Prime not ready at scheduled departure time
Discussion in 'Prime Plug-in Charging' started by Alf0412, Feb 17, 2020.
  1. Alf0412
    Alf0412 Junior Member
    2020 Prius Prime
    I have only had my prius prime for about a week. The first two days I set the charging schedule, everything was great and the vehicle was ready as scheduled. The last two days, it has not been ready. This morning it had 10 minutes left, yesterday it had 20 minutes left. Both times the battery was only partially drained since I did not drive more than 10 miles. That is why I was trying to use the schedule so it isn't charging all night. The calendar/clock are up to date and correct. Is anyone else having this issue? Any recommended solutions?
  2. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    It's normal for the scheduled charge to be off the mark. I would estimate up to +/- 60 min. The car tries the best to estimate how long it will take to fully charge, but it makes error. The error I have been seeing is more often in earlier finish than later finish. Mine is set for 5:30 am departure on week days. It is often done by 5 am or earlier, but I also have had a few times it was not ready when I actually left home around 6:20 am. Ambient temperature changes and need for the battery heater or cooler, use of preconditioning, any electrical source power fluctuations, and other unpredictable conditions throws off the scheduled charge timing.
    #2 Salamander_King, Feb 17, 2020
  3. Mark57
    2,945
    2,740
    OK
    Mine has never been late. It's always been done 10-15 minutes early of the desired departure time. This all assumes that you have it plugged in early enough for it to do a full charge to begin with. Best thing is to move the departure time earlier.
    You say you don't want it charging all night. That should nit be a concern. Let it take how ever long it needs to charge and don't sweat it. I always make sure it's plugged in about 6 hours before I need it. That method has never failed me for a full charge.
  4. Alf0412
    2020 Prius Prime
    I plug it in as soon as I get home but specifically schedule it for when I am leaving next. I drove less than 10 miles yesterday and it was plugged in for 14 hours. There is no reason it should not have been fully charged by my departure time. It was in the mid-50s here so weather/temperature should not have had an impact.
  5. Alf0412
    2020 Prius Prime
    So that means the climate feature is essentially useless if I have to schedule the car to be ready an hour before I want to leave?
  6. Jon Bloom
    Jon Bloom Member
    77
    78
    Connecticut
    It won't be "charging all night." It will charge until it's at 100%, then stop charging. It's not like some consumer electronics devices that you have to be careful not to leave on the charger. I often leave my Prime plugged in for several days at a time.
  7. Jon Bloom
    Jon Bloom Member
    77
    78
    Connecticut
    I wonder if this would work: Schedule a charge to start 6-1/2 or so hours before your normal departure time, then add a second schedule event for departure at your normal time if you want the climate preconditioning.
  8. Salamander_King
    11,024
    8,978
    New England
    If you want to set the climate control for pre-conditioning right before you leave, then you just have to set the schedule and if the car is not charged 100% just drive with whatever the level the battery has. If you are seeing 10-20 min to full charge, you have more than 95% charge anyway. The difference of 5% is only a few miles of EV range at the top. For me, the climate control pre-conditioning is a useless feature anyway. The only time I would love to be able to use the feature is when it is cold outside well below 14F. At that temperature, the heat pump is nonoperative. Any other time, preconditioning is just a waste of electricity.
    #8 Salamander_King, Feb 17, 2020
  9. Tamara_]01
    Tamara_]01 New Member
    Philadelphia, PA
    I became a prius owner in beginning of February and successfully used the scheduled charge event for a few weeks. This weekend, i plugged it in like normal, and two days in a row, NO charging was delivered overnight. I checked the outlet was fine, the time on the clock is fine, and it charges using "charge now" just fine (at home and at charge point). With COVID 19, I'm only going to ther grocery store and back so i wasn't too inconvenienced, but definitely want to figure out what's going on.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Welcome. I can think of a couple possibilities, but without knowing all about your situation and the steps you take, I'm just guessing.
    Is it possible that it's waiting for a scheduled charge? There are 3 ways to override the schedule. One is by hitting the "Charge now" button that comes up on the display when you turn off the car assuming that the 7" display on a plus has that feature.
    Another way to override the schedule is with the button on the dash that kind of hidden down by the driver's left knee. Use that in conjunction with the MID display after it's too late for the first option.
    The third and easiest override is to just plug in the EVSE in the charging port and then unplug it and then plug it back in within about 5 seconds. When you first plug in the EVSE, the green indicator light in the port will bling green a few times and then go out it it's going to wait on the scheduler. If it's going to charge immediately, it'll come on and stay on.
    Another possibility might sound stupid, but it's really easy to just forget to turn off a Prime (or any Prius) when you get out of it. You put it in park, browse the amazing statistics and then, because it's dead silent, you just get out and walk away. Happens a lot! And, if the car is still on, it won't charge.
    So, if you want it to charge immediately, it's easy to know if it's going to do that. First, the green light in the charging port will light up. Second, the three blinking LEDs on the dash in front of the passenger seat will blink giving a rough approximation of the progress. Third, if you open a car door, the MID will show how long till the charge will take to either start or finish. If it's on a schedule and plugged in when you open a door, it will tell you when the charging is going to start or finish depending on the kind of schedule (start or departure time). If it's actually charging, it gives the estimated time till it's finished.
    So, first steps in investigating:
    1. Look at the green light in the charging port.
    2. Open a door and see what the MID tells you.
    These two steps will probably get you starting in the right direction.
  11. LightningBolt
    LightningBolt New Member
    27
    Rhode Island
    2020 Prius Prime
    I've been carefully tracking actual charge times for my car (2020 Prime Limited) and notice the car consistently over estimates the actual time by anywhere from 10 to 20 percent. Car currently has less than 1500 miles on the odometer. Was wondering if others have noticed this and if it changes as the car ages.
  12. Salamander_King
    11,024
    8,978
    New England
    Yap, the estimate is off, and I don't think it changes as the car ages. My 2017 PPPremium always indicated 6h 10min for empty to full charge, but it was almost always done charging by 5h 30min.
    #12 Salamander_King, Oct 30, 2020
    jerrymildred and LightningBolt like this.
  13. jerrymildred
    11,517
    14,167
    Tampa, FL
    I concur with @Salamander_King. Unless I turn on the air conditioner and delay it, mine is always done well ahead of the promised time.
