Prius 12V Battery went dead in 20 hours, Fob key won't unlock door
Discussion in 'Gen 4 Prius Main Forum' started by sgpriusdriver, Mar 14, 2017.
Tags:
  1. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    My humble apologies, Alan. It was already Gen 4 when I opened the the post.
    alanclarkeau likes this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    That's fine - I'd reboot myself, except 'tis too late for a double shot coffee (nearly 9pm). That's for the morning.
    Prodigyplace and RCO like this.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Having looked, I see he was last seen managing his account about 12 minutes ago. You'll have to assume that was a profile change. Not the first and certainly won't be the last to be caught napping with a dated profile after a new car in the garage. Last I heard it's no longer a cardinal sin. Just makes helping that little bit more edgy! :whistle:
  4. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    Mine went dead at 12 months. Defective battery. I started a thread on it. Warranty replacement just miles from 36,000 limit. It's the only issue I have had. Retail cost on the battery is about $280.
    #44 William Redoubt, May 29, 2017
    RCO likes this.
  5. alanclarkeau
    7,045
    7,592
    I assume that's 36,000? :)
    That's at least 3 faulty on a car which was released less than 18 months ago.
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    ProdigyPlace will probably confirm that is one of the perils of buying into the first run of a new line. Think he said it several times before.... and others have also.
  7. William Redoubt
    1,228
    1,172
    Yeah, I fixed that. 36,000 miles.
    The dealer stated that for the US the batteries are manufactured by Interstate.
    Electricity is black art. I would assume there is a certain percentage of unit failures in all batteries. At least the Truestart is warrantied for 84 months.
    RCO and alanclarkeau like this.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    I suspect that if you get a car that's been on the showroom floor, there's a good chance that the 12v battery takes a lot of abuse from people opening doors and so on. But if they sit in the lot in the hot sun, maybe that's not so great either. :confused:
  9. bisco
    51,948
    i wonder if the gen 4 12v is an odd size as in the past, or if you will now be able to replace it with a myriad of inexpensive options, like most cars.
  10. alanclarkeau
    7,045
    7,592
    I wonder - the battery under the bonnet (hood?) now instead of in the boot (trunk?) may mean that it's getting a lot hotter.
    I had 2 VW Microbuses ('74 & '77), the battery in the back (the engine was there too) but in the airstream from outside - the batteries lasted well. Next car was a Mitsubishi EXPRESS where the battery was under the driver's seat, and was always hot - I only ever got 18 months out of batteries in that car.
    RCO likes this.
  11. bisco
    51,948
    sure, but isn't every gasser? and the engine runs less in the prius. i can buy a good battery for my pick up truck for $100. and the current one is 12 years old.
  12. Archenemy
    Archenemy Junior Member
    24
    Singapore
    "Other non-hybrid" was before i took delivery of my prius 2016 earlier this month...
    Noticed that i used "our 12v battery is......."
    Hehe..anyway yeah..the 12v battery is indeed very poorly designed..considering that on hybrid mode..the alternator doesnt charge the 12v..which is more than 50% of the time..
  13. bisco
    51,948
    how do you know that? i have never hear it before.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I think I read somewhere that is the HV battery that keeps the 12v Pb/acid topped up on the Gen 4.
  15. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    The 12V battery is charged from the High Voltage system by a DC to DC converter - it does not depend upon the engine running to be charged or supply 12v power to run the vehicle.
    kevin
    #55 kevinwhite, May 29, 2017
    RCO likes this.
  16. bisco
    51,948
    maybe different in singapore?
    RCO likes this.
  17. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It's such a major system, I can't think why they'd vary it regionally.
  18. bisco
    51,948
    ya, could just be newbie confusion.
    RCO likes this.
  19. Mendel Leisk
    41,463
    I was wandering around a Honda dealership showroom, noticed on one car with the hood up: they'd disconnected the 12 volt negative cable.
    I'm on Clore Automotive mailing list, got this the other day. If you've got some time, a lot to digest:
    Grasping Ground Side Concepts - CloreInfo.com
    jerrymildred likes this.
  20. jerrymildred
    11,517
    14,152
    Tampa, FL
    Thanks. Looks good. I book marked it so I can take my time with it. (If I ever get some time! LOL!) Troubleshooting rule #1 as an industrial electrician was, if weird things are happening, check the neutral. On a car, that would be the ground.
    kithmo and Mendel Leisk like this.
