Prisu 2010 mechanical key in FOB do not work
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alexk345, Apr 30, 2024.
  1. alexk345
    alexk345 Junior Member
    46
    india
    hi all ,
    I thought i tell my experience
    There is a physical key in FOB.
    I assumed it work like in any car. NOT THE CASE.
    if Battery is completely down , you can open car with physical key. I called the TOYOTA guys they said it has no connection to battery. Probably the guy who answered never repaired prius.
    Prius need battery even with physical key.
    So i had to order UNLOCK kit from amazon and it arrived and watched few youtube videos to unlock it.
    Anyways i thought if people ask if they cant open with real physical key , tell them to get unlock kit
  2. alexk345
    46
    india
    Physical Key works fine after i bought new battery from canadian tire , 337 tax inclued and they took my old battery.
    52,925
    what's the point to having a physical key, if you need the battery?
    seaglasspearl2013 likes this.
  4. alexk345
    46
    india
    I asked the same question , but toyota guy said , you dont need. LIARS.
    Hybrid cars need battery. Issue is this. If you can charge 12V from outside then there is no issue. You need unlock kit if your battry die completely.
    Physical key is only for FOB dont work because its battery inside fob down.
    Without battery you cant open the car.
    Or it has some sort of deadlock mechanism in that as battery dying it enable the safety mechanism.
    That is ok but how do you open the car?
    Every time battery dies... its only way. They should have charging port for 12v battery
    seaglasspearl2013 and bisco like this.
  5. ChapmanF
    19,086
    I have a 2010 gen 3, and its physical metal key physically unlocks the driver's door, with or without any battery power. It is a simple direct mechanical linkage.
    I've owned a gen 1 and a couple gen 2s and those worked the same way.
    Tombukt2 and Brian1954 like this.
  6. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    And only the driver's door takes the physical key so what in the world
  7. HKz
    HKz Junior Member
    45
    17
    Mesa, AZ
    Hmmm our 2011's battery died last year, I did not have any trouble opening the driver's door with the physical key...
    Now the hatch yes, that is impossible to open from the outside if your battery dies. I know this because after I used the physical key to get in, I crawled over the seats to the rear area to open the plastic paneling in order to reveal the physical hatch release so I could comfortably change the battery lol
  8. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    After you unlock the drivers door, open it, reach in and pull the lid handle.
    Then go around to the front of the car, open the hood and prop it open.
    Then remove the cover for the fuses. Flip the red cover at the top of the fuse box
    to expose the positive terminal. Either use jumper cables that are attached to a
    good, charged 12v battery, or attach a jump box. This will supply power to the car.
    It is very likely you'll be able to open the trunk lid normally...
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,019
    NJ-USA
    The lock cylinder in the driver's door has a mechanical link to the door latch - no power required.
    What I have seen on this type of system is that the lock doesn't get any use in years. When you do try the key, the lock cylinder is dirty or sticky and won't turn. Maybe working the key a few times will free it up, maybe it needs lubrication.
    seaglasspearl2013 and Brian1954 like this.
