Prius 2007 p0300, p0301, p0302
Discussion in 'Gen 2 Prius Technical Discussion' started by Arshad Khan, Feb 14, 2022.
  1. Arshad Khan
    Arshad Khan Junior Member
    Uk
    While driving today, got the red triangle and all other warning signs on dash 3, plugged in my obd card reader, and got the following error messages
  2. Arshad Khan
    Uk
    Has anyone had these faults and how to fix them, car is 2007 prius with 185000 miles
  3. PriusCamper
    PriusCamper Senior Member
    13,468
    5,437
    Pacific Northwest, USA
    Looks like engine problems... When was the last tune up, new spark plugs, etc.? How many kilometers/miles on the car?
  4. Arshad Khan
    Uk
    185000 miles on the car, had the car for 6 years, regularly serviced but never changed the spark plugs
  5. Arshad Khan
    Uk
    Yesterday I drove it with all the errors, but today when I started it and tried to put in drive mode, would give the following error IMG_20220215_101141.jpg IMG_20220215_101050.jpg
  6. bisco
    52,863
    that can sometimes mean not enough voltage to the ecm. if the 12v is up to snuff, it could be corrosion at the terminals
  7. Mendel Leisk
    42,355
    Just for giggles: check the coolant level in engine reservoir.
  8. Arshad Khan
    Uk
    I took it to a mechanic, he said looks like a spark plugs issue, or maybe ignition coil, replaced spark plugs (old ones were really bad).
    Mechanic did not remove the codes and the errors were still showing, thought will clear them myself with the mini obd scanner but it won't connect, called RAC breakdown and their system failed to connect as well, any idea why it is not connecting, issue started after the plugs were replaced.
    Also car is driving but feels heavy and ABS light came on as well.
    As suggested will check for battery corrosion (recently changed only few months ago) and will top up coolant as well
  9. Arshad Khan
    Uk
