Prius 2008 with 37 MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by Abdulaziz_Barham, Nov 9, 2016.
  1. Abdulaziz_Barham
    Abdulaziz_Barham Junior Member
    68
    Jordan-Amman
    Three Touring
    hi
    i have Prius 2008 with 37 MPG 90k mile
    what i have to do to make it more ??
    thank you in advanced
    52,697
    welcome! can you give us a little history?
    how many miles?
    how long have you owned?
    were you getting better mpg's previously?
    how are you measuring mpg's?
    any past accidents or other problems?
    anything you can tell us about the car might be helpful.
  3. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    sorry i am new with prius , history like what ??
    52,697
    see my edit.
  5. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    how many miles?
    90070 mil
    4 Months
    it was 37mpg since i got it
    from the info screen
    it had accidents in front lift and Sank with salt water (from car fox) in usa
  6. bisco
    52,697
    thanks. start with this: fill the tank, drive until low, refill, divide miles by gallons, and report back with true mpg's.
    in the meantime, inflate your tyres to 40f, 38r, and make sure they are low rolling resistance rated. check your oil level, test your 12v battery, check your air filter, clean your hv battery cooling fan and make sure the vent on the rear seat isn't blocked.
  7. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    i notes that with full tank trip a record 300 mile only until the fuel light on
  8. bisco
    52,697
    and how many gallons to refill?
  9. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    i takes 40 Liters i think it is about 10.5669 in gallons = Full tank
  10. bisco
    52,697
    i now see your other post. this is a salvage car from salt water flooding and you have trouble lights on?
  11. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    yes . i am in Jordan and i bought it from dealer who get it by Auction from usa
  12. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    I'm not knowledgeable mechanically and I suspect your problems are most likely mechanical but how the car is being driven and used has a lot to do with mileage too. A lot of short drives, hard accelerations, etc. can really affect the gas mileage. Ours has gone as low as 34mpg for a couple of tanks when all we did was drive it for a couple of weeks just on short hops around town for work or shopping. The car needs time to warm up.
  13. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    How many days does it take for you to drive the 300 miles tank?
  14. Abdulaziz_Barham
    68
    Jordan-Amman
    Three Touring
    from 25/10/2016 to 6/11/2016 with full tank = 300 Mile
  15. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    The bad battery is probably the reason for the bad MPG
    Abdulaziz_Barham likes this.
  16. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Would that be the 12v Battery or the HV Traction Battery?
    I concede that the 12v Battery might have suffered a degree of damage from salt water - though I'd have thought it wouldn't manifest itself via low MPG.
    Changing a faulty 12v has been known to make a difference.
    Has the owner considered the possibility that the salt water might have affected the bearings on any, or all 4 wheels , resulting in a degree of drag that is contributing to the low MPG figures?
    It seems a logical possibility. Other ideas; did the saltwater irretrievably damage the catalyser on the exhaust? Could this result in higher MPG?
    Last question; what are the ambient atmospheric temperatures in that area of Jordan from day to day when the vehicle is in use - and come to think of it - is any driving in particularly mountainous regions or on badly surfaced roads with bad traction involved?
    Is there a lot of short journey stop start driving involved?
    iPhone ?
  17. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    my bad battery comment was because in another thread he said he had symptoms consistent with a bad module in the HV battery
    Data Daedalus likes this.
  18. Data Daedalus
    1,025
    1,185
    Wembley, London
    Ah. Understood. Thank you.
    iPhone ?
  19. Kate Harvest
    Kate Harvest Member
    105
    Vancouver, WA
    (1) Check your tire pressures. The manufacturer recommendation is 35psi front, 33psi rear but many people on these forums prefers to go up to 42psi front/40psi rear. Personally I go halfway and do 38psi front/36psi rear. In my experience even a few psi can make a big difference in mileage with the Prius. I try to check and adjust at least once a month.
    (2) Check the engine air filter. If it's dirty, replace it.
    (3) Check your 12v battery. Let the car sit for at least a few hours, then push the power button once without your foot on the gas. Hold down the Info button then, while it's held down, flick your headlights on and off three times. The touchscreen should go into "System Check" mode. Push "Display Check," then "Vehicle Signal Check." This should get you to the screen that shows the battery voltage. with the car in accessory mode (i.e. power button once, no foot on gas) the value should be somewhere around 12v-12.8v. If it's significantly lower than that, you could try to recharge your battery by leaving the car on overnight but you'll very likely need a new 12v to get your car performing correctly.
    If you've done all of that and are still getting mileage in the 30's even on reasonably lengthy trips in more moderate temperatures, it's gotta be your driving style and you should consider reading some hypermiling guides to get a better idea of how to drive more efficiently.
  20. Mhd
    Mhd New Member
    Amman
    السلام عليكم
    اعتقد انها ممتازه اضرب الرقم ب 8.5 بتعطيك حوالي 315 بالتنكه...مليح
