Prime LE or XLE '21 - is carplay wired or wireless?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by YogiJr, May 23, 2021.
  1. YogiJr
    YogiJr New Member
    Boston, MA
    2020 Prius Prime
    With '20 model, for apple carplay to work Google Maps or Apple Maps, I need to plug my phone via USB. Does 2021 Prime LE or XLE have a wireless option or do they also need to have a phone plugged in?
  2. satsuke
    satsuke Junior Member
    68
    XLE is wired only
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    AFAIK, all Toyota models that offer Carplay or Android Auto are all wired. I have not read any info that Toyota is offering wireless Carplay or AA. Correct me if I am wrong. I can't say I have checked every Toyota model. But I know for sure no wireless Carplay or AA is offered for any models of Prius PRIME or Gen4 Prius.
  4. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Wired, unfortunately.
  5. MIkeDr
    MIkeDr Active Member
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    Ferretguy likes this.
  6. roguetadhg
    roguetadhg Junior Member
    24
    2023 Prius
    Limited AWD-e
  7. MIkeDr
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    I’m not sure exactly what you mean? CarPlay permits you to use Apple Maps, Google Maps, etc., on your phone but display it on your Prius screen. This is built into 2020+ Prius, in wired form. The gizmo I reference converts that to a wireless connection.
  8. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    Think of it like this. If you just want to listen to music via Bluetooth you have that capability on every trim level
    If you want to take advantage of Apple car play or Android auto you need to plug in a USB cord into the outlet in the center console.
    That can't be done wireless on any model
    Why is this the case? I have no idea. It's probably the amount of data being transferred.
    That being said the XLE and limited have built in nav.
    Which when I thought about it was a absolutely useless feature if I'm mainly using Apple car play or Android auto as my navigation.
    If you're using an app for your navigation though car play, the integrated nav built into the car is useless to you. All you're really taking advantage of is that bigger screen. Which is nice I'll give it that...
    Personally I hated the lack of actual buttons on the 11" screen.
    I found myself being distracted while diving and trying to use it at the same time. Especially for climate control.
    I prefer the cloth seats on the LE better too (call me crazy but I really do)
    Regardless of which trim level you choose all will need a wired connection for either android auto or car play. And only the LE has android auto.
    I like my LE better than the XLE I had. I will probably get another one after this is paid off.
    Which if my stonks go TO THE MOON BABY will be sooner rather than later.
    Sorry to off track from your original question just figured some extra info on the trims would be helpful.
  9. Ferretguy
    Ferretguy Junior Member
    26
  10. Banksy
    415
    133
  11. MIkeDr
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    I haven’t seen any. The connection process takes a bit longer. Once the Prius recognizes the device, it’s then another 10-ish seconds for the device to connect to your phone.
    Sorry, I’m not aware of one.
  12. Ferretguy
    26
    I’ve read that using this gives noticeable lag to phone calls etc. Do you find that to be correct?
  13. pakitt
    2,173
    1,313
    Colorado
    Because wireless Car Play is more expensive and Toyota went cheap on a 2021 model. The fact they don't even offer Car Play but only Android Auto on the LE says it all.
    I wish car manufacturers stopped offering useless Navs that become obsolete in 2 years. We all have a phone with the latest connection tech (4G or 5G), can be upgraded when necessary or as desired, always have the latests and greatest maps, and several nav apps to ones' content.
    Instead I am stuck with a screen with a nav that has already a 1 year old map, with horrible low res graphics (from the 90s) and with little to no integration to my phone. I HAVE to use Car Play even if I didn't want to. Entune, forget it - it was maybe ok 5-10 years ago when Car Play was not a thing yet.
    All car manufacturers should provide is clear functional and safe interface to the car features (e.g., HVAC) and leave the infotainment to the phone you own, with preferably wireless connection and charging. Having a wireless charger with a wired USB Car Play connection is idiotic.
    Toyota needs to up their game with infotainment. Because this Prius Prime 2021, as much as it is fantastic for the car features, design, quality, it is disaster for the infotainment section and lack of buttons for basic car functions (like HVAC). The car might be 2021, but the infotainment is 2010 (at best).
    MIkeDr likes this.
  14. Salamander_King
    11,024
    8,980
    New England
    Wired Car Play has been offered in all trims of Prius Prime since the 2020 models. It is the 2021 PP LE model that started offering wired AA for the first time. The XLE and Ltd with larger screen HU have no AA connectivity.
  15. MIkeDr
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    I haven’t seen this at all. I’ve had lengthy phone calls and no one has ever said anything. Nor have I noticed anything. Besides the slight delay in the CarPlay first popping up, the wireless is indistinguishable from the wired in my view.
  16. pakitt
    2,173
    1,313
    Colorado
    I have recently bought the CPlay2Air adapted mentioned in this forum.
    Warning: the return policy for the CPlay2Air is borderline illegal, and surely in the scam realm. You can return the device only within 15 days *from shipping*. Not 15 days after getting it. And shipping it back, means on your dime and to China. That is expensive. And there is a restocking fee of $25. All this shown clearly in their website here, but it is not mentioned when you order.
    I have read several reviews on other website, not their own, of a LOT of people that got the device, it didn't work, and ended up a $100 brick to recycle.
    All this being said...
    It does work on my Prime Limited 2021. It took a bit for first setup, but I followed the instructions accurately and it works fine. It connect quickly, considering that wired CarPlay takes a while to boot in the first place.
    There is no lag for music (I haven't tried phone calls yet) and animations on the screen are fluid. The graphics are ever so slightly rendered differently, but it is CarPlay. Let's see how this thing will work in x months. I read from many people in forums that after some time it stops working altogether.
    The biggest issue I have, is not with it, but with Toyota's Qi charger! :D My iPhone 13 Pro Max doesn't manage to charge and it loses the connection all the time.
    So Wireless CarPlay with the CPlay2Air works (but I strongly recommend to get another adapter at Amazon with clear and customer-friendly return policy!!), but ok for shorter trips where the battery of your phone will last. For longer ones, wired CarPlay is the solution for me, since the Qi charger doesn't work with my iPhone 13 Pro Max...
    The irony of it all - I thought this adapter would not work and then the wireless charging from Toyota doesn't work... ahahah
  17. PerryD
    PerryD Junior Member
    27
    34
    Near Boston
    2022 Prius Prime
    Another data point for the CPlay2Air adapter, mine arrived last week and I've installed it in my '22 Prime. It works pretty seamlessly, I can keep my phone in my bag, and it connects in about 15 seconds. I haven't seen any glitches, lags, or drops so far. It is currently $119 on their site (claims to be marked down from $159). Shipping took slightly over a week.
    I have the same issue with the Qi charger and my iPhone, I think that the charging coil is quite small on the Prius side. I normally don't charge my phone in the car so it hasn't been an issue.
    MIkeDr and pakitt like this.
  18. pakitt
    2,173
    1,313
    Colorado
    I have noticed that my CPlay2Air has issues connecting when the cabin temperature is low. And sometimes I think the Prime’s own software has issue and reports a “USB error”. But otherwise it seems to be working fine.
    Considering the horrid return policy though, I’d still buy an adapter via Amazon or other retailer with a customer friendly return policy.
  19. MIkeDr
    252
    138
    Seattle, WA
    2020 Prius
    XLE AWD-e
    interesting. How cold is the cabin temperature?
  20. pakitt
    2,173
    1,313
    Colorado
    I’d say 10C/50F or less.
