Prime may start ICE in EV mode if Windshield Defogger switched on
Discussion in 'Prime Technical Discussion' started by GT4Prius, Nov 6, 2016.
  1. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    I am perfectly OK in sub zero temp, I just need to be able to see through the windshield in front of me. :)
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    when the temperature reaches -14 degrees F or below ICE will definitely come on. Last December or January it was -7 degrees and ICE kicked in for me.
  3. Salamander_King
    11,019
    8,954
    New England
    minus 14 F can happen, but it's rare. I may be OK for most part of the winter.
    priuscatprimeguy likes this.
  4. priuscatprimeguy
    2,730
    2,640
    Using the Remote Climate if you have the Advanced model comes in handy because both the front and rear defroster come on without engaging ICE. But sometimes it's a losing battle when it's that cold out.
    Salamander_King likes this.
  5. priuscatprimeguy
    2,730
    2,640
    agreed:cool:
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Got my car in April, so don't know yet. Coldest I drove it in was about 12 degrees F. Ev only.
  7. Mendel Leisk
    41,463
    Could I make the case for just driving as usual, no special tactics, don't sweat the engine running more. It's maybe healthier for the car overall, in particular the engine?
    I'll brace for the barrage now, lol.
  8. Mark57
    2,945
    2,740
    OK
    Go visit the ice climbing in Ouray in February. That'll be a good test.
  9. priuscatprimeguy
    2,730
    2,640
    well, I do have a full tank of gas that needs to be used up:p
  10. Tideland Prius
    16,559
    The Premium has a an A/C button on the fob, right? You can pre-heat the car prior to take off so that the interior is warm and the windows are at least partially frost-free.
    As long as you run the climate control in AUTO with the A/C light on, you'll be fine without the defroster. It's rare that the ice forms such that it impedes my vision (but i can still see the frost in the far corners of the windshield where the air has cooled down by the time it reaches that altitude but that happened when it was -40 outside.
  11. Salamander_King
    11,019
    8,954
    New England
    Thanks. I will give a try when the time comes. I can still see some instances when defroster is must, like when freezing rain is on the windshield. One of my current project is to clear our shed/garage which is now being use for storage, so I can keep my car inside before winter. By the way, -40 temperature is the same temperature for you in Canada -40C and for us in US -40F. I experienced that temperature only once in my life when I was living in North Dakota. ;)
  12. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    All trim levels have that feature, and it actually works, on my Plus
    Tideland Prius likes this.
  13. Tideland Prius
    16,559
    Ahh I forgot about freezing rain (maybe it was subconsciously deliberate lol). I just about made it to work one day before the windshield cooled enough to start allowing the wipers to smear the freezing rain across the glass; I opted to use washer fluid instead of the defroster haha.
    I know, that's why I left the unit out lol.
    Here's my photo
    from here:
    Extreme Cold Weather Performance | PriusChat
    Nice! And it works for both heating and cooling? (I think the PiP only allowed pre-cooling)
  14. priuscatprimeguy
    2,730
    2,640
    So how did the windshield washer fluid work out for you?:D:p:LOL::ROFLMAO:
  15. Tideland Prius
    16,559
    Enough to get me to work. It was a 12km drive and I started using it maybe around the 8-9km mark.
  16. priuscatprimeguy
    2,730
    2,640
    yup, it's a cr*p shoot on whether or not you're going to make it all the way before the windshield washer fluid runs out and the window refreezes.:eek:
    HPrimeAdvanced likes this.
  17. Tideland Prius
    16,559
    Esp. since the Gen 3 did not have a "low washer fluid" light. Ran out for the first time a few years back. Argh. Now I check occasionally (more frequent if I notice I'm using it regularly)
  18. joachimz
    451
    612
    17
    SoCal
    don't know, have not had the need for heat here in SoCal :cool:
    And, looking at the pic made me shiver ...
  19. Lee Jay
    5,850
    4,036
    Yes, remote AC works for both heating and cooling.
    Remember, you can defrost without the ICE too if you don't use the defrost button and just direct heat at the defrost vents. The difference is you'll get little or no dehumidification that way. But for frost on the outside, that's what you want.
  20. Salamander_King
    11,019
    8,954
    New England
    I hope I never have to leave home when outside is -40. Although where I live now, most of days in month of Jan and Feb, the temperature does not get above freezing, the lowest we had were maybe -10F or -23C, certainly not -40. I didn't pay much attention on how I drove my Gen3 during winter, and not having climate prep in my previous Prius, I always blasted with defroster. After window was sufficiently defrosted, I used 12v plug-in seat cover heater and kept heat in the cabin minimum for my morning commute. Even without much attention, my Gen3 kept about ~45mpg during winter compared to ~54mpg in summer. I was happy then, but I want more from PRIME now.;)
    Shown below is my record of calculated mpg for 2.5 years of Gen3 Prius ownership. As most of you know, the mpg displayed by the car was always higher than calculated mpg by "full-tank method" by about 8%.
    #100 Salamander_King, Aug 15, 2017
    HPrimeAdvanced and Mendel Leisk like this.
