Prius 2008 CAN Bus Hacking Guidelines
Discussion in 'Gen 2 Prius Technical Discussion' started by mserour, Nov 7, 2019.
  1. mserour
    mserour New Member
    Alexandria
    Hello guys,
    I am planning to hack a toyota prius 2008 car with ELM327 OBD2, Have someone done this before and have an idea about the signals that I can read and write? or can provide guidelines for the CAN data base of the Prius?
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Don’t do it. Too many bad things can happen.
  3. mserour
    mserour New Member
    Alexandria
    Why not?, can you explain?
    We will hack it to use for a self driving car application, I know the risks but I want to here more from you.
  4. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It's extremely easy to do on the bus. The problem is if you are asking this question on how to do it, you are not the person who SHOULD be doing it.
    It is pretty neat though to steer the car from your laptop and that type of thing. But that's custom software and hardware with lots of controls.
    Skibob likes this.
  5. Skibob
    2,912
    1,505
    Northern California
    Also how would you stop? I don’t think the brakes are fly by wire on a gen 2 Prius. There is a hydraulic backup thru the brake petal.
  6. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    You can override the pedal input signals, as long as they match, and move the car. It's just two potentiometer readings fed into an ADC and then the CANBus. The thing about CAN is that if you know what you're doing it is easy to snoop and alter messages on the bus without errors.
  7. Skibob
    2,912
    1,505
    Northern California
    Would that actually move the brake petal?
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    No it doesn't move the pedal. But it can be overrode. Same reason the accelerator pedal doesn't move when you have cruise control set and it has to speed up.
  9. bisco
    52,915
    i don't recall anyone ever covering the signals here. maybe there is something in the tech forum?
  10. ChapmanF
    19,063
    The go pedal is the one with the two-potentiometers position signal. The brake system is not completely by wire, though Gen 2 was the closest it got. Gen 1 had the hydraulically-boosted master cylinder and Gen 3 brought it back.
    NortTexSalv04Prius and Skibob like this.
  11. mserour
    mserour New Member
    Alexandria
    I know how to do it but I was asking for a previous experience.
    If I hack the brake pedal in this generation, will the vehicle brake?
  12. mserour
    mserour New Member
    Alexandria
    so if I hacked the brake pedal and faked its value will the vehicle brake without pressing on the brake pedal?
  13. dolj
    dolj Senior Member
    8,657
    4,407
    Wellington, New Zealand
    I'm not sure whether you will get too much information here, as I do not recall anything like this being discussed (not to say it hasn't been) before. So, you may well be the pioneer in this endeavor.
    I do hope I am wrong, though.
  14. Elektroingenieur
    2,515
    3,288
    Three Touring
    I’m not sure what you would hack. The skid control ECU doesn’t rely on digital data from a CAN or other multiplex bus to determine the condition of the brake pedal or the driver’s braking demand; instead, it receives analog voltages directly from the brake pedal stroke sensor and master cylinder pressure sensors.
    I’d suggest that you spend some time looking over the “Chassis — Brake” section of the New Car Features book (more info) for the 2004 Prius (NCF255U), and the “Electronically Controlled Brake System” section of the Repair Manual, especially the system diagram, system description, and information for DTCs C1246 and C1247.
    You’ll notice that nearly all of the sensors and actuators for the brake control system are connected directly to the skid control ECU. This ECU does have a CAN bus connection, but on second-generation Prius cars, it’s used only for a few functions, such as getting the readings from the yaw rate and steering angle sensors, and for regenerative braking cooperative control with the hybrid vehicle control ECU (HV ECU).
    That last function is, I think, the opposite of what you’re asking about: the skid control ECU asks the HV ECU to apply regenerative braking, and to the extent the HV ECU reports that it is doing so, the skid control ECU reduces the hydraulic brake force, so the total brake force meets the driver’s demand.
    That said, I can’t say for sure that there is no way to cause braking by sending a message on the CAN bus, but as far as I know, that isn’t how the system—at least on this model—normally works. Later models definitely have that capability, since it’s needed for the Toyota Safety Sense driving support systems.
  15. Skibob
    2,912
    1,505
    Northern California
    What would happen if the brake Actuator failed and there was nobody in the drivers seat to press the brake petal?
  16. ChapmanF
    19,063
    It wouldn't make a sound.
    NortTexSalv04Prius and dolj like this.
