Prime Total and Electric Range Question
Discussion in 'Prime Fuel Economy & EV Range' started by JackJ, May 28, 2017.
  1. James2012
    James2012 Junior Member
    24
    Chino
    I drive from Chino to Anaheim every day (60 then 57) then reverse - all in the carpool lane with dynamic cruise control. In the morning, there's the usual stop/go traffic (takes an average 45 minutes to drive) and I get there with battery only left over. On the reverse, I usually come home after the stop/go traffic (takes an average of 30 minutes to drive) and I will definitely run out and swap to gas/electric with another 5 miles to go.
    Is this typical for everyone else - that if there's no stop/go traffic, the Prime will likely run out of juice? I assume it's because I'm driving at a higher speed.
  2. fuzzy1
    10,722
    That sounds reasonable. While the stop-and-go itself doesn't help, the lower speeds of such traffic often significantly boost MPG, compared to free flowing full speed conditions, on our older non-plugin Prii.
  3. stevepea
    stevepea Senior Member
    535
    581
    Yes, the battery lasts longer going at slower speeds (with stop and go to help recharge) than just going 65 (or 70) on the freeway.
  4. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    it all depends, no question that lower speed eg 60mph uses less energy than 70mph, however, in my case of a 50 mile commute i go ~ 40 miles on EV incl ~31 miles on the fwy @ 67 w/DRCC (you can look "My EV range story". I'm chasing my commute hours to be after stop/go ... @James2012 you say "higher speed", unclear what that is, if you can try to not exceed 65-67 and see what difference that makes
  5. Krzysiek_KTA
    Krzysiek_KTA Active Member
    159
    125
    Houston
    from my experience on flat Houston roads if I hit the highway and go for posted speed + 5mph the E/v range falls below 30 - say 27-8 at 65mph+, but if take rural routes and can deploy some gliding below 50mph the E/v is in 33-35 miles range.
    as All keep saying the E/v range really suffers at Highway speeds.
    should I drive stretches beyond 30 miles I'd use HV for HVy driving.
  6. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    Today I did some field test. Before the trip, the dashboard showed 27.8 miles.
    Hit the hwy at 79 mph, EV mode: electricity ran out at 21 miles. Considering $0.2/kwh, the 6.6 kwh translates into 15.9 miles/$
    Same distance at 79 mph after EV ran out: 51 MPG. Considering $2.8/gallon gas, it translates into 18.2 miles/$
    iskey likes this.
  7. James2012
    24
    Chino
    Thanks for the confirmation guys... California drivers get angry when you go sub-70 when there is no traffic. lol
    alexcue likes this.
  8. fuzzy1
    10,722
    Some of us have noticed, even two states away. Though I had to cheer when one such tailgater finally blew around me -- one corner before the waiting speed enforcement (exiting Greenwater, on road back from Mt. Rainier National Park). :D She had absolutely no 'herd protection' whatsoever, and quickly learned why I had been obeying the posted limit the entire time.
    #28 fuzzy1, Jun 15, 2017
    Bob Comer likes this.
  9. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Someone actually got pulled over for speeding ? Now that's a sighting !
    I've noticed that lately, but have attributed to the high heat (upper 80's) and and the fact that it's cooler in the mornings.
    Also my car has a black interior, and gets super hot in my employer's parking lot.
    That air conditioner will drain the battery !
    jp
    #29 I'mJp, Jun 15, 2017
  10. fuzzy1
    10,722
    In a number of the places I frequently travel, it is not at all unusual. Remember that if you are traveling out of state and notice yourself passing numerous cars with local plates.
  11. CharlesH
    2,798
    1,166
    Roseville, CA
    High 80s is hot? Forecast for the Sacramento area for early next week: 108°F
  12. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Yeah but ours is the DRY heat... Theirs is the HUMID heat. You pick up several degrees for the damp feeling. :giggle:
  13. MNdriver
    MNdriver Senior Member
    549
    577
    Let's compare our PIP (pain in posterior) weather stats in January, shall we?
    alexcue and Prius from Dad like this.
  14. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The hottest I've ever felt was 99F and 85% humidity in Washington DC last year. That was far worse than 120F in Arizona.
  15. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I agree. In NJ, during the summer with humidity over 80% any temp over 80 is very uncomfortable. But when I was in Nevada, 100° was not a problem.
    alexcue likes this.
