Prius 12v battery theory....
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Aug 15, 2025.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    TRUE / FALSE (and please discuss).
    1. The 12v battery does nothing other than wake up the computer and provide power if in ACC mode.
    2. Once the car starts, the traction battery provides for all loads. The 12v battery is just another load on the traction battery (because it recharges the 12v battery)
    3. If you had a completely dead battery in a Prius that was incapable of taking a charge, you would never be stranded as long as you had a jumper box with a good charge.
    4. Once started, the 12v battery could even be removed because it does nothing (just talking theory, not suggesting that's a good idea).
    5. The Prius doesn't even need a 12v battery to be present, you could just attach a jump box each time to wake up the computer and start the car (again, just talking theory).
    I'm pinning down my understanding of the 12v battery function.
  2. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    1 and 2 are correct...
    But 3 is not correct because a dead battery in a circuit is going to suck the life out of the 12v charge in the system. And if the dead battery can't take a charge you'll likely have the same problem if you removed the battery entirely after the car is in ready mode which is warning lights, error codes and system shutdown because the car isn't detecting the 12v that it depends on for all circuits to be running properly even though it's not actively drawing power but charging that circuit...
  3. ChapmanF
    18,969
    1. The 12-volt battery provides power for all of the loads (ECU memories, smart key operations, lights, horn, etc) that are enabled all the time. In addition, it supplies the infotainment system and 12v power outlets and a few other things, when in ACC mode. In addition, it supplies all of the car's 12-volt loads, including windows, climate blower, defoggers, electric seats, wipers, brake pressure pump, coolant pumps, etc., when in IG ON mode. It also supplies all those loads in READY mode for a second or two until the system main relays close and the DC/DC converter takes over the loads.
    2. Once the car is in READY, the DC/DC converter output is in parallel with the 12-volt battery. Because the DC/DC converter output voltage is generally a bit higher, it is generally what's carrying those loads when it is active, and the 12-volt battery is getting a charge.
    The DC/DC converter is taking its power from the high-voltage system, not just from the high-voltage battery. When the engine is supplying charging power, or when you are coasting or regen braking, those sources of power are supplying the DC/DC converter and therefore the 12-volt system. At other times, the power is coming from the traction battery.
    3. Depends on the capacity of the jumper box. An extremely-discharged Prius 12-volt battery can suck all the charge out of a smaller jumper box, even if the box was charged to 100% to start with, in less time than you need to connect the jumper box and reach around inside the cabin to try starting the car.
    4. Yes, that works; that is my usual way of getting around #3. I get the 12-volt battery out of the circuit first, use the jumper box to make the car READY, then put the 12-volt battery back into the circuit so the car can charge it. Having the battery out of the circuit then doesn't harm the car. A gen 2 Prius may log a trouble code because the remote-sensed 12-volt battery voltage doesn't reflect what the DC/DC converter is putting out.
    In other (especially older) cars, don't do that. Conventional alternator/regulator systems depend on the battery being in the circuit.
    5. You might be able to drive a Prius this way for a while before going stark staring bonkers. All of the ECU memories would be lost every time, all the recalibrate-after-battery-replacement things would always need to be done, and so on.
    PrimeDan likes this.
  4. PriusCamper
    13,417
    5,416
    I'm suprised the computers don't throw up warning lights when you don't have a 12v connected? Wouldn't the computers notice that the 14v charge to 12v wasn't being received? As in when you have a discharged battery that's able to get into ready mode from a jump start it still creates all kinds of glitches in the system when driving it before its fully recharged, right?
  5. ChapmanF
    18,969
    Gen 1 and gen 2 have two wires that connect at the 12-volt battery positive post. The fat one is the main power cable and the skinny one is the DC/DC converter's voltage sensor, so it can react to the exact voltage at the battery, unaffected by any voltage drop in the wiring.
    The cars don't really panic if that wire's not connected. Gen 1 just silently goes to a nice default DC/DC output voltage, and gen 2 does that and sets a trouble code and a warning light.
    You can "take the battery out of the circuit" in more than one way, say by undoing the clamp from the battery post, or just unplugging the fat wire from the clamp.
    If you undo a battery clamp, then the sense wire and main cable are still connected at the clamp, and the DC/DC converter sees its own output voltage coming back, which won't seem weird. If you unplug the fat wire, the sense voltage stays reading the battery voltage no matter what the DC/DC converter puts out, which may seem weird enough to set a code. So you get a code and light telling you you did something weird. You already knew that.
    In gen 3 they still have the "remote sense" wire but just bolt it down in the fusebox. It allows the DC/DC converter to accurately sense voltage unaffected by any voltage drop in the, like, nine inches of fat wire from the converter to the fusebox. So taking the battery out of the circuit doesn't really change what the converter senses.
    Gen 4 had the switch to the more sophisticated Battery State Sensor and I don't know how that responds to your unexpected shenanigans.
    PriusCamper likes this.
  6. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    You are still using a 12v battery to ready the car. Without 12volts, the hybrid system
    won't be "readied".
    If you didn't need the 12v battery, Prius wouldn't have one.
    Even the Tesla uses a 12v battery.
  7. PriusCamper
    13,417
    5,416
    Both EVs and Hyrbids have had all kinds of similar failure in their 12v system not being robust enough. With the amount of amps an alternator could produce in a regular car there was always plenty of power for the 12v to charge up quickly. But when there was no longer a need to use the 12 volt to use lots of cranking amps to start an engine they started limiting the amps to recharge the 12v to so little that all kinds of problems arose. https://www.wsj.com/business/autos/why-is-my-electric-vehicle-dead-check-the-12-volt-battery-67d432dd
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The 12v battery does more than that. It powers up windows locks wipers headlights and etc under ACC. The hv bat won’t supply the power when ACC is only on
  9. T1 Terry
    T1 Terry Senior Member
    966
    544
    The biggest pain in the butt, is losing the distance travelled on that particular tank of fuel, so you end up topping the fuel up well before the expected range per tankful.
    We did the battery disconnect thing when the taxi Prius would lose the speedo and odometer if the vehicle didn't sit over night before being restarted .... we found a workaround by pure accident when the rear hatch wouldn't shut properly and caused the door open light to show up in the instrument cluster .... the down side of that one, without the rear hatch properly sealed, exhaust was drawn into the cabin on highway driving .... the work around then was, open the rear hatch to the first click when parking the car, but remember to shut the rear hatch after you restarted the car .... that grew old real quick as well.
    The extaxi Prius would kill 12v battery on a regular basis, just dragged flat to many times until the 12v battery would no longer hold a charge. Replaced it with 4 x very used LFP cells to form a 12v battery, after 5 yrs, that same battery went on to power the winch on the trailer when the ex taxi Prius was put out to pasture ...
    The problem turned out to be the DC to DC charger only put out 12.8v for some reason, the system was fine with that, but that is not enough voltage to recharge a 12v lead acid battery .... but it was plenty for the LPF battery to hold some where between 30% and 60% SOC .....
    T1 Terry
