Prime Heat Pump Questions...
Discussion in 'Prime Technical Discussion' started by Susan4ET, Dec 2, 2016.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I think A/C off/on does not take you out of auto as well in the PiP
  2. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Taking some refrigerant gas (in liquid form) from the condenser outlet, bypassing the evaporator and injecting it to strategic points inside the compressor. This liquid evaporates (flash evaporation) at the conditions inside the compressor and thus cooling down the mass of vapors there, this cooling action allows for the system to produce effective heating at ambient temps lower than regular (non gas injected) heat pumps. With the prime - down to 14F.
    With bigger housing systems the same effect (and better) can be achieved with 2 stage compressor with intercooling heat exchanger in between, but this is not practical with car systems.
    Sorry for the length...
  3. Trollbait
    12,832
    The prime isn't the first car to have a heat pump, it is the first one to have one of these gas injected heat pumps. The technology was in use for other applications before the Prime
  4. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    When you're in hybrid mode and the heater is on, does it keep burning power with the heat pump, or switch entirely over to engine heat?
  5. mr88cet
    2,313
    1,335
    Austin, TX
    FWIW, the EV1 (RIP) also used a heat pump.
  6. Trollbait
    12,832
    I think all the BEVs available at this point use a heat pump.
  7. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    It will depend on engine heat if the coolant have reached parameter....otherwise it will use heat pump......in EV mode that is another story....there is so many things that are different from what we are learned from other .....this is new way of efficiency....
  8. mr88cet
    2,313
    1,335
    Austin, TX
    I gather from other conversations here that it uses engine heat for front defroster.
  9. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    correct
  10. ttait
    ttait Active Member
    273
    163
    Southern California
    Does that mean that if you activate remote climate with front defrost the ice will start? I'll have to experiment with that. (first I have to get remote climate working reliably)
    I have managed to turn the remote climate on a couple of times (out of many times trying) and the front windows really fog up. This is probably because there is no A/C taking moisture from the air. After it's been running for it's allotted 10 minutes, it is quite steamy in the car. I haven't tried running the remote defroster. I'll make a point of it next time and let everyone know if the ice does start.
  11. priuscatprimeguy
    2,730
    2,640
    No, in fact turning on remote climate and remote front and rear defrost will not cause ICE to kick in, as I have tried this several times
    bisco and john1701a like this.
  12. bisco
    52,880
    that's great news, especially front defrost.
  13. bisco
    52,880
    how does that match up to this answer?
  14. priuscatprimeguy
    2,730
    2,640
    well, it's like this bisco.........ICE will kick in if you're in EV mode and vehicle is in Ready mode. and you turn on front defroster.:D
  15. bisco
    52,880
    i get it.:whistle:
    priuscatprimeguy likes this.
  16. mr88cet
    2,313
    1,335
    Austin, TX
    I could be mistaken, but I don't think the Prius Non-Prime uses a heat pump.
    I gather that the heat pump is pretty quick at starting to warm (from car off), which would make sense. However, it's worth pointing out that, unlike my current Gen-2, the Prime, and probably other Prii since my Gen-2, pipe the engine coolant past the catalytic converter, which means that it heats up vastly quicker than on my Gen-2.
  17. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    The Prime has a ecoheat position and along with low fan
    position will provide defrost to the front window without
    Activating the main defroster, Engine will not come on.
    True for this geographical area, cannot vouch for others.
  18. bisco
    52,880
    should work well within austin city limits. as for ten 3 heating up faster than gen 2, it would take a machine to measure the difference. it's probably about as much as mpg's improved.
