Prisu 2013 69k mile battery check hybrid system battery error P0A80 error
Discussion in 'Gen 3 Prius Technical Discussion' started by Brad wije, Mar 12, 2018.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    I can't think of any driving techniques that would prolong the battery's life. It needs to have the cells balanced now.
    amos, Prodigyplace and Raytheeagle like this.
  2. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    At first, I thought the "40000 us$" was a typo. That much for a used Prius with a bad battery? Something doesn't add up. Are import duties responsible for the high cost? What would you pay for a new Prius there?
  3. Brad wije
    Brad wije New Member
    corona, ca
    Brand new is $60000 above
    Toyota Prius 2016 Carmudi Sri Lanka
    divide this by 150 to get us$
    median income in this country is $10000 annual
    amos, davecook89t and Prodigyplace like this.
  4. Brad wije
    corona, ca
    The mechanic wouldn't do the balancing he said he cant balance this, obviously he was not balancing it with his phone software. Will the prolong charger do the job? How would I know it did?
  5. davecook89t
    1,089
    825
    Four Touring
    Interesting. And from the looks of the steering wheel in the picture, you don't even get Bluetooth as standard equipment (never mind Toyota Safety Sense). Someone along that supply chain must be making out like a bandit.
    To the best of my knowledge, using a Prolong charger is about the only way to balance the modules properly, without a lot of time and effort. You can monitor the individual blocks on your phone using Torque (or something similar) as you drive to verify that their voltages are staying within an acceptable range, both with and without a load.
    Raytheeagle and jerrymildred like this.
  6. jerrymildred
    11,517
    14,152
    Tampa, FL
    That's pretty much exactly what it's for. Balancing batteries.
    Raytheeagle likes this.
  7. Keepdriving
    Keepdriving Junior Member
    35
    27
    Palatine
    Hi Brad, I’ve been driving mine with a bad battery for over 10k miles. Whenever the warning light came on I would turn it off with OBD2 scanner. Probably came on about 10 times? but not sure. The light comes on typically when I’m not paying attention to where the battery level is on the energy monitor. It’s been over 6 months but will see what happens.
    amos likes this.
