat how Toyota can use the same sensors for a different task. <LIKE>
    Tips and Tideland Prius like this.
  6. PrPr
    PrPr New Member
    US
    2019 Prius Prime
    Hi got a new prime today. So far had some short distance driving to stores and home. Didn't use gas just the battery for all which was cool. And I really think HUD is cool but does anyone find it little bit distracting? :)
    SM-N960U1 ?
  7. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    You can dim, adjust hud up and down.... page 253, 2020 manual...was thinking that myself but you have to minimize it in your brain ;D
    Samsung Galaxy Note 9 (SM-N960U1) GSM? I use older model samsung
  8. Tideland Prius
    16,678
    You can always turn it off by pressing the HUD button to the left of the steering wheel. (There are 3 settings - OFF, speedo/DRCC, speedo/HSI/EV range)
    Tips likes this.
  9. MaggieD
    MaggieD New Member
    Washington
    2020 Prius Prime
    Just a heads up - the remote AC no longer works via an app, even though Toyota is still advertising that it does. All the app features for the car were discontinued in Sept 2019. It’s pathetic that Toyota still hasn’t updated its advertising and manuals to reflect this but they haven’t.
    Tideland Prius likes this.
  10. CharlesH
    2,798
    1,166
    Roseville, CA
    o_OTrue, they don't work on the 2020 Prime Limited, but the Advanced Apps are still working just fine on my 2017 Prime. I have used Eco Dashboard, Charge Management, and Vehicle Location in the last couple of days.
  11. jasonj566
    jasonj566 New Member
    Portland, OR
    2020 Prius Prime
    I just bought the 2020 prime prius limited. I had the 2017 prius prime and you used to be able to use the entune app to see your charging current status and vehicle locator, did they discontinue that now showing in app as well?
  12. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Correct, no more Prime App for 2020 Prime Limited.
  13. Dael
    Dael Member
    137
    32
    Ohio
    2020 Prius Prime
    fingers crossed, entune/android auto...
  14. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Nice thread.
    So still the same for plug ins! You never have to plug it in as it is optional?????
  15. dbstoo
    dbstoo Senior Member
    1,397
    753
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    You are not required to plug it in. If you don't, it behaves like a normal hybrid with a bigger than normal battery. The bigger battery will allow you to recover more energy from regenerative braking.
    Depending on where you are, charging from the grid may be much cheaper than using gasoline. Personally, I find it more convenient to plug in the charger each day instead of having to go to the gas station every month or so.
    Dan
    Henrik Helmers and jerrymildred like this.
