Prime tax credit
Discussion in 'Prime Main Forum (2017-2022)' started by Bobskipp, Dec 12, 2016.
  1. NJ-PrimeAdvanced
    204
    134
    New York/New Jersey
    So in what cases, generally speaking, someone won't' qualify for the fully $4502? what can prevent you, in general, from receiving the full amount - some examples: high income? high mortgage? high other deductions? not having a refund due at all? high tax bracket? or too low bracket? what's a "general rule of thumb"?
  2. Mark57
    2,945
    2,740
    OK
    You have to have a total tax liability of $4,502 or higher for the credit to offset it. The $4,502 credit cannot be carried forward if you don't use it all.
    Look at the line items on your previous return to see what order things are taken in and it will help. Or it will make it MUCH harder. ;)
    It's difficult to make a lot of generalized statements about the situations because there are so many special situations out there, BUT one thing is absolute. You have to have a total tax liability of $4,502 or higher for the credit to offset it.
    #22 Mark57, Jul 22, 2017
    NJ-PrimeAdvanced likes this.
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Looking on the 2016 tax table (page 82) a single person would need at least $33100 of taxable income on line 43 to use the entire credit.
  4. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    I forgot to mention there are also free tax websites that you can use for the calculation, where you can easily do all kinds of "what if" scenarios. I went to the IRS website and they have a list of them, I picked the first one on the list FreeTaxUSA
    Playing around with it I came up with the minimum scenario (using 2016 tax rates) for getting the full credit, which turns out to be $43,450 income with standard deduction, no dependents and no other credits, which results in a tax liability of $4,505.
    Single, no dependents
    Line 37: Adjusted Gross Income = 43,450
    Line 40: Standard Deduction = 6,300
    Line 42: Standard Exemption = 4,050
    Line 43: Taxable Income = 33,100
    Line 44: Tax = 4,505
    Line 54: Other credits = 4,502
    Line 63: Total Tax = 3
    Without the plug-in credit, whatever you had withheld during the year less $4,505 would be your refund amount (or amount owed). But in this case whatever you had withheld during the year less $3 is your refund. So you are getting the full benefit of the $4,502 credit.
    Lower income, deductions beyond the standard, and other credits will have an effect. I will give just one more example, a scenario with a higher income than the previous example, but with one dependent and itemized deductions, causing that you only get $3,575 of the credit applied.
    Single, one dependent
    Line 37: Adjusted Gross Income = 50,000
    Line 40: Itemized Deductions = 15,000
    Line 42: Exemption = 8,100
    Line 43: Taxable Income = 26,900
    Line 44: Tax = 3,575
    Line 56 is the kicker, if your credit(s) are higher than your tax, then the tax owed is 0, not negative
    Line 63: Total Tax = 0
    Without the credit, whatever you had withheld during the year minus $3,575 would be your refund amount (or amount owed). In this case whatever you had withheld during the year is your refund. Which means that only $3,575 of the credit actually benefited you.
    #24 Since2002, Jul 22, 2017
  5. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    California has a limit of two credits and also a maximum income test.
  6. Vikrant
    Vikrant New Member
    Sherwood, OR
    Can someone please help me with this? I am about to buy a prius prime advanced 2017 model for about 28k. The car has 59 miles on it and was built in Nov 2017. If I buy this car in 2018, will I still be getting tax credit? Based on what I know, I would say yes but I want to be sure. Can someone please help? Thanks.
  7. bisco
    52,855
    welcome!
    yes, doesn't matter what year it is. it's what year you put it into service, then you take the credit for that year, the following april. as long as it has never been registered previously.
    all the best!(y)
