Prius 2008 Doesn't Start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Katia P, Dec 23, 2013.
  1. Katia P
    Katia P Junior Member
    55
    I tried to turn on my car this morning, but the "Ready" sign didn't go on. The whole display is black. "Check Engine" sign blinked briefly. Battery display shows the battery is "green". Everything else works - cd/radio/bluetooth, etc. As I tried to start it, the screen showed that the engine briefly charged the Prius battery, then it was all quite. I tried to wait and restart a few times, but still the display was all black and no "ready" sign. I WAS able to still move the car, but I didn't chance to drive it out of the garage. What can be the problem? I just had it serviced (oil/fluid change). Small battery was replaced in July. Thanks!
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    The combination meter (the display that's now black) might have failed based on what you've described.
    Toyota issued an extended warranty on these displays. I don't know if your model year was included. If it had been, you should have received a letter by now.
    Contact your nearest Toyota dealership and ask them to check your vehicle identification number to see if it's
    covered by the extended warranty. If it is, they should send out a tow truck to you to get it repaired.
    Katia P likes this.
    52,889
    perhaps a loose connextion at the 12v?
    Katia P likes this.
  4. Katia P
    55
    thank you for your responses! actually...it turned out to be a gas cap that was not tight enough. how crazy is that?! i've read somewhere to try it, and i did. on my second try after 15 min the car turned on and we didn't have any problems since...
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Wish it was true. A loose gas cap will throw a check engine light at best but will not hamper the car's ability to start.
    To save you and the kids from being stranded at the worst possible time please try this and post all 3 battery voltages.
    It may save you a huge hassle and alot of money:
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    Katia P likes this.
  6. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Yes, do check the 12V before anything else.
    Katia P and edthefox5 like this.
  7. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Thanks nh I fixed it.
    Katia P likes this.
  8. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi Katia. It's not the gas cap, and if nothing is done then the condition will probably return.
    A bad connection to the combination meter, as jadziasman suggests, is the most likely cause here. This is a fairly common fault, and it often starts out as an intermittent problem just like yours. In any case it's always a good idea to test the 12V battery voltage when the Prius has any unusual behavior, so do that first.
    Britprius and edthefox5 like this.
  9. edthefox5
    10,096
    4,840
    Clearwater, Florida
    And get that kid off the hood..lol...
    Katia P likes this.
  10. Katia P
    55
    guys, you were right...it happened again today..."check engine" sign came on and the car is not in "ready" mode. the gas cap didn't work. it's not that cold out. the 12V was replaced a few month ago. i don't think that's it...i'm so disappointed and frustrated. tried to do the "do-it-yourself" battery test, but i can't turn the car on without pressing the break :(
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    When you press the brake, does the car turn on? I know you say the 12V was just replaced but, this sounds like a weak/discharged 12V battery problem. That would be my first point of attack. Check the voltage and charge it if you can.
  12. JC91006
    16,939
    8,647
    Yikes, I hope you have small hands.
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    JC, I gotta go, can you help Katia with this? Have her disconnect and reconnect the 12V and go from there.
    Katia P likes this.
  14. JC91006
    16,939
    8,647
    I'll try
    Katia P likes this.
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Unfortunately, just because the 12 volt battery was replaced in July, doesn't mean the problem isn't stemming from the 12vlt battery or that related area. Too many stories of people getting "new" batteries not fully charged or defective.
    The here today, gone the next moment nature of the problem makes me speculate that perhaps it's a defective battery, battery post or installation of same battery created a short in a connecting cable or in installation a connection was loose.
    The fact that you had the 12 vlt battery replaced relatively recently actually makes me MORE suspicious of it being something related to that entire system.
    But since it seemed to suddenly appear, suddenly disappear, and suddenly re-appear. My speculation would be a loose connection or a short.
    I would think if it was a failing or weak battery, your symptoms would of been more consistent and simply remained until the problem was discovered.
    Best of Luck.
    Katia P and HaroldW like this.
  16. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Could also be a bad brake switch. Those might cause intermittent problems with failure to start the car.
    SCH-I535
    Katia P and usnavystgc like this.
  17. edthefox5
    10,096
    4,840
    Clearwater, Florida
    She clearly states she's pushing the brake and the car is not going into 'Ready". The engine is not starting. Also in her first post the combo meter is flaking out also so she may have 2 issues.
    First thing is test the small battery voltage. Just do the first 2 steps where you don't have to push the brake. Just the first 2. We are really interested in the second step the second button push as then the car is in accessory and has load on it and will reveal the true remaining voltage of the small battery. If its at 12.1 or above the small battery is not the issue.
    Alot of no starts on this forum have been no gas. Since the combo meter is out do you know if there's any gas in the car?
    Or the throttle body may be really mucked up and needs a cleaning. You do not post the mileage on the car nor where you live so not sure how cold it is where you live.
    BUT, there's also alot of posts where the mechanic severely overfilled the oil during an oil change choking the engine, fouling the plugs and the engine won't start. The dealer is famous for this. I see you just had the car/oil serviced. This is a common story. So check the engine oil dipstick asap.
    Katia P likes this.
  18. The Electric Me
    9,083
    5,801
    We're all speculating, in so much as we only have the information given and do not have the vehicle in our possession.
    But in the case of "No Gas" or "Engine Oil Overfill" those conditions don't synch with the intermittent or Here Today, Gone Tomorrow symptoms.
    The OP had the problems, then perhaps with no real connection tightened the gas cap and the symptoms went away. Then after X amount of time they returned.
    That would suggest to me it's not a case of being out of gas, or engine oil overfill.
    I'm still going with 12V battery....or a short or defect in the system, wires, post, connectors.
    If it's a short in the system, she could do the 12V battery voltage test, get good results but still have a problem. I think she should have the whole thing checked out. Battery voltage, connectors, post, wires....
    Katia P likes this.
  19. Katia P
    55
    thank you for your response! we tried charging the battery and it worked! so, the battery does seem to be the problem. we will be going to the toyota dealership where it was replaced and asking some questions...
  20. Katia P
    55
    thanks, everyone! it does seem to be the battery since it worked after we jumped it...very disappointing. we recently replaced it. the dealership gave us the wrong quote for the battery on the phone, but they had to honor it in person. the guy checking me out was not happy about the money loss...so, we are suspicious that as a "revenge" they put a used battery in our car :(
