Prime vs. Hyundai Ioniq
Discussion in 'Prime Main Forum (2017-2022)' started by keithjam, Dec 2, 2016.
  1. Trollbait
    12,814
    Eliminating physical parts with software isn't a guarantee for improved reliability though, and most mechanical parts will last the car until it gets scrapped and even after.
    Besides, the transaxle's physical simplicity is an illusion. Without the two motors, inverter and its cooling system, and battery, the transaxle will not transfer the ICE output to the wheels.
    fotomoto likes this.
  2. CharlesH
    2,798
    1,166
    Roseville, CA
    So how do companies like AAMCO, whose business is servicing automatic transmissions, exist? I sort of crack up when I see their TV commercials about "your automatic transmission has over 800 parts, and we keep it working", with a video of an exploded transmission with its gazillion gears, clutches, belts, hydraulic systems, and other parts.
    #262 CharlesH, Aug 24, 2017
    farmecologist and bwilson4web like this.
  3. Trollbait
    12,814
    How do businesses refurbishing hybrid batteries exist? Or the ones servicing cars' HVAC system? Or brakes? Seen any car dealers without a service department?
    AAMCO was founded 1957. Back then, automatic transmissions were less reliable, and so was much of the other systems on the car. Because of the improvements in reliability, the company had to expand away from specializing in just transmissions.
    AAMCO Transmissions - Wikipedia
  4. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    What is not an illusion is that the Prius is one of the most reliable cars in existence.
    The car has already failed if it is required to transfer power directly from the ICE to the wheels after any of those items you mention have failed.
    kevin
    farmecologist likes this.
  5. Rmay635703
    Rmay635703 Senior Member
    2,689
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    Fixed it for you
  6. kevinwhite
    333
    200
    Los Gatos Ca
    Is the New 2016 and 2017 Toyota Prius As Reliable As Older Prius Cars? | Torque News
    I have not seen anything to indicate that the later generations have fallen below the reliability of the iconic Gen 2 Prius.
    I fact on this site they give the Gen2 (2007, 2008) a worse rating for powertrain reliability than Gen 3.
    https://cars.usnews.com/cars-trucks/toyota/prius/2010/reliability
    Of course they are not perfect but they are among the best.
    kevin
  7. Trollbait
    12,814
    Never claimed the Prius wasn't a reliable car. Just saying that the belief that having more parts makes other transmissions less reliable ignores the state of transmission technology today. Most of Toyota's other models have reliability of the level the Prius, and they manage it with these complex transmissions.
    Nothing about a car is simple. There is plenty that has a chance to go wrong, and something will in time. The measure of the car company is in how they handle it when it does.
    HPrimeAdvanced likes this.
  8. Bluecar1
    Bluecar1 Active Member
    204
    272
    Kent, UK
    I took a look under the bonnet of my Ioniq when i got it and was astounded at the size of the rocker cover to house all the variable valve timing for the Atkinson cycle engine, I dread to think how complex it is inside that valve cover
    oh for the days of an old overhead valve engine with pushrods and an old SU or zenith carb
    I will hobble into the corner with my zimmer frame having shown how old I am :( :(
  9. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    "Simplicity is the ultimate sophistication."
    -- Leonardo da Vinci
    Hyundai should take note.
  10. Trollbait
    12,814
    There can be elegance in simplicity, but if it were the be all and end all, the Prius would have a carbureted two cycle engine, or maybe an old diesel.
    Bluecar1 likes this.
  11. MikeDee
    1,581
    597
    Got to admire the simplicity of the bicycle though, the most efficient form of transportation that man has ever invented.
    HPrimeAdvanced and Bluecar1 like this.
  12. CharlesH
    2,798
    1,166
    Roseville, CA
    (A bit off topic...) Sometimes simplicity rules.The engines of small single-engine aircraft are typically air-cooled, carbureted , with magnetos for ignition. And they run on high octane low-lead gasoline (Avgas). Neither complex mechanical systems nor software of any kind in sight.
  13. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I remember a couple of years ago that per Toyota statements the Prius WAS the most reliable car inside Toyota brand.
  14. bwilson4web
    16,518
    Source: 10 Most Reliable Cars - Consumer Reports
    • Toyota Prius* Price as tested $27,323. ...
    • Lexus CT 200h. Price as tested $32,012. ...
    • Infiniti Q70* Price as tested $53,825. ...
    • Audi Q3. Price as tested $40,125. ...
    • Lexus GX. Price as tested $58,428. ...
    • Lexus GS. Price as tested $58,858. ...
    • Mercedes-Benz GLC* Price as tested $49,105. ...
    • Chevrolet Cruze* Price as tested $23,145.
    Understand we canceled our CR subscription because their car testing and scoring system is suspect. I don't know about their reliability claims.
  15. TinyTim
    TinyTim Active Member
    416
    241
    Seattle
    That is because the Prius is made in Japan. Wonder no more about reliability.
    Prodigyplace likes this.
  16. Prodigyplace
    12,711
    11,848
    Central Virginia
    For now that is the case. In the past, German engineering was considered top notch and now we have the Volkswagen fiasco.
    Bluecar1 and TinyTim like this.
  17. TinyTim
    416
    241
    Seattle
    German engineering is top notch. Nobody disputes that. It's the reliabilty of German engineering that is lacking on German imports. It has been said in Germany and Europe they are extremely reliable. There is the American know how that foreigners no matter the country do not understand. I don't consider England a foreign country as we speak their language.
    Bluecar1 and bisco like this.
  18. bisco
    52,804
    actually, the engineering that went into the software emissions cheat was brilliant, but criminal.
    Nic Steussy, Bluecar1 and bwilson4web like this.
  19. Trollbait
    12,814
    I believe the Volt is the most reliable model within Chevy. I think either of these cars being such as more to do with the importance they have for the company than how many moving parts they have.
    Toyota has models made in Japan and North America. Any evidence of there being a difference between where they were made?
  20. TinyTim
    416
    241
    Seattle
    No direct evidence other than CR says the Prius is one of the most reliable vehicles and all Prius models are made in Japan. The "J" being the 1st letter in the Vin means made in Japan. Many have suggested being made in Japan only means a slight increase in reliability.
