Prisu 2013 69k mile battery check hybrid system battery error P0A80 error
Discussion in 'Gen 3 Prius Technical Discussion' started by Brad wije, Mar 12, 2018.
  1. bisco
    51,947
    isn't the hybrid battery under warranty?
    Raytheeagle likes this.
  2. JC91006
    16,769
    8,567
    This car is under warranty in California, go to the dealer for a free battery
    amos and Raytheeagle like this.
    51,947
    why does the report say sri lanka?
    Raytheeagle and davecook89t like this.
  4. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    :eek: Maybe that explains how a 5 year old battery would have these problems.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    JC91006 said: This car is under warranty in California, go to the dealer for a free battery
    Bisco said: why does the report say sri lanka?
    Everyone else thinks: Holy crap, that's going to be a long drive.........nice catch
    (y)
  6. Prodigyplace
    12,564
    11,779
    Central Virginia
    They had to drive that far to find a good dealer. :whistle::cool:
    amos, Danny3xd, bisco and 2 others like this.
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Just like in real estate, location is everything. Nice catch, @bisco. ;)
    I would say that, if you can manage it at all, at least get the Prolong charger with manual discharge system along with a couple new modules from HA. Just the modules will probably get it running but will generate more cost and work in the long run, not to mention the likelihood of standing beside a dead car on a dark rainy night wondering what to do next.
    bisco, Prodigyplace and Raytheeagle like this.
  8. Brad wije
    Brad wije New Member
    corona, ca
    Flights to Mars start just two years down the road and Asia is nothing. I am from LA and will be in Sri Lanka until May 2019 on an assignment. No warranties here. Surprisingly there is a Toyota owned repair facility 2 miles down the street. They only replace with new batteries. I need to use it for another year and sell it. swapping modules is only option. There are numerous places doing battery repair and conditioning. Not sure they know what they are doing.
    #28 Brad wije, Mar 13, 2018
  9. Prodigyplace
    12,564
    11,779
    Central Virginia
    Did you import your 2013 Prius from the US or buy it locally?
  10. Brad wije
    corona, ca
    Direct import from Japan used car hence no warranty and no guarantee of mileage.
    Prodigyplace likes this.
  11. Brad wije
    corona, ca
    Where can get the modules and the charger?
  12. Prodigyplace
    12,564
    11,779
    Central Virginia
    Raytheeagle and jerrymildred like this.
  13. Brad wije
    corona, ca
    TMR,
    This thread was very helpful. Can you help me to get 4 modules shipped to new York. What is the cost of the Charging system?
  14. Brad wije
    corona, ca
    Is there a video showing how to setup prolong reconditioning package?
  15. jerrymildred
    11,517
    14,152
    Tampa, FL
  16. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    They have step by step instructions :).
    Good luck with your Prius (y).
  17. Brad wije
    corona, ca
    Can someone tell me if I need to replace those two modules that show 13.99? I just need to keep this simpler and what will happen if I just replace the one module that show 12.6?
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    I believe if the pack has voltages that differ by more than 0.2 volts, it’s a sign of weak cells:(.
    From how your pack looks (lower in the middle and higher on the outside) that heat has taken a toll on the pack. Seeing that spread, you might have more than 3 modules that have issues. But for sure replacing the one at 12.3 volts needs to be done;).
    Good luck (y).
    jerrymildred likes this.
  19. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Why isn't this battery covered under the hybrid system warranty?
    [Edit] Sorry everybody! I usually read threads more thoroughly before weighing in.
    #39 css28, Mar 14, 2018
  20. jerrymildred
    11,517
    14,152
    Tampa, FL
    Because it's actually in Sri Lanka, not CA.
