Prius 12V Battery went dead in 20 hours, Fob key won't unlock door
Discussion in 'Gen 4 Prius Main Forum' started by sgpriusdriver, Mar 14, 2017.
Tags:
  1. bisco
    51,949
    but how do we know it's bad? maybe the amp is drawing it down faster than it can recharge?
    kithmo, jerrymildred and RCO like this.
  2. Mendel Leisk
    41,463
    You can disconnect negative battery lead, push a chain link ( or similar) into the hatch latch to simulate hatch closed, wait maybe 20 minutes then connect miniameter. I measured 16~20, with occasional spikes to around 45, which I think is normal case.
    kithmo and RCO like this.
  3. Dale Leonard
    Dale Leonard Member
    66
    47
    Hartland, Wi
    The best way to prove a bad battery is to replace it. I have had a lot of bad batterys over the years. In most cases it is easier to buy a new battery than to play games with the dealers
    #83 Dale Leonard, May 31, 2017
  4. Mendel Leisk
    41,463
    No offense, but I'd say that's the WORST way to test a battery. How about acquire
    a tester like Solar BA5? Then you're not flying blind.
    #84 Mendel Leisk, May 31, 2017
    RCO likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I'd be still going with disconnecting the non-original stuff, returning it to stock first. If that solves the problem, then work out which of them is incompatible. If not, maybe the battery is indeed dead.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    What's the point paying out for a new battery if the fault lies elsewhere ?
    Mendel Leisk, RCO and alanclarkeau like this.
  7. Prodigyplace
    12,564
    11,779
    Central Virginia
    If it is bad, it may be replaced under Toyota's warranty. I remember at least one other battery replaced extremely early under warranty here.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Perhaps this is a cautionary tale to warn modders about interfering with the default Toyota Prius electrics...
    .. unless they're absolutely certain they know what they're doing. (n)
  9. Dale Leonard
    Dale Leonard Member
    66
    47
    Hartland, Wi
    If the wife gets stuck a couple times in her brand new sienna, it is real easy to replace the battery.
  10. Prodigyplace
    12,564
    11,779
    Central Virginia
    How does that apply here?
    The Sienna is not a hybrid and the battery has the engine starting stresses that the Prius one does not.
  11. Dale Leonard
    Dale Leonard Member
    66
    47
    Hartland, Wi
    Bad batteries are bad batteries. Has he Found a fix yet.
  12. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    There's no denying that, but to suggest that a flat battery is a bad battery and to change it would cure the problem, doesn't make sense.
    RCO likes this.
