Prius 04 salvage, overheats/sets p1150 & p1116
Discussion in 'Gen 2 Prius Technical Discussion' started by TLK914, Aug 2, 2008.
  1. TLK914
    TLK914 New Member
    Los Angeles CA
    Hello all. 1st time here, hopefully I can receive and occaisionally offer some help. I am an emissions and drivability tech, sometymes a trainer and consultant. With gasoline engines, and emissions, I rarely get beat.
    Now I have a hybrid in the bay. 1st time, but Im the guy that gets the headaches here, so its mine.
    I have taken the older Hybrid courses. 3 lf them. HOWEVER, the last one I took was close to 2 years ago, and all 3 courses pretty much consisted of pictures of new hybrid cars, discussions of what a hybrid is, and discussions about not touching the orange wires, please dont touch the orange wires...btw, stay away from the orange wires....etc etc...
    A large body account of our shop sent this Prius over for mil on. front end wreck. nice work, looks clean and well done, everything is new genuine toyota parts. Scanned with Mastertech v14.1a, codes p1116 and p1150. If you fire the engine and hold throttle at a point high enough to keep the engine from shutting itself down by choice...it will sometimes overheat. If the battery gets low and it takes over the engine running (battery charge mode, throttle disabled) then the engine will do an overheat shutdown ALWAYS within 5 minutes (temp climbs very quick when its autocharging the battery.) Overheat Warning lamp comes on at 248f degrees, gasoline engine shutdown occurs at 258f). When it overheats, the cooling fan IS running and moving hot air to the touch.
    The codes indicate the storage tank valve or pump is possibly clogged/not flowing; and temperature change isnt detected when required. I idled in the bay till a shutdown event, engine coolant temp on scantool showed 258, storage tank temp on scanner was about 168(Warm, but not near as hot as the engine temp on the scantool).
    recheck 30 minutes later. Engine temp has dropped to 197, storage tank down to 128?!?!? That should be impossible? Assuming they didnt replace the thermos bottle with a beer mug, a thermal insulated container cant cool that fast unless its not sealing to atmosphere or no longer sealing heat internally? crack the petcock, its probably telling the truth, feels like 100-120, definately not scalding in the 200 range?
    I have it sitting now. approximately 90 minutes to 2 hours since shutdown. engine is at 160, storage bottle temp on scanner is 87 degrees. in 2 hours, the bottle has cooled to ATMOSPHERE! Crack petcock, red coolant is absolutely COOL, no heat at all anymore. no more than 2 hours after it scanned and felt very WARM and scanner said 168f.
    SO, based on that, I am diagnosing a defective thermos tank. (Whatever else may be wrong, it cant cool that quick from 168? should have been over 140 even tomorrow morning!?).
    NOW however, why didnt the tank temp(Scanned or felt?) get to 258 like the engine? It SHOULD refil at shutdown if I read right? So that may be a totally different issue like its not filling properly or the line or valve IS plugged/defective(Though it did get warm?)? I cracked the petcock 10 minutes after the engine shut down for overheat and it was just WARM at 160ish, not boiling?
    Further, why did the engine go to overheat shutdown with the cooling fan running? Is it possible there is simply too much air in the cooling system and its not bleeding on its own? Could air cause the 1116 ad 1150 codes with no other defects?
    Does anyone have an effective coolant air-bleed procedure or do I need to find someone to borrow an AIRLIFT tool from? Or if air in the system is unlikely, what else should be checked?
    Any help appreciated. I know how to read ALLDATA, but experience is the best teacher, so thought Id ask someone who has banged a hybrid around and make sure Im not misinterpreting what I read about how it works?
    Thanks in advance
    Kelly Garvey
    Drivability/Smog Technician/iATN member
    Complete Auto Systems.
    Los Angeles CA
    NortTexSalv04Prius likes this.
  2. Patrick Wong
    18,200
    6,492
    Hi Kelly,
    Do you hear the coolant heat recovery pump running for 15 seconds or so, after the car is shut down? That is how the canister gets filled up.
    If you hear the pump running but the fluid in the canister is not at engine temp, then it is possible that the valve that switches engine coolant to flow to the passenger cabin heater core or to the canister is stuck, so that coolant only flows to the cabin heater core.
    Also see the attached message string:
    http://priuschat.com/forums/prius-t...ant-heat-storage-thermos-how-do-you-test.html
    Note that when you drain coolant from the coolant heat recovery canister drain cock, some of the initial flow is coming from the radiator; hence that fluid will be relatively cold. The engine overheating issue is much more of a concern than the coolant heat recovery canister. Regarding that problem, I am wondering if the engine thermostat is opening. Do you feel hot coolant flowing through the radiator hose leading to the radiator?
    If the thermostat is OK, then are the two radiator fans blowing properly so that they are sucking air; or are they blowing air towards the front of the vehicle? I have seen a few posts where the body shop incorrectly installed the fans. Is the serpentine belt in good condition and its tension properly adjusted so that the engine coolant mechanical pump is being driven properly?
    Regarding the procedure to refill engine coolant, this can be done without using a special coolant air-bleed tool. I did this for another Prius owner last weekend. However this requires considerable patience. Note the valve on the upper driver's side of the radiator that allows air to be bled as fluid is added. Also note that ~6 quarts of SLLC are required to be added after all three drains have been opened.
    Pls see my post #22 from the attached string:
    http://priuschat.com/forums/care-maintenance-troubleshooting/30813-changing-engine-coolant-3.html
    BTW the correct coolant to be used is the pink Toyota Super Long Life Coolant; not the red Toyota Long Life Coolant. However this should not cause the overheating issues.
    Also, are you aware that there is an inspection mode that keeps the gasoline engine running at all times: make the car IG-ON while the gear selector is in P, and fully depress the accelerator pedal 2x. Then shift to N and fully depress the accelerator pedal 2x. Then shift back to P and depress the accelerator pedal 2x. At that point, make the vehicle READY and you will see the hybrid vehicle icon appear in the upper left corner of the MFD. The gasoline engine will remain on. Do not drive the vehicle in this condition as the transaxle can be damaged if the tires slip.
  3. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    Patrick, How do you get it out of inspection mode?
  4. Patrick Wong
    18,200
    6,492
    Just turn the car to IG-OFF. Next time you make the car READY, it will be back to normal.
  5. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    Does the coolant can get hot on the outside? If so that is an indication that there is a problem internally with the can. You should also check the hose routings are correct and the electric pump and valves are functioning. Check you PMs.
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    1)Listen to Patrick before you listen to me.
    2)Patrick sounds like he's on track...I want to know about the coolant pump too..that could easily be the entire problem. Second guess would be improperly replaced coolant with some air in the system. Third would be a thermostat not working.
    3) Let us know what you find.
    4) Thanks for coming here....there are a lot of people here with a lot of knowledge...some of us have specific knowledge in a very finite area, others with broader knowledge, but there's a good chance we (as a group) can offer some direction to almost anyone who's humble enough to ask. And trust me...you'll be getting requests for help from us too!!
  7. cygnusx1
    cygnusx1 New Member
    topeka, ks
    2003 Prius
    Definately sounds like a blockage somewhere--something not flowing... Use one of those laser pointer temp gauges to check temps in the system without having to take crap apart... this should give you your answer quickly and effectively....
  8. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    front end collision usually means there's still air in the system.
    you've got a scantool. don't f around with the diy workarounds when you're on shop time.
    scantool>
    active tests>
    water pump active test
    activates coolant pump for 30s- will refuse command for that long, and then it will shut off. run this until you stop hearing the air.
    use the air bleed valve on top of the radiator. use a 6 mm allen to open that up. down on the side of the radiator there's a little air bleed outlet. watch that until it's running coolant w/o air bubbles.
    alternate this w/water pump procedure. it's not easy to bleed coolant in this car, takes some patience.
    you can't use a specialty coolant system bleeding tool like w/a regular car, unfortunately. too much vacuum on that system and you can do damage.
    that's from my husband, a fellow unbeaten diagnostician and former hybrid tech, over the phone. i only see him a couple weekends a month now since he's back in school.
  9. Patrick Wong
    18,200
    6,492
    Hi Galaxee,
    Regarding engine coolant drain/replace: since the Toyota scantool is used just to run the coolant heat recovery pump, and since it is possible to short the coolant heat recovery pump relay socket terminals to achieve the same end, then from a DIY perspective it appears that there is no advantage to having the scantool available for this particular job. Do you agree?
    The air bleed outlet on the side of the radiator is news to me. My 2005 repair manual did not mention this, so I did not look for it. If you've seen this could you please describe where to find it.
    Thanks for providing the warning about not using a vacuum bleeding tool to speed up this process. Did DH say how long it should take to do this job, assuming that the tech is experienced and well down the learning curve?
  10. galaxee
    9,810
    468
    MD
    oh boy. well i won't be able to get ahold of him for a while so i don't know the answers to all of those questions.
    the scantool is a huge timesaver. these guys don't get paid by the hour, they get paid by the job. rather than fooling around taking things apart, they plug it in and press a couple buttons. much simpler. from a diy, sure. i can see that. we have yet to replace our coolant loops because of all the stupid crap that keeps happening to us, but we don't have a scantool and DH isn't afraid of the job.
    i'll ask him to clarify the location of the bleed outlet next time we talk. tonight, maybe. i don't remember how long it took him to bleed a prius coolant system at the top of his game, but there is a definite learning curve. for conventional cars, the bleed procedure is made pretty quick and simple with a couple-hundred-dollar adapter and bleed kit. in shop time, the kit pays for itself in time saved pretty quickly. the prius takes a little more effort, as usual.
  11. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    hey galaxee, glad to hear your husband is doing well in search for his better career, must be tough to be only to see each other for a tee wee bit when you were used to seeing him everyday for so long. Be strong!! and thanks again for the wise answers as i'm sure he will excel in his upgrade for success.
    I know a coolant job only pays X hours and for the prius you don't get any extra so techs are discouraged from working on hybrids hmm (goes true when bleeding prius brakes, lots of techs thinks its stupid) ... I will confirm that when I go to work again on Tuesday. BTW is a coolant thermometer is a good indicator of coolant life besides the pink color?
    Oh and sometimes I remember a Camry Hybrid customer complaining about noise (hissing?) after getting his coolant changed, the techs said due to the complicated nature of the system, you would have to drive it for awhile before all the air is cleared out of the system. Hm is that true or they just lying so they can go bang up other jobs to make up the camry that lost their potential flat rate earnings?
  12. TLK914
    TLK914 New Member
    Los Angeles CA
    Hi all. Thanks for the many helpful replies. Armed with printouts of 3 threads here, I started the engine, coolant and can temp were near identical (around 88 degrees) and car had not b een started or touched since saturday evening (roughly say 40 hours).
    On startup, it warmed reasonably quick. Cooling fan came on at 230 or so, Triangle and coolant warning message at 248 around 10 minutes running, coolant fan was spinning at what appeared to be full speed.
    Prior to startup, I cracked the bleeder valve on the engine (I guess thats the one recommended? only crackable anything on the radiator itself is a petcock down near bottom of drivers side tank). It spewed fluid cracked cold...but I squeezed hoses, let it settle, zapped pump with scantool (actuator mode), let it settle...anmd was able to get another half gallon to fit before it literally wouldnt bubble or take a drop more.
    It still warms very fast, and eventually overheats.
    On to the bottle tests. At startup, bottle temp was 90ish degrees as was engine.
    10 minutes in the engine was at 200 and bottle still at 88. SHUT ENGINE OFF FOR 2 MINUTES. Restart, bottle updates after startup to like 96, but thats all. engine is at 206. let it run another 5 minutes, engine now creeping into the 240s, bottle still at 96. shutdown. scanned bottle temp still 96, restart, bottle temp starts JUMPING just as coolant warning activates at 248 right after startup. its moving rapidly just after re start of the already HOT engine. let it run 2 more minutes, engine safety shutoff at 258, bottle scanned temp now at 165.
    Open petcock on bottle: slightly warm to the touch. Quickly close petcock and wait 30 minutes. Scanned bottle temp (Engine has not been restarted!) now at 117 30 minutes after showing 160, coolant at petcock is COLD now.
    WHat I BELIEVE this sequence tells me is the bottle is able to open to the engine and trades coolant when starting, but for some reason the coolant IS NOT being pumped into the bottle at shutdown l ike its supposed to be. Im not sure what sound I am supposed to hear, but other than a humm that lasts pretty much FOREVER with key power still on but engine not running...and the humm/buzz appears to be in the hoses and plastic coolant storage tank dead center above the bellhousing and NOT in the coolant heat storage can...I dont hear a temporary pumping noise or feel one of any kind immediately after shutdown? after the 2nd trip to check the rapidly bleeding temp of the stored coolant...which does warm slightlty but never ever seems to get hot...
    Im pretty convinced we have a pump or valve failure to supply the can with fully warm coolant. However since SOME coolant apparently gets in and warms it slightly...the code definition may be accurate on this occaision and its merely PLUGGED or possbly a pinched hose that is severely restricting flow IN to the can?
    Thats where Im at now...customer is getting antzy...but without known good parts and with the other 2 drivability guys out today I was too busy to give it more than about 1 hour. Tomorrow I can hopefully throw more tyme at it if they dont yank it entirely. But thanks to the replies here and the data collection it has led me to...
    I believe we have a restriction or failure of warm coolant supply.
    Sound like the right track based on the data so far? never more than warm and often cold coolant in the bottle even right after shutdown or shortly after...and no apparent pumping sounds? (Where should I look/feel for the best try to verify pump on shutdown?)
    PS, I can actuate flow valves and water pump...however, the only valves it lists on the screen of the Mastertech with dealer toyo card, are listed as Flow valve 3, 4, and 5? I dont know if there is a 1 or a 2 but they arent on the scan screen? And for actuating the can pump...I dont think it gives me that access (Unless its automatic with the flowvalves?) because it only lists 1 PUMP which appears to be the main water pump for the engine.
    \Thats where Im at. Any new ideas?
  13. Patrick Wong
    18,200
    6,492
    After you remove the black plastic cover, you can see that the top of the radiator is covered by body sheet metal. Look for a hole in that sheet metal on the driver's side of the car, and you will see a 6 mm hex fitting within. Use a 6 mm Allen key to open up that fitting, which will allow air to vent out of the top of the radiator.
    While you are running the engine to purge out air in the coolant system, did you set the heater temperature control to Max Temp and turn the fan to max speed, so that the heater core will fill up with coolant?
    If you are sure that you have filled as much coolant as you can but the engine still overheats, I suggest that you consider removing the engine thermostat and testing it. It is supposed to open at 82 degrees C (180 degrees F). If the thermostat is good, then maybe the mechanical coolant pump has failed?
    Your message says that you "zapped pump". This should be done when the car is IG-ON (not READY) and the engine should be off. The pump in question is the coolant heat recovery system pump. When you applied power, did you hear the pump running? It is easy to hear. The purpose of running that pump would be to fill up the canister and associated plumbing with fluid. After that is done, then you would start the engine in inspection mode and continue to purge air out of the system.
    If you do not hear the pump running, then check the CHS relay which lives in the relay box mounted to the cowl. One of my prior posts (that I earlier gave you a link to) explains how to short the relay socket terminals to force the coolant heat recovery system pump to run. Then you can see whether you can hear the pump or not.
    The hum is the inverter running (when the car is READY), and/or the inverter coolant pump which runs at all times when the car is IG-ON or READY.
  14. galaxee
    9,810
    468
    MD
    except that when you do that short like that, you don't have access to the flow control valve. when the car is off, the valve blocks off the path to the chs tank. you can jump the pump, but where is the coolant coming from and going? how is the air going to get out if the valve is closed? the scantool will open the valve when you trip the pump and let the air out.
    ok, if you're looking at it from the front of the engine compartment. it's on the rear side of the radiator pointing back toward the engine compartment. the valve is on the LH side (right side when looking into the engine compartment.)
    the 6mm hex plug is on top of the radiator, you stick the allen wrench through the frame rail in front. the bleed outlet is directly below. it's metal.
    it depends on whether you have to burp the chs tank. if yes, and it all plays out, he can do it in 15-20 minutes. his record is under 10, cycling it 3 times. and he didn't even work at that dealership- the tech handed him the techstream and told him to do it :p if it's not all perfect on the first shot, more like 30-35 minutes which is fairly average. unfortunately you don't know 100% for sure until you park the car for 5 hours. if there's air, you'll suck it up, the temp sensor cools off from the air, car sets cel. you can be pretty damn sure beforehand, but it happens from time to time where they come back if you send them out too soon.
    thanks phil :) we'll be fine. been through far worse trials that didn't even involve the promise of a better future. this isn't fun but so far so good. hope you and the little family are doing well too.
    some places are taking to charging the flush rate for a prius drain and fill to account for the time...
    are you talking about the pH dip strip or the hygrometer? as far as DH has been told, neither can accurately test the sllc. it is thinner than the ethylene glycol coolants so the hygrometer readings are off. also, the pH chart that comes with the dip strips won't be accurate.
    yes. the camry coolant system is the easiest damn coolant system to bleed ever. including the camry hybrid. he has no idea how you would f up and get air in that system. either something beyond that is wrong with the car or the tech is itching to rack up hours. the tech is bullshitting.
    if it's hissing outside the car after the car is warmed up the radiator cap may be loose. if the noise is inside the car, it's probably air in the system. usually that sounds like a gurgle though.
  15. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    OK. Stupid shot in the dark here.
    On another thread, a guy had a Prius that had some front end repairs done to it.
    There are two fan motors that pull air through the radiators. But, the motors turn in OPPOSITE directions, and the fan blades have OPPOSITE blade pitches.
    If they were swapped when the front end was assembled, then instead of having two fans that efficiently suck air through the radiator, you have two fans that inefficiently (because they're both turning backwards) blow air out of the front of the radiator. In his case, this is just what was done. He swapped the sets of fan blades and everything worked out great.
    Might be worth checking.
  16. Patrick Wong
    18,200
    6,492
    Hi Galaxee,
    Thanks to you & your DH for considering my questions.
    Regarding the flow control valve position, the valve is supposed to direct coolant flow to the cabin heater core (and sometimes the canister as well) when the engine is running. When the engine is turned off, the valve is supposed to direct coolant flow to the canister for preheat as well as storage operation (see for example, page 05-287 in the 2005 repair manual.) Therefore I assumed that the valve would remain in that position after the coolant heat recovery system pump stopped operating and the car remained IG-OFF.
    Perhaps this assumption is not valid; however we were successful in refilling the engine coolant system. I recall that DH was planning to change the engine coolant on your Prius without access to the scan tool. What was his plan to deal with this issue?
    Regarding the radiator bleed valve, I know the valve that is accessible from the top LH side and can be opened using the 6 mm Allen key. Is it correct that this valve and the drain cock located on the LH bottom of the radiator are the only valves associated with the radiator?
    20 minutes for doing the job is amazing; we probably spent 1.5 hours or more working on getting all air out of the system.
  17. galaxee
    9,810
    468
    MD
    patrick-
    he left all of his training materials here so he directed me to the hybrid system training book, course 071 page 4-14. during storage (ig-off), the valve provides a path between the heater core and the head, but the chs circuit is blocked off.
    i don't recall how he was going to do it. he didn't say much other than that i'd get it once he showed me.
    will get back to ya on the other stuff.
    re: the time... that's why diy and professional wrenching are on vastly different scales. this is also why in a big shop, scantools are worth the investment. in that 1.5 hours, DH could have gotten the prius out the door and made a couple bucks on that, moved on to a good juicy maintenance ticket to put some real hours on his paycheck, and maybe even been moved on to the next car. this is the pace that is expected of you in the shop, and if your bay doesn't produce the profits... the inhabitant of that bay is replaced. the emphasis is always more work in less time when there's work laying around waiting to be done. it deserves all the criticism it gets...
    TLK- good luck with getting this worked out- will let you know what DH says again next time i talk to him.
  18. Patrick Wong
    18,200
    6,492
    Thanks, Galaxee. Regarding p. 4-14, figure 4.19, I agree that the illustration shows that the valve does not route flow to the canister, and that the water pump is "off". However that does not make sense since the water pump in fact does run for several seconds to fill the canister, when the car is shut down.
    I've attached the page from the 2005 repair manual that I had previously cited, which shows that the valve is open between the engine and the canister when the car is IG-OFF. This appears to contradict figure 4.19 from course 071.
    For those who are following along, course 071 can be downloaded at Automotive Training and Resource Site
    The file is Hybrid04 Engine.pdf
  19. galaxee
    9,810
    468
    MD
    the pump active test isn't the engine water pump. that's for the chs pump. if you can run that on active test, then the pump functions. if you're not sure, reach back under the wheel well cover and rest your hand on the pump, trigger the active test.
    could be the flow valve is screwed up if you're not getting hot coolant in the tank, and if it's not keeping the coolant hot for very long if hot coolant is getting in there, he's worried about the integrity of the chs tank.
  20. galaxee
    9,810
    468
    MD
    could be this is what happens AFTER the water pump fills the tank. note the pump is OFF but hot coolant is already in the chs tank. this clearly is the state *after* coolant has been pumped into the tank. isolating the hot coolant would be a good idea, after all. the running pump to fill the tank is just a few seconds of operation and not the permanent state while the car is off.
    would it contradict or would this be looking at when the coolant loop is open to allow coolant to enter the tank? it is concerning the operation of the valve, which would make the open position during transfer more relevant to the topic at hand there. it even says storage operation (after power switch off.)
