Prime for newbie
Discussion in 'Prime Main Forum (2017-2022)' started by wongnog, Dec 22, 2023.
  1. wongnog
    wongnog Member
    125
    26
    Toronto
    Technology
    Hi guys, been a really happy owner of a 2014 Prius C for almost 10 years now, and starting to consider an upgrade to a Prime. Thing is I won’t have regular access to a charger in my condo building, so would only charge if one is available at the mall or maybe public parking. Does this make sense, to treat the Prime just like a hybrid with the bonus of occasional charging?
    52,677
    absolutely, not a problem at all, but don't pay more for it. there was a time when they were cheaper, then it made sense.
  3. wongnog
    wongnog Member
    125
    26
    Toronto
    Technology
    Thanks, I think there are government incentives where I live (Toronto, Canada) that make the base prime comparable in price to the top trim Prius. Also sorry if I’m posting this in the wrong sub forum, I could find one for the 2023 Prime
    52,677
    gen-5-prime-charging.178
    it's the only one in the gen 5 forums, because they figured everything else was the same. makes it confusing though, and they forgot to put gen 5 in the title
  5. bisco
    52,677
    don't forget, it's heavier, and no place for a spare. not sure if there are other differences, but if you can get it for the same, don't need awd, and want the ev once in awhile, absolutely worth it.
  6. Trollbait
    12,787
    The latest Prime gets worse fuel economy than the hybrid when not charged. Something to consider.
  7. sylvaing
    sylvaing Senior Member
    1,211
    514
    Well, it IS heavier...
  8. otatrant
    otatrant Active Member
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    For clarification you don't need a built in charger to charge the prime. In addition you can't charge at the DC fast chargers. The car comes with a charger you can plug into most (120V/210V) outlets.
  9. wongnog
    wongnog Member
    125
    26
    Toronto
    Technology
    Thanks but it would at the least be better fuel economy than my 2012 Prius C! Almost 12 years later it’s averaging 5.5L/100Km.
    Note: incorrectly said I have a 2014 Prius C in OP
  10. wongnog
    wongnog Member
    125
    26
    Toronto
    Technology
    So I’m moving into a new condo building, and most underground parking spots don’t have their own outlets. So if I get the prime, I’d be driving it like my current hybrid with the occasional charge at public places
  11. bisco
    52,677
    nothing wrong with that if that's what you want
  12. Washingtonian
    Washingtonian Senior Member
    726
    621
    I have found that after enjoying driving my Prius for a few years I will never go back to an ICE as a primary vehicle. Just filled the gas tank last week; previous fill was in September. I would recommend you look closely at the available parking in the condo garage. Some spaces may have a 120V outlet available. Not sure of Canadian laws, but would think that if the government subsidizes EVs, they may encourage the building management to have available charging as EV ownership will be more common in the future.
  13. Canby
    Canby Junior Member
    Burlington, On
    2018 Prius Prime
    Unfortunately the Province of Ontario in their wisdom removed any incentives years ago for anything related to electric vehicles or plug-in-hybrids of any sort. There are incentives from the Federal government.
    Anyone installing charging equipment in a condo has to get condo board agreement which can be very costly and time consuming. I find it quite easy to charge up at many free or very inexpensive public places such as parking lots at shopping centres etc.
  14. sylvaing
    1,211
    514
    What else did you see expect from a conservative government...
  15. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    Primes have charge mode that will charge the traction pack all the way up to 80 % State of Charge by starting the engine to charge the battery. (Hold the HV/EV button for 5 seconds and see the charge mode indicator on the dash light up).
    It's not a feature I'd use instead of plugging in to charge, but if you don't have local access to a convenient outlet to plug into, it's really nice to have this feature.
    Learning how to use Charge Mode sparingly, and adjusted to all your local conditions, and the other behaviors of the car, when the taction pack has at least some EV range available, the Prime can be very efficient and even fun to drive. Especially if you learn enough about how it works to make it fun for you.
  16. sylvaing
    1,211
    514
    I've used the Charge mode a few times for about half and hour before leaving an intercity highway and getting into town so I can run in EV mode while in the city.
