Prius 2001 heat Gauge
Discussion in 'Generation 1 Prius Discussion' started by illusion4sx, Jan 30, 2015.
  1. ChapmanF
    19,061
    Sorry, I missed in your earlier post where you mentioned being overseas with no access to a proper scanner.
    It's very likely that the temperature light and the P3120 are telling you about the same problem, so when you fix the problem you'll be done with them both. Not having the INF codes just means having to do more of the diagnosis the old fashioned way. You know something is getting hot. Probably not the engine, because there was no engine code for overheat, the coolant doesn't feel hot, and the engine thermostat wasn't the fix.
    So it's probably safe to guess that if you could read the P3120 INF codes, you'd find one (or more) of the ones having to do with transaxle/inverter overheating, and going on that guess it would certainly make sense to check the inverter coolant circulation. The pump should be running any time the key is ON, and whenever the pump is running, you should be able to see about a 2 cm 'waterfall' inside the small coolant reservoir that is about centered under the hood, between the engine and the inverter housing. Do you see that?
    -Chap
    usnavystgc likes this.
  2. illusion4sx
    illusion4sx New Member
    2001 Prius
    The inverter coolant circulation is good since I changed that pump few months back. I did replace the main computer behind the compartment and so far it looks good but again, the weather is freezing now and I have not drove it for a long distance so I have wait a little to drive out of town and keep you guys posted
  3. illusion4sx
    2001 Prius
    Is there a youtube clip or a diagram to show where to adjust the headlights for this 2001 Prius? They keep shinning up and pissing off people on the other side of the road
  4. ChapmanF
    19,061
