Prius 2007 back-up light not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nadee, Jan 13, 2020.
  1. Nadee
    Nadee New Member
    Srilanka
    My prius 2007 back-up light suddenly stop working. Both side
    Bulbs and 10a fuse good but BK/UP LP relay receiving 12 via 3H-6 terminal as well as 3H-7. But when put in to reverse 3H-7 voltage only droop upto 9volt. Please be kindly help me
  2. pasadena_commut
    pasadena_commut Senior Member
    3,062
    951
    Southern California
    I don't know what those lines are. Are both to that relay?
    Since relays do fail start by checking that.
    If you pull the relay is there continuity all the way from the expected pin(s) to the taillight bulbs?
    If you test the pulled relay on a bench does the side which is supposed to switch actually do so?
    Is the resistance on the drive side of the relay within the acceptable range?
    Are there any internal shorts in the relay?
    SFO likes this.
  3. Nadee
    Nadee New Member
    Srilanka
    Thanx for reply
    Relay ok i put in to a anther prius and wiring also ok. But still no reverse light.
  4. Stormy Steve
    Stormy Steve Junior Member
    Rockmart ga
    I never found any relay.so/I wired a sw.inmy glove box/console/ lights now!
  5. Stormy Steve
    Rockmart ga
    Please/I hate I rigged it.
    But theres Alot of stuff behind the glove box /someone said a black relay?
    Didnt see it.
