Prius 2008 wiper arm removal tool?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priuses4All, Dec 18, 2015.
  1. Priuses4All
    Priuses4All Junior Member
    17
    I need to remove the wiper arms of my 2008 Prius to clean out under the cowling. Any recommendations for a wiper arm removal tool that will fit the narrow space around the base of the wiper arms?
    The wiper arms are firmly stuck -- I really need a removal tool.
    I bought an OTC Stinger battery terminal puller to remove the wiper arms, but the feet of the puller are too large to insert in the wiper arm recess. So that I don't buy another tool that won't fit, I'd welcome any suggestions for a brand of wiper arm removal tool that will do the job (any online links for a good tool would be much appreciated).
    Thanks!
  2. JC91006
    16,939
    8,647
    You don't need a tool, you just have to flip up the wiper blades so it's off the windshield......then unbolt and remove. You may need to wiggle it a bit but it should come off. The wiper blade has to be off of the windshield!
  3. Priuses4All
    17
    I already tried that.
    The wiper arms are on very firmly and are really stuck. I took it to a mechanic who had a devil of a time removing the wiper arms, and he had his own specialty tool.
    I hope that by having a mechanic take the arms off once it would help, but this was several years ago and they're firmly attached once again.
    What I would like – hopefully – are some recommendations for specific wiper arm removal tools that will fit a Prius 2008.
    Thanks.
  4. Patrick Wong
    18,214
    6,530
    I don't have a recommendation because I haven't needed this tool. It worked for me to wobble the wiper arms for removal.
    I suggest you go to NAPA or a place like that with your car, and let the clerk see your car's wiper arms. Then s/he can recommend an appropriate puller.
  5. bisco
    52,891
    is there any way to spray some loosener under there and let it soak overnight?
  6. Mendel Leisk
    42,376
    I've taken our 2010's wiper arms off a couple of times, no sticking. All I can think is some corrosion built up?
    One thing, it's worthwhile to mark the windshield glass with strips of masking tape or similar, where the wiper blades were before you removed. In practice they seem to have pretty good "homing sense", but just in case.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The wiper arm is under spring tension even when up. You need to push down on one side (wiggle) to release the spring tension and it will lift right off.
  8. Patrick Wong
    18,214
    6,530
    Usually the windshield will have two dots which show where the wiper blade ends are supposed to be when the wiper arms are parked.
  9. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Were the 17mm nut's removed, under the plastic cap, allowing the wiper arms to be gently pried off the toothed receptacle?
  10. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    I had a windshield replaced on my 2008 and faced the same problem. I figured I would prep the vehicle before the windshield guy showed up, save a little time maybe. I have a puller that would fit, but the amount of tension I had to put on the threaded bolt without a release made me give up on the idea. The windshield guy just removed the two 17mm bolts and "whacked" both arms with his hand and they were off. Did it so fast I didn't even see the method. OK, some skill there. As mentioned above, remove the bolts, rotate the arm to near vertical (well off the glass into the upward parked position) and then, using the extended wiper for leverage, wiggle forward and backward until the compression fitting releases. And, as Patrick has suggested, find the alignment marks on the windshield to line up the wipers for re-installation.
  11. Priuses4All
    17
    Thanks for the suggestions, much appreciated. However, I have wacked the wiper arms (when the wiper is folded up into the vertical position off the glass) until I thought I might break them. They just refuse to loosen without a puller-type tool.
    Patrick Wong: I also tried this. I took the car to a NAPA store and also to an AutoZone store. The guys at both stores looked at the confined space of the recess and shook their heads, no ideas.
    As luck would have it, the mechanic I took the Prius to several years ago has retired, so no info there. I also contacted eBay's Pro-AutoTools about a standard type of wiper arm removal tool (item #371511861514, which has a U-shaped base and a bolt that presses down on the top of the wiper arm bolt head) , but the owner there tells me this tool won't fit a 2008 Prius.
    Back to the drawing board....
  12. bisco
    52,891
    maybe stop in at an auto glass shoppe and request assistance.
  13. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    If they would be so stuck that you couldn’t get them off by wiggling puller would just break them. I have seen puller break them (on older cars) but I have never seen any that couldn’t be removed by just wiggling vibrating and using penetration fluid. And I don’t really think that yours are so stuck.
  14. Mendel Leisk
    42,376
    Maybe someone put something on them, super glue? :confused:
  15. Patrick Wong
    18,214
    6,530
    When the wiper arms are mounted, they tend to be slightly cocked on the threaded shaft. This is why the OP is having trouble removing them.
    My guess is that the "windshield guy" probably hit the arm down (towards the glass), to release that misalignment and make the arms easier to pull off the threaded shafts.
    If the OP cannot free the arms using the methods already discussed, another possibility is to push down on the arm, placing the blade tip of a very large flat blade screwdriver on the arm adjacent to the hole that the threaded shaft is protruding through, tapping on the end of the screwdriver with a hammer to apply force to the arm.
    Obviously a judicious amount of force needs to be applied. You are not trying to break the arm or the windshield.
  16. bisco
    52,891
    maybe the debris under the cowl isn't worth it.
    Patrick Wong likes this.
  17. Patrick Wong
    18,214
    6,530
    A voice of reason enters the picture...
  18. bisco
    52,891
    apparently, you haven't spoken with my wife.:cool:
  19. Mendel Leisk
    42,376
    Don't distract us with rationality, dammit!
  20. Priuses4All
    17
    Youse guys are getting OT.... -- With a hopeful nudge, let us back to the topic, for surely there must be a wiper arm removing tool that fits a Prius 08. --- But maybe not.
    As for the rationality question (that "maybe the debris isn't worth it"), I don't want to be responsible for veering us off course, but I'll answer that, and may regret it!
    I live out in the country where there's a rodent problem like you wouldn't believe. $1,200 spent twice on a Subaru that had to have all of its heater ducts replaced thanks to rodent "debris." My Pathfinder had a wiring harness chewed through by a rat (he was at it when I opened the hood). With the Prius, I had fine mesh hardware cloth screwed over the "rodent access holes" beneath the cowling (thanks to directions that I found on PriusChat, if I remember right), and had hoped this would keep the rodent nest building, droppings, and urine smell out of the ducts.
    But it was not to be. I need to be able to remove the cowling periodically because I've learned that, despite the screening, mice and rats continue to build nests on top of the metal tray (below the plastic cowling), and then this stuff gets sucked into the heater ducts and clogs/ruins the cabin filter....
    It's an ongoing problem as long as I own the Prius (and the next car may not be much better), or until I move away from these beautiful rodent-infested surroundings. (And, yes, I do trap, poison, and shoot the mice and rats. Frequently. Have also had a series of cats; the rats are too big for them.)
    I know there'll be a temptation to post now about Prius rodent control. My apologies for this OT digression, just trying to answer an obvious question. -- But, sincerely, I would just like to know of a wiper blade removal tool that will fit a Prius.
