Prime Shutdown
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Stacey Jones, Jan 30, 2019.
  1. Stacey Jones
    Stacey Jones Junior Member
    Biloxi, MS
    2018 Prius Prime
    My 2018 Prius Prime shuts down while driving and immediately turns back on. Anyone else having this problem?
    primer likes this.
  2. schja01
    schja01 Senior Member
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    In the olden days I'd say it was a dirty fuel filter but now a days ??
    Get the codes read or read them yourself.
    May give some insight into whats wrong.
    ardashev likes this.
    51,973
    if you are talking about the humongous screen rebooting, yes. search is your friend.
    if you are talking about the engine, that's how hybrids are designed to operate.
    if you are talking about the whole car shutting down and stopping in the middle of the road, get thee to a dealer
    EyePrime and Bob Comer like this.
  4. Stacey Jones
    Biloxi, MS
    2018 Prius Prime
    The dealer couldn’t find anything wrong. Have another appointment to have the diagnostics checked again. It lasted literally seconds. Screen and dash completely shut down and rebooted.
  5. Stacey Jones
    Biloxi, MS
    2018 Prius Prime
    Oh car lost power as well
  6. schja01
    1,835
    1,221
    Chicagoland
    2024 Prius
    Limited AWD-e
    I like the “That is the way hybrids work “ solution. I was reading more into the question than required.
    Occam’s Razor.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Intermittent malfunctions can be a royal pain to figure out. But, if they read the DTC codes, I would think there would be a history of some kind of trouble code. It's odd to just shut itself down and way more odder that it then restart itself.
  8. Stacey Jones
    Biloxi, MS
    2018 Prius Prime
    I totally agree Jerrymildred. It has happened on 2 separate occasions now. After reading more posts I’m beginning to wonder if it’s a computer system reboot of some kind???
    #8 Stacey Jones, Jan 30, 2019
    primer and jerrymildred like this.
  9. bisco
    51,973
    also, if the car shut down, corporate can bring their computer and see that info in the 'black box'. give customer service a call, and report your experience to nhtsa, that is a dangerous situation, and needs to be addressed before someone is seriously hurt.
    primer and Stacey Jones like this.
  10. Elektroingenieur
    2,515
    3,284
    Three Touring
    When you return to the dealer, ask them to check not only for diagnostic trouble codes (using the Health Check feature of a Toyota Techstream diagnostic system), but also for vehicle control history events, described in my previous posting. If the dealer is stumped, the should open a case with Toyota’s Technical Assistance System (TAS), the dealer-only support line.
    Stacey Jones likes this.
  11. Stacey Jones
    Biloxi, MS
    2018 Prius Prime
    Dealer contacted Toyota. There is a computer upgrade to the hybrid side they are installing this morning and hoping it will correct the problem.
    jerrymildred likes this.
  12. bisco
    51,973
    do you know if this is upgrade something we are aware of?
  13. Elektroingenieur
    2,515
    3,284
    Three Touring
    I haven’t seen a service bulletin or campaign publication from Toyota about it, if that’s what you mean.
  14. bisco
    51,973
    Yes, thank you
  15. primer
    primer New Member
    Yes. Just over 2000mile on my prime. Scary. Still at dealer. I won’t drive it until they find what caused everything to black out. Scary.
    Tips likes this.
  16. primer
    primer New Member
    Did it work?
  17. primer
    primer New Member
    Yes! Scary
