Prius 2007 doesn’t forward without accelerater
Discussion in 'Gen 2 Prius Technical Discussion' started by Fahad’s, Apr 19, 2018.
  1. Fahad’s
    Fahad’s Junior Member
    Uk
    ----UK----
    Hi. I have Prius 2007 with 126000 miles and it doesn’t go forward it self unless I accelerate it . Can any body help me I don’t know what’s wrong with it even fuel consumption is very good. Usually when we put in to drive mode Prius goes farword it self but mine doesn’t . Please let me know if any body know about it. Thanks
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Are you on a flat and level surface?
    Raytheeagle likes this.
    52,679
    welcome!
    fuel consumption IS good? any dash lights? the 'creep' feature is purpose built, and may be a computer problem.
    i have never heard of this problem before though.
    jerrymildred and edthefox5 like this.
  4. Fahad’s
    Uk
    ----UK----
    Thanks a lot for your replies
  5. Fahad’s
    Uk
    ----UK----
    On level or flat surface .
  6. Fahad’s
    Uk
    ----UK----
    No dash light at all , I drove my friends car Prius and as we put in drive mood it's goes farword it self but mine dsnt.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    is your parking brake on? are any of the brakes improperly rubbing? Is a wheel bearing bad?
    Has it ever worked or has it always been like this?
    Jack up each corner and try to turn each wheel by hand
    jerrymildred and SFO like this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Thats what I was thinking too the parking brake but that would be a red light on the dash. My guess is also brakes maybe the rear brakes are dragging. Like TMR says spin those rear wheels in the air. The fronts dont free wheel they are really hard to turn.
  9. Fahad’s
    Uk
    ----UK----
    Thanks a lot I ll try and let you know
    thanks a lot I ll try to do what you advised me n let you know .
  10. Fahad’s
    Uk
    ----UK----
    Hmmmm lets c I ll check it and let you know . Thanks a lot
  11. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    What do you think is "good"?
  12. Fahad’s
    Uk
    ----UK----
    Still giving me about 56 miles per galan in average
  13. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    If it's a dragging brake, you should be able to feel the heat after a short drive. Be careful. It might be REALLY hot.
  14. Mendel Leisk
    42,166
    Assuming imperial mile per gallon, that translates to 46~47 US miles per gallon, still right in the middle of the pack for second generation.
