Prime really hates zero degrees
Discussion in 'Prime Main Forum (2017-2022)' started by Zed Ruhlen, Jan 15, 2024.
  1. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    So it's gotten unusually cold here in Oregon and in the past few days every time I turn on the prime the engine immediately fires up. Haven't been able to run in EV mode at all for days. I've never had it this cold so it was a new experience for me. On the plus side you get a lot more heat :)
    Louis19 and bisco like this.
    52,750
    repeat after me: there's no such thing as climate change, there's no such thing as climate change...
    Louis19 likes this.
  3. Andy2
    Andy2 Member
    77
    51
    Victoria, B.C.
    2022 Prius Prime
    Technology
    Trying to upload picture of my car at -28 Celsius last week (about -18 F). Upload not working — maybe file size is too big?. Yes, engine comes on right away. Car still does go into EV on its own for some stretches. Today it started up and drove well at -36 Celsius! No issues.
    52,750
    upload has been broken for awile, people have taken to linking offsite pictures
    caymandiver75 and Andy2 like this.
  5. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    I can't because my lips froze together
  6. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    Yeah, it's been fine except I have to sadly watch my cumulative MPGs drop more and more :cry:
  7. MalachyNG
    MalachyNG Active Member
    304
    227
    Northern NY
    2022 Prius Prime
    Below about 14f and definitely below 0 the heat pump can't heat so if you're asking for any heat in the cabin it'll be more prone to fire up the gas engine and definitely will if you ask for front defrost. You can try to coax it to drive in EV by turning off the heat but with lower temps and snow you can expect pretty bad mileage anyway so it's a wash. Once the gas engine starts it'll keep coming back on to maintain operating temperature. Either you'll get 16-20 miles of EV range with a 2mile/kwh and then it switches to HV and still be 55ish MPG for a 40 mile trip or you can let it do it's thing and get a little better m/kwh and still get 55MPG for the same trip. I'd rather be comfortable. So I switch to EV auto on cold days or let it decide.
    Zed Ruhlen likes this.
  8. sylvaing
    sylvaing Senior Member
    1,215
    514
    -10°C is the minimum temperature for the heat pump to work. However, if one was to NOT use the climate, just the seat and steering wheel heaters, would the engine still fire up? I've not driven in below -10°C so I haven't had a chance to experience it myself.
  9. ChapmanF
    18,940
    Probably comparable work to just switching off JavaScript to upload them here, and then I can see them,
  10. Washingtonian
    Washingtonian Senior Member
    726
    621
    I noticed this happening this week. I was sitting in the car waiting for my wife to finish shopping and the outside temp was about 20F. In EV mode, about 17 miles available from the HUD, heater on high to defrost the front window, and the engine suddenly came on. I remembered the car has a heat pump and that my home heat pump calls for the heat coils to come on at that temperature, so it didn't surprise me. My son has a Cadillac gas guzzler, and I am hoping he will drive it more to encourage Global Warming to return.
  11. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    I answered that question an entire decade ago, with the original Prius PHV... at -19°C
    The engine stays off. Lithium chemistry will allow you to draw in surprisingly cold conditions (though with a big efficiency penalty due to in increase in electrical resistance), you just can't charge then.
  12. sylvaing
    1,215
    514
    I see that when slowing down, it seems to recharge the battery. Was it the case or did you have to always engage the physical brake to slow down? Renegerative braking can send much more current (albeit for a shorter period of time) than charging alone. Was your battery temperature above freezing (ie, car was plugged in so the battery warmer was working while the car was parked)?
  13. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    That's likely the issue and makes total sense. Thank you. The heat was has been on because, well, BRRRR.
    sylvaing likes this.
  14. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    My drive home from work yesterday was in EV mode. Ahh, the bliss of 20F. And the battery was super unhappy about it, too. Range dropped faster than freezing rain in a wind storm.
  15. DukeofPrime
    DukeofPrime Member
    108
    77
    US
    In my experience, turning on the front defroster always starts the engine regardless of temperature.
    SM-F731U1 ?
  16. sylvaing
    1,215
    514
    Yes, that's how I turn on the engine after an oil change.
  17. Zed Ruhlen
    247
    138
    Hood River, OR
    2018 Prius Prime
    Yes, it's probably to operate heat and a/c at the same time. Which of course the heat pump is incapable of doing both. I wish you could direct air to JUST the windscreen without the a/c but that is not an option. Usually full fan on just the defrost vents is enough to keep up with defogging but if you have split level it isn't.
