Prime rolls when put in park even in small incline
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Robjess, Nov 25, 2017.
Tags:
  1. Robjess
    Robjess New Member
    Nyc
    When prime advanced is brought to a full stop and Park is pushed, car rolls (small incline) unlike other vehicles I drove.
    The sales person said thats a prius thing, does that make sense to any one?
    Thank you
  2. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    I assume you mean that it might roll forward or backward an inch or two until the parking pawl "catches." This is normal behavior for many cars. However the car should not continue to roll past an inch or two. In the photo below, you can see that the car may need to move forward or backward after park is initiated due to the design of the gear that the pawl engages.
    I always keep my foot on the brake, push park (which engages the pawl) and then engage the parking brake. That will eliminate the behavior.
    jerrymildred likes this.
  3. Robjess
    Robjess New Member
    Nyc
    Yes, its exactly how you described it
    In this instance, prime rolls back a couple of inches (on a small incline)
    I have never witnessed this in any other vehicle i drove. This happened during a brand new prius prime test drive today actually. Love the car otherwise but I was put off by this issue.
    So the way to park a 2017 prius (on a small incline) is to push brake, push P button and use the parking brake on the left before releasing the brakes?
    I really appreciate your input on this, huge help as I am trying to decide to get this car or not. Thank you again
  4. fuzzy1
    10,603
    Have you driven any previous Prius? This is not different than my two (past and present) Gen3s, and I believe earlier generations were similar.
    I always use the parking brake on my household's manual transmission cars, and haven't owned a 'normal' automatic in more then thirty years.
  5. Robjess
    Robjess New Member
    Nyc
    So the sales person was right this is a “prius thing”, and isnt aign of a faulty vehicle? It was a decent 10/15 degree incline to be specific
    (I havent driven a prius in a long time, when i did once or twice it was all around flat parking surfaces, definitely reminiscent of manual vehicles)
    Thank you very much again, once again I really appreciate it
  6. Mendel Leisk
    41,905
    I've never had a vehicle (of any description) that wouldn't rock back and forth an inch or two, when off, in park, without parking brake on.
  7. mikefocke
    4,040
    1,839
    Sanford, NC
    As one who just had a pLock actuator replaced, my current approach on a slope is to stop the car with the foot brake, apply the foot actuated parking brake, release the foot brake, then hit the P to lock the parking pawl that locks the transaxle and then power off the car. My failure occurred when I first used the pLock to hold the car before putting the foot actuated parking brake on. The entire car's weight was resting on the pawl and then its retraction wasn't effected by the actuator.
    Granted this is on a v but isn't the principle the same?
    Prodigyplace likes this.
  8. William Redoubt
    1,228
    1,173
    I went out for a drive to check my description through the application of muscle memory. I do exactly as you do (not the way I previously described). I ALWAYS use the parking brake, even if I am on the flat.
  9. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Always use the parking brake, do not rely solely on the parking pawl.
    And, I concur, I've never driven an automatic that WOULDN'T rock a couple inches before the parking pawl engaged, if you didn't set the parking brake.
  10. Ferrarilover
    Ferrarilover Active Member
    185
    168
    Manchester, UK
    I just switch off the car and that puts it into park for me. If on an steep incline I also use the parking brake.
    iPhone ?
  11. bisco
    52,391
    yes, prius can roll more than a few inches after putting in park. i always make sure to take my foot off the brake slowly, until it has come to a stop.
  12. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    This happens on every other automatic I've ever driven from 1972 to 2012 model years. It has to because of the way the parking system works.
  13. Trollbait
    12,686
    The Toyota automatics seemed to have more give in park than our GMs and Fords, and the Prius more so. With the Prius, I'm now in the habit of using the parking brake with all my cars.
