Prime Prime - understanding kWh
Discussion in 'Prime Main Forum (2017-2022)' started by john1701a, Jun 27, 2019.
  1. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    The latest upgrade from that aftermarket app (called "Hybrid Assistant") I use to create Prius Prime drive videos with has added a very informative new meter. You can now see the electricity being consumed & regenerated.
    That display of kWh is real-world data we've never had access to on this level. It's a great learning tool to really understand what the plug-in hybrid technology is really delivering.
    Here's my first video using it, featuring a 30-mile drive of all EV with kWh data the entire way:
    I'm quite curious what others will have to say after observing that collection of content compiled into a single contiguous video. Feel free to sound off on whatever information catches your interest.
    Arctic_White, ReDave, Pdog808 and 2 others like this.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    If I had one iota of an idea what the Hybrid Assistant’s various displays actually mean I’d probably find it of interest. Can you you post a cheat sheet? Being an Apple person I don’t have access to the app. In general I do appreciate your posts and expertise.
    J
  3. john1701a
    12,840
    5,312
    58
    I'm working on a cheat-sheet. Posts like this are how I collect feedback about the content for it. In this instance, the topic is kWh.
    kWh is the amount of actual electricity consumed by the vehicle. This is a big deal, since some plug-ins are more efficient than others. In fact, some are outright guzzlers of electricity. That's why drawing attention to how well Prius Prime uses its supply available will help endorse Toyota's well thought out design.
    Think about kWh. That's the unit of electricity your provider bills you for. Requiring less to travel the same distance is a better return on your vehicle purchase. Your monthly statement will be lower. It also means you'll spend less time at the charger. So, knowing the actual efficiency rate is very important. Understanding of that starts with observation of how kWh is used.
    Prius Prime has a 8.79 kWh capacity battery-pack. Part of that is reserved for longevity, never touched for the sake of avoiding stress on the cells. Extremes accelerate aging. There's also a portion of it reserved for HV travel. The portion allocated for EV travel is noted on the dashboard as the percent value from 100 to 0, when the numeric display option is selected. On that secondary display (to the right), it is the range from 87% to 12%. In other words, the dashboard shows "usable" capacity and the phone app for that aftermarket gauge connected to the ODB-II port shows "actual" charge level.
    Watching the video, you'll see the Total kWh value go up & down. That's because it is showing the net result of using plug-supplied electricity and some of what it recovered when braking (known as "regeneration" of electricity). For that 30-mile drive, it states a 5.2 kWh as the transition point, where EV capacity is depleted entirely and HV mode engages. At that point, the gas-engine joins in to supply power for both propulsion & electricity.
    The next step in understanding kWh is to look at what happens when you plug in. There are conversion losses going from household AC to the battery DC. There are efficiency differences from the charging speed as well.
    Arctic_White, jerrymildred and utsug like this.
  4. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Thanks.
    Maybe a little verbiage on these?
    Some of the Icons are not intuitive to me.
    Tnx.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    I am bit confused. So, 5.221kWh your video is showing at the end is the total amount used from 100% to 0% SOC on MID. Do you see this number to be more or less constant from day to day when 100% is used up to 0% SOC on MID? 12% to 87% SOC shown in Hybrid Assistant for the EV MODE makes up 75% total for the traction battery that has 8.8kWh capacity. That would mean 6.6kWh (8.8 x 0.75) of the battery capacity was used for the EV mode. This number seems to be larger than what I have read in some other thread. I though the actual SOC for EV was more like 18%-80%. If I believe the number on the video, why the actual total kWh used 5.221kWh is smaller than 6.6kWh? Like you said, if the total shown is subtracting "regenerated" electricity, shouldn't the total at the end be larger than 6.6kWh?
  6. Flaming
    Flaming Active Member
    138
    123
    QC , Canada
    Technology
    If you put the car in accessory mode while charging HA shows 3.2 kw going in while my meter in my electrical panel shows 3.8kw going out for the charging station circuit.
  7. john1701a
    12,840
    5,312
    58
    Since I recharge at work, most of driving is totally electric... which means not actually depleting the battery-pack to 0% that often. So, I don't have that data available.
    We cannot account for every aspect of battery design & capacity; however, we can monitor inputs & outputs. A full recharge for me registers as 5.75 kWh via the charger. The observed 5.2 kWh from driving would account for that rather well when we factor in conversion losses.
    Since it is all plug-supplied electricity being tracked, no. Seeing the flow in both directions makes it difficult to follow, especially when recovery is only partial, but it's the same quantity in the end.
    The best analogy for that is to envision a pitcher of water being the energy source. You may pour a little back when a glass is filled too full. You may also spill a little in the process. But there is never any more water added beyond what you started with.
  8. john1701a
    12,840
    5,312
    58
    That 167° is temperature of the traction motor, not much of an influence on anything related to the drive itself.
    That red/yellow/green ball going up & down and white circle is an efficiency meter, a feature of the app designed for those who don't have a handy hybrid display like we do in Prius.
    That 0.0 on the left is the kW (power) meter for the gas engine, which is never used in this particular video.
    That 15 on the right is the kW (power) meter for the electric output (both motors combined) showing traction energy sent to the tires. It's what many of us find most important, since it indicates EV power. Each generation of Prius has offered more, to the point where we see everyday need is covered just fine.
  9. ed4271
    ed4271 Member
    107
    64
    US
  10. Washingtonian
    Washingtonian Senior Member
    726
    621
    Here is the simple way I think about kWh. Electrical power is measured in Watts, current in Amps and pressure in Volts. Power (Watts) is current times voltage. kW is a thousand Watts; kWh is the power of a thousand Watts for one hour. My electrical utility charges me thirteen cents for one thousand watts of power for one hour, or 1 kWh. I can use that to power a couple of burners on my electric stove for an hour or maybe two burners and the oven for half an hour. Or, I can use it to charge the Prime enough to drive five or ten miles on EV , depending on how I drive and the road I am on.
  11. Salamander_King
    11,024
    8,978
    New England
    So, I've tried using the Hybrid Assistant to record the Total kWh consumed during my recent trips. Only twice so far, but I don't know where this number is reported in the final report the app generate.
    The on screen TOT kWh meter was showing 2.536kWh at the end of one trip. The Report app generated for this trip has different value under High Voltage Battery Statistics. The number seems to be close to the final value in Energy graph, but not exact. Do you where this number "2.536kWh" in this case is found in the report? Or is it a glitch in meter display and/or report generation of this app?
    #11 Salamander_King, Jul 11, 2019
    Arctic_White likes this.
  12. Salamander_King
    11,024
    8,978
    New England
    That must be the "measuring charge efficiency" thing they blogged here. Hybrid Assistant: Measuring charge efficiency
    Flaming likes this.
