Prius 2008 A/C Blowing Hot Air
Discussion in 'Gen 2 Prius Technical Discussion' started by megaTCS, Nov 19, 2011.
  1. megaTCS
    megaTCS New Member
    cc
    HI Prius a/c start to blow hot air after driving the car for 30 min.
    In the next day when i start the car, it blowing cold air.
    A/C starts to blow warm air if i drive the car more than 30min. look like once the engine heats up its start to blow hot air
    What will be the issue? :confused:
    Only twice i got the VSC and Engine Check light. but it went off after 2 days. i Took it to the auto shop and did a scan, they said its giving lots of code (codes like: C1241, U0073, U0123,U0124, U0126, U0293, U0111) and they have reset the codes. and told if you get warning lights again then they can try.
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Sounds like it could be a problem with the inverter coolant loop/pump. Have you had the recall done yet?
    Try to drive it as little as possible until this is fixed!
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    +1. This explains C1241, which sets due to low 12V battery voltage. When the inverter coolant overheats, the car takes A/C offline, as well as the DC/DC converter. With the car dependent on the 12V battery to power all computers, it will sag quickly and many sensors will give low voltage related errors.
  4. richard schumacher
    7,683
    1,066
    United States
    Where are you? Take it to a Toyota dealer immediately. Replacing the inverter coolant pump is a recall item and may be at no cost to you. If the pump is bad it can damage the inverter, which costs a thousand or more to replace.
  5. megaTCS
    megaTCS New Member
    cc
    HI thanks for your reply, am in SRILANKA, toyota lanka doesn't provide warranty for hybrid. I imported directly from japan.
  6. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Ok then it's almost 100% the inverter coolant pump (aka the "HV" coolant pump). You should get it changed out as soon as possible. It's a pretty easy job if you want to do it yourself. I'm pretty sure some users have written posts explaining how to change it, so if you do a thread search you should find some guides.
