Prius 2004 Gen II ECM replacement with P2610 OBD code
Discussion in 'Gen 2 Prius Main Forum' started by aryabasu, Oct 1, 2018.
  1. aryabasu
    aryabasu Junior Member
    28
    Atlanta. GA
    Hi everyone,
    Good morning!
    I am based in Atlanta, GA and I drive a 2004 Prius. Recently, my MIL is on with the code P2610. I have been to the dealership and they are asking for a ECM replacement part number: 89661-47104. My car is not under warranty and has ran 164700 miles.
    Is this the right thing to do? The ECM is quite expensive. Are there other alternative places where I can buy this part?
    Thanks,
    Arya Basu.
    #1 aryabasu, Oct 1, 2018
  2. PriusCamper
    PriusCamper Senior Member
    13,411
    5,413
    Pacific Northwest, USA
    I don't have experience with this particular code, but typically a dealership fixes cars under warranty so they'll replace very expensive parts at Toyota's expense even when it's not the root of the problem because they could care less about diagnostics, just jacking up as many warranty charges against Toyota as they can get away with is their highest priority.
    Likewise, if they start replacing expensive stuff at your expense, they'll likely keep replacing expensive stuff until it's fixed and they rarely pick the right part to replace on the first try, so it could cost you ten times as much at a dealership than going to a legitimate auto mechanic who fixes non-warranty problems at the lowest cost possible because that's what customer loyalty requires.
    There's a reason we call them stealerships instead of dealerships...
    SFO likes this.
  3. aryabasu
    28
    Atlanta. GA
    Thank you PriusCamper.
    I get where you are coming from. I found this article on NHTSA saying that a similar code on newer Priuses (2014 and beyond) does not need an ECM replacement.
    Link: https://static.nhtsa.gov/odi/tsbs/2016/SB-10084375-5448.pdf
    Should it not be the same procedure for a 2004 Gen II? On the same token, I mean!
  4. PriusCamper
    13,411
    5,413
    Probably not, but there are some PriusChat folks who own both of these vehicles and might know the correct answer...
  5. aryabasu
    28
    Atlanta. GA
  6. PriusCamper
    13,411
    5,413
    Yea, but that's a bunch of money to spend on something that may not solve the problem... There was a guy on here a month ago who had a friend with the same Prius as him and was able to keep swapping out parts to diagnose problem.
    If I were you I'd do some digging via google search to find all the other things to check/fix before you start spending hundreds on parts that may or may not fix it. And hopefully someone with more experience with this problem will see this thread and further advise...
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Arya,
    If you'd like to wait a few hours, I can look in my stockpile at home and see if I have one. I'd be happy to mail it to you to swap out and see if it solves your problem. If it doesn't, then you wasted no money except shipping. If it solves your problem, we can work something out much better than that ebay price. I'm not sure if it's something that has to be matched to the car or not, or immobilizer programmed, etc.
    You could also read this just to review that code:
    P2610 ECM/PCM Internal Engine Off Timer Performance
    #7 TMR-JWAP, Oct 1, 2018
  8. aryabasu
    28
    Atlanta. GA
    That is very generous of you. Thank you! I am not sure if I have to program the immobilizer. Kindly suggest!
  9. aryabasu
    28
    Atlanta. GA
  10. PriusCamper
    13,411
    5,413
    That's very kind of you!
  11. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    It looks like all I have is a 89661-47250. I don't know if it's compatible or not. Here's photos of the label and the plug receptacles. Let me know if you'd like to try it.
  12. aryabasu
    28
    Atlanta. GA
    Thank you so much. I really appreciate the gesture. Unfortunately, I tried this link here to check if my 2004 Prius is a match or not. It turns out it is not compatible. Toyota Ecm 89661-47250 | West Kendall Toyota Parts
    Thank you again. I need this part: Toyota Ecm 89661-47104 | West Kendall Toyota Parts
  13. aryabasu
    28
    Atlanta. GA
    Hello all,
    I was able to get a hold of this part on eBay.
    My question now: What are the steps involved in getting the ECM replaced? Should I involve the dealership?
    In other words, if I were to install a new (open box) part, does it involve re-programming the ECM or not?
    Thanks.
    #13 aryabasu, Nov 3, 2018
  14. PriusCamper
    13,411
    5,413
    If you do some googling with key word 'Priuschat' you should find lots of info on that... I remember someone mentioning that there's a service that reprograms them to match your vehicle.
  15. Elektroingenieur
    2,515
    3,288
    Three Touring
    See the Repair Manual (more info), under Engine/Hybrid System: Engine Control System: ECM (1NZ-FXE): Replacement, for the 54-step procedure, which is mostly cross-references to the procedures for disassembling the instrument panel to get access to the ECM mounting location. The only initialization mentioned is for the power window control system; that’s done whenever the 12-volt battery negative terminal is disconnected.
    Perhaps others who have replaced an ECM will comment on their experiences; I can only share some information from published documents.
    For 2004 models, it may or may not be necessary to store the Vehicle Identification Number into the replacement ECM. See Toyota Technical Service Bulletin EG045-04, “Entering VIN During ECM (PCM) Replacement and/or DTC P0630,” revised January 24, 2005, which states, “2004 model year vehicles which have been flash reprogrammed may contain updated 2005 model year OBD II logic. These vehicles will require VIN entry into the ECM (PCM) after reprogramming.”
    If you want to be diligent, and you have the necessary tools, you could also check whether the hybrid vehicle control ECU or the replacement ECM needs the software updates from Special Service Campaign 50P. For 2004 models, the new calibration IDs are 899834717001 and 34705200, respectively.
    The bulletin and campaign instructions explain how to do the VIN input and software updates using the Toyota Diagnostic Tester, available when the documents were written, but it should also be possible to do those tasks using the current Toyota Techstream diagnostic system.
  16. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    I realize I am jumping in late, but what diagnostic tests have been performed that condemn the ECM? ECM failures outside of voltage spikes from jump-starting are very unusual. The ECM off timer fault can be caused by interrupting the B+ circuit to the ECM, thereby preventing the internal clock from counting. There are other wiring related causes, but this is the most common I have seen.
    Elektroingenieur likes this.
  17. HighBreed
    HighBreed Member
    113
    Los Angeles/Orange Counties
    Hello Arya: Did you ever fix the problem? I want to know because I am also having the same error code P2610. Any lead or advice on what to do would be greatly appreciated. Thank you.
  18. aryabasu
    28
    Atlanta. GA
    Hello HighBreed!
    I ended up replacing the ECM for $600+ labor. I am sorry but P2610 in my instance was pretty much a bad ECM.
