Prime Premium versus Advanced
Discussion in 'Prime Main Forum (2017-2022)' started by MagnetoBlue, Jun 5, 2018.
  1. A Prime Factor
    A Prime Factor Formerly "I want my PHEV"
    340
    171
    Madison, WI
    Here's what I like about advanced, in order of importance.
    Rear Cross Traffic Alert - I have always thought cars should be able to tell or show you what they can see that you cannot see from the driver's seat. Now they can.
    Blind Spot Monitor - Similarly, I'm always worried that even if I look and look again, I'll miss a car in the blind spot. I use this as an extra check before changing lanes.
    Heated steering wheel - I love this feature. Sure, if you live somewhere it never gets cold, you would not need this. I use this all the time in winter.
    Intelligent Clearance Sonar - It beeps a lot, but when I'm trying to negotiate a tight area, it gives helpful clues.
    HUD - While not absolutely necessary, putting some info on the windshield is a great idea.
    Rain-sensing wipers - Pretty cool, especially in light on-again off-again rain. One fewer thing to think about.
    Auto-dimming rear view mirror with Homelink - Had this on my previous car and saw no reason to give it up!
    Premium JBL audio - While not a make-or-break feature, this is honestly the best car stereo I've ever had.
    Things I haven't really used at all so no opinion:
    Parking assist
    Safety Connect
    Smartphone apps
    benagi likes this.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    having avoided parallel parking intentionally for years I definitely want to try it out.
    J
    Prime Alex likes this.
  3. A Prime Factor
    340
    171
    Madison, WI
    Update:
    I have now tried the parallel parking assist a couple of times and it works great. Perfect for someone who doesn't parallel park often enough to be good at it.
    schja01 likes this.
  4. antiglare
    antiglare Member
    79
    57
    SF Bay Area, CA
    For me, hearing that the auto parking feature has a tendency to scrap up my wheels is enough incentive to never try it. Unless Toyota offers to replace my rims/hubcaps when the autopark feature scrapes the curb.
    I'd much rather have a 360-degree camera than autoparking.
  5. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    have you tried the "parallel exit" feature? You have that also... when you're already parked and it's time to leave hit the park button again and it will pull you out of the spot. works pretty well actually!
  6. Mendel Leisk
    42,343
    How is that call made; is there some sort of two-way communication built-in to the car?
  7. PCPrime
    PCPrime Member
    110
    103
    Tampa Florida
    Yes, the Safety Connect uses its own cellular connection
  8. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Yep. There is a cellular radio. Verizon LTE.
    J
  9. Tideland Prius
    16,678
    Yes. There's a DCM (data communications module) inside the car that works off the cellular network.
  10. CharlesH
    2,798
    1,166
    Roseville, CA
    Isn't SafetyConnect only on the Advanced? The SafetyConnect cell phone also enables the Advanced Entune applications (remote charging, vehicle location, remote climate control), which are available only on the Advanced.
    Good thing it uses LTE. Verizon is shutting off their CDMA network at the end of 2019.
    Which means no joy for our Canadian friends.
    #30 CharlesH, Jun 26, 2018
  11. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Doesn’t everyone have an Advanced? ;)
    benagi likes this.
  12. SteveMucc
    391
    268
    Kentucky
    Why do you say that? The phone can handle it, but it's all about the roaming agreements between Verizon and Canada... I would guess that Toyota could have enough clout to make the roaming charges go away if they wanted to
  13. A Prime Factor
    340
    171
    Madison, WI
    No. I wasn't aware of it. I'll try it next time if I think of it. I don't get many opportunities to parallel park.
  14. A Prime Factor
    340
    171
    Madison, WI
    Another update:
    While I still haven't tried the parking exit, I got the apps on my tablet (don't have a smartphone) and now I can use an app to turn on the air conditioning. This is useful. I can't wait to try it in winter heat (well, actually, I can wait). Also, to get the necessary ID to set it up, I called Safety Connect with the button in the car, and that worked nicely.
    So I can now say that every feature of the Advanced (beyond the Premium) adds something of value for me.
    MNdriver and SteveMucc like this.
  15. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Safety connact is standard on all 18 prii, and i thought it was also on 17's but google isn't helping to ascertain.
  16. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    #36 Salamander_King, Oct 24, 2018
    heiwa and Tideland Prius like this.
  17. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Salamander_King likes this.
